enclosed trailers
poasttown(at)yahoo.com
PostPosted: Sun Feb 24, 2008 5:26 pm    Post subject: enclosed trailers Reply with quote
Every year I look back and evaluate what it cost to fly and every year I see that hanger rent makes up the largest percentage of my flying costs. So every year I think about building an enclosed trailer not so much for transporting my Kitfox but for storage at the airport.
I usually give up on the idea after two or three weeks of thinking about it. However, has anyone on the list gone this route? I know there has been alot of talk about trailers but not so much about enclosed trailers.
Mike Chaney
Be a better friend, newshound, and [quote][b]
Sbennett3(at)aol.com
PostPosted: Sun Feb 24, 2008 5:40 pm    Post subject: enclosed trailers Reply with quote
Mike, I hear that you can expect corrosion issues if you keep it in an enclosed trailer. I have a friend that has one and he says I can use it, but that would only be for an off airport forced landing. Steve Bennett 4-912 North Carolina
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
vetdrem
PostPosted: Sun Feb 24, 2008 6:16 pm    Post subject: Re: enclosed trailers Reply with quote
I bought my kitfox because I winter in Florida, spring and fall are in Arkansas, and summer in Michigan and I needed a plane that I could take with me. My plane came on an open, flatbed trailer that would carry it down the road, but not provide much protection, I built a framework out of conduit, and covered it with a tarp that is designed for covering lumber on semis. It has worked great for about 2500 miles so far, and the plane has been "hangered" in it here in Florida for the last three months. It takes about five minutes to roll it out using the 12 volt winch that I installed. I haven't noticed any corrosion or other ill effects from leaving it in the trailer. Of course, it isn't air tight, and it isn't as secure as a rigid sided trailer would be, but has sure worked well for me. The airport charges $30 per month to leave the trailer in a tiedown spot, (beats $$$$ for hanger fees). I can probably take some pics if you are interested.
Louie
shinco(at)bright.net
PostPosted: Sun Feb 24, 2008 6:24 pm    Post subject: enclosed trailers Reply with quote
enclosed trailers.
Mike Chaney
the thing with enclosed trailers is..That you have to watch how wide the
back door opening is.I have a 24ft enclosed trailer.I would have to do
alot of changing of the back door drop down.to get it to fit inside.but
it would if do alot of changing to it to fit.and all so have to watch
how tall the trailer is.even if you would change the rear door to fit
.it would be a close fit trailer is 108 in wide,and KF is app 8ft wide
wings folded.U would have app 6in on each side of wings in the
trailer..real tight fit..but it has been done..you would need at least a
24ft-28ft trailer..Steve Shinabery N554KF KF2
Guy Buchanan
PostPosted: Sun Feb 24, 2008 7:42 pm    Post subject: enclosed trailers Reply with quote
enclosed trailers.
Here's where my Kitfox IV lives. Out West we call them "toy
boxes" because they're made to haul dune buggies and the like. My Fox
fits with 1/2" to spare either side of the wings. It takes me seven
minutes to set up or tear down, but I designed for it. I pay for a
tie down so if I can get two more Foxes and boxes I'll get my monthly
down to $36.
I highly recommend it. Oh, and I have no problems with
condensation because the trailer walls are all vented out the bottom.
Also I have a couple of solar fans in the roof, and a solar panel
charger for my battery. The trailer cost $6600. (I didn't mind
because it's very marketable used.)
Guy Buchanan
San Diego, CA
 Filesize:  95.26 KB
 Viewed:  630 Time(s)
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
PostPosted: Mon Feb 25, 2008 1:47 am    Post subject: enclosed trailers Reply with quote
> enclosed trailers.
minutes to set up or tear down, but I designed for it. I pay for a tie
down so if I can get two more Foxes and boxes I'll get my monthly down
to $36.
charger for my battery. The trailer cost $6600. (I didn't mind because
Guy Buchanan
San Diego, CA
Guy That is one nice plane///and a nice trailer to store or haul it..wat
to GO....Steve Shinabery N554KF KF2
Rex Hefferan
PostPosted: Mon Feb 25, 2008 6:05 am    Post subject: enclosed trailers Reply with quote
I would like to see pics of how you did it. I also have a flatbed
trailer that came with my plane and have thought about constructing an
enclosure on it.
Rex Hefferan
SE Colorado / K-II / 582-C / still waiting repairs
Louie
Rex
N740GP - M2/582
Colorado
patreilly43(at)hotmail.co
PostPosted: Mon Feb 25, 2008 8:56 am    Post subject: enclosed trailers Reply with quote
Guy, What length is your trailer?
Do Not Archieve
Pat Reilly
Mod 3
Rockford, IL
Date: Sun, 24 Feb 2008 19:38:31 -0800
Subject: Re: enclosed trailers
>enclosed trailers.
down to $36.
Guy Buchanan
San Diego, CA
Guy Buchanan
PostPosted: Mon Feb 25, 2008 12:35 pm    Post subject: enclosed trailers Reply with quote
It's 22' x 7000# gross. The Fox fits with just inches to
spare. 24' would be better because then you'd have space for cabinets
and things at the end, but it bumped me up to 10k# gross and was just
too heavy for me to deal with. As it is I have plenty of storage
above and below the wings, I just have to be careful that anything
above can't come down in an earthquake or something like that.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
kitfox555(at)sbcglobal.ne
PostPosted: Mon Feb 25, 2008 9:51 pm    Post subject: enclosed trailers Reply with quote
These are some pics of my trailer built from a tandem boat trailer it's 8'6" wide 22' long made from EMT welded together with sheet metal has the hand wench if needed to pull it in cost was $1100 makes a great hanger for here in North Cal.still needs carpet and paint
Jerry Evans
96% done 582
Magalia Calif.
