Carb heat in the 9A
grantn
PostPosted: Thu Feb 28, 2008 1:43 pm    Post subject: Carb heat in the 9A Reply with quote
I see nowhere in the plans indicating that warmed air should be routed via a SCAT tube directly to the hole made in the top plate of the filtered air box. Is the radiant heat from the adjacent exhaust pipe in the low pressure area of the cowling sufficient for carb heat or should I be directing some air to the opening in the filtered air box with a heat muff / SCAT tube?
Thanks for any input.
Grant Neilson, RV9A finishing
 Filesize:  3.69 KB
 Viewed:  5315 Time(s)
mrobert569(at)hotmail.com
PostPosted: Thu Feb 28, 2008 2:15 pm    Post subject: Carb heat in the 9A Reply with quote
There is a small heat muff that goes around the crossover tube right above the airbox that is connected to the airbox but a short section of scat tube. I don't remember which drawing it is in but it does come with the firewall forward kit, if you have it.
Mike Robertson
To: rv-list(at)matronics.com
Subject: RV-List: Carb heat in the 9A
Date: Thu, 28 Feb 2008 13:38:51 -0800
.ExternalClass {font-size:10pt;margin-left:30px;color:#333399;font-family:Trebuchet MS, Verdana;} .ExternalClass IMG {margin-left:-30px;}
Helping your favorite cause is as easy as instM/Home/?source=text_hotmail_join' target='_new'>Learn more.
 Filesize:  3.69 KB
 Viewed:  5313 Time(s)
hooverra(at)verizon.net
PostPosted: Thu Feb 28, 2008 2:44 pm    Post subject: Carb heat in the 9A Reply with quote
Grant,
I installed Van's heat muff on the x over pipe on my 7A, I have not
flown yet so no pirep.
Anyone else attest to the effectiveness?
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1204238207-138-198&browse=engines&product=carbheat-muff
Ralph C. Hoover
RV7A
hooverra at verizon dot net
n616tb(at)btsapps.com
PostPosted: Fri Feb 29, 2008 10:57 am    Post subject: Carb heat in the 9A Reply with quote
It does seem effective in flight as there is a rpm drop when applied. Mine
doesn't make any difference on the ground when doing a run up. I wouldn't
hesitate to use it as shown.
Tim
[quote] --
bicyclop(at)pacbell.net
PostPosted: Fri Feb 29, 2008 11:00 am    Post subject: Carb heat in the 9A Reply with quote
I installed one of these on our 6A and was not impressed. We got maybe
10 rpm drop. We changed it out to about a 10" long muff fitted over on
of the crossover pipes and got much better results. That said, I've
never needed carb heat on our O-320, although I do use a little bit when
aggressively leaning to aid with atomization.
Pax,
Ed Holyoke
Ralph Hoover wrote:
Grant,
kahamer(at)bigpond.net.au
PostPosted: Fri Feb 29, 2008 4:57 pm    Post subject: Carb heat in the 9A Reply with quote
Hi all
I had one from Vans initially in my 6A and the rpm drop was very
small.Changed over to one made by Robins Wings and got 100rpm drop.
Karl/Sydney Australia
7A first flight maybe this Sunday!!!
bobbyhester(at)newwavecom
PostPosted: Fri Feb 29, 2008 7:53 pm    Post subject: Carb heat in the 9A Reply with quote
Go here and order the carb heat muff and airbox housing Smile
http://www.robbinswings.com/products.htm
Surfing the web from Hopkinsville, KY
Visit my flying RV7A web page:
http://home.newwavecomm.net/bobbyhester/MyFlyingRV7A.htm
Grant Neilson wrote: [quote] Nature BODY { MARGIN-TOP: 5px; FONT-SIZE: 10pt; MARGIN-LEFT: 30px; COLOR: #333399; FONT-FAMILY: Trebuchet MS, Verdana } IMG { MARGIN-TOP: 5px; MARGIN-LEFT: -30px } I see nowhere in the plans indicating that warmed air should be routed via a SCAT tube directly to the hole made in the top plate of the filtered air box. Is the radiant heat from the adjacent exhaust pipe in the low pressure area of the cowling sufficient for carb heat or should I be directing some air to the opening in the filtered air box with a heat muff / SCAT tube?