N582'er'
kitfox 555
 Filesize:  215.98 KB
 Viewed:  638 Time(s)
 Filesize:  220.51 KB
 Viewed:  654 Time(s)
Guy Buchanan
PostPosted: Tue Feb 26, 2008 8:49 am    Post subject: enclosed trailers Reply with quote
That's very cool, but does your wife know about her? Very Happy
Seriously Jerry, that's way better than mine, which cost $6600 to
buy. What do you think yours weighs? I wonder, if you put plans
together, and John found a fabricator, what it would cost to build and market?
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
vetdrem
PostPosted: Tue Feb 26, 2008 10:09 am    Post subject: Re: enclosed trailers Reply with quote
here are a few pics of mine. I did the emt framework, and covered it with a truckers tarp. the nose is fiberglass that they cover motorhomes with. the tail wheel goes up a ramp, and the wing tips fit nicely into the nose of the trailer.
Call me if you have any questions about hauling it. I've gone about 2500 miles so far, and had no issues.
Louie (989)387-4662
 Filesize:  483.3 KB
 Viewed:  675 Time(s)
 Filesize:  448.52 KB
 Viewed:  587 Time(s)
john beirne
PostPosted: Tue Feb 26, 2008 10:10 am    Post subject: Re: enclosed trailers Reply with quote
have had trailers on the back burner for a long time, was wondering where one could obtain plans for a trailer hanger. also i have heard of foxes being damaged by trailer suspensions being too solid. is this a consideration when trailering.
msm_9949(at)yahoo.com
PostPosted: Tue Feb 26, 2008 11:07 am    Post subject: enclosed trailers Reply with quote
John:
Don't know much about enclosed trailers but hard trailer suspensions are an issue whether open or enclosed. Most boat-type trailers from which our home-made trailers are typically constructed, are designed to carry much more than your Fox weighs. As a result, every bounce will be transmitted directly to the cargo rather than "absorbed" by the suspension. Double axles help some.
As you probably know, the stock, Kitfox single-leaf steel tailspring was notoriously prone to failure under the best of conditions. With the wings folded, the load on this spring increases dramatically. So if you do nothing else, find a way to unload and limit the flexing of the tail spring during transport.
john beirne <jmcb(at)oceanfree.net> wrote:
[quote]--> Kitfox-List message posted by: Be a better friend, newshound, and [quote][b]
PostPosted: Tue Feb 26, 2008 2:53 pm    Post subject: enclosed trailers Reply with quote
Jerry, What is max trailer width allowed in CA? It is 8' here in IL. You stated your trailer is 8'-6" wide.
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
[quote] Date: Mon, 25 Feb 2008 21:48:17 -0800
Subject: enclosed trailers
Jerry Evans
96% done 582
Magalia Calif.
N582'er'
kitfox 555
PostPosted: Tue Feb 26, 2008 3:07 pm    Post subject: enclosed trailers Reply with quote
Louie (989)387-4662
http://forums.matronics.com/viewtopic.php?p=166380#166380
http://forums.matronics.com//files/dscf0193_166.jpg
http://forums.matronics.com//files/dscf0192_201.jpg
Very nice job,,looks good.. good idea,,How do you get the KF up in to
it?? Steve Shinabery N554KF
Float Flyr
PostPosted: Tue Feb 26, 2008 3:33 pm    Post subject: enclosed trailers Reply with quote
You could also carry a little ballast to soften the ride.... Lots cheaper.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Marco Menezes
Sent: Tuesday, February 26, 2008 3:35 PM
Subject: Re: Re: enclosed trailers
John:
9[b]
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Tue Feb 26, 2008 7:40 pm    Post subject: enclosed trailers Reply with quote
Pat that is the limit here 8'6" according to the CHP
patrick reilly <patreilly43(at)hotmail.com> wrote: [quote] .hmmessage P { margin:0px; padding:0px } body.hmmessage { FONT-SIZE: 10pt; FONT-FAMILY:Tahoma } Jerry, What is max trailer width allowed in CA? It is 8' here in IL. You stated your trailer is 8'-6" wide.
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
These are some pics of my trailer built from a tandem boat trailer it's 8'6" wide 22' long made from EMT welded together with sheet metal has the hand wench if needed to pull it in cost was $1100 makes a great hanger for here in North [quote][b]
PostPosted: Wed Feb 27, 2008 7:41 am    Post subject: enclosed trailers Reply with quote
Jerry, I guess I stand corrected. Another e-mail said the legal limit is 8'-6" width for over the road nation wide.
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
[quote] Date: Tue, 26 Feb 2008 19:36:14 -0800
Subject: RE: enclosed trailers
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;} Jerry, What is max trailer width allowed in CA? It is 8' here in IL. You stated your trailer is 8'-6" wide.
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
bjones(at)dmv.com
PostPosted: Wed Feb 27, 2008 9:14 am    Post subject: enclosed trailers Reply with quote
Consider supporting the tail where the tail spring attaches to the fuselage to
avoid aft CG stress on tail wheel spring while trailering and avoiding impact
of spring on rudder because of limited clearance in this area on some model IVs
B Jones
443-480-1023
N154K
Quoting Noel Loveys <noelloveys(at)yahoo.ca>:
Noel
John:
help some.
transport.
_____
This message was sent using Delmarva Online's Webmail.
http://www.dmv.com/
