Posted: Mon Feb 25, 2008 6:01 am Post subject: Firewall foreward cooling air needs |
Here's the setup:
IO360B1F6 with CS MT prop, AFP injection, LASAR ignition, Vetterman crossover heater/mufflers in a SamJames cowled/plenum'd RV6A.
I'm planning on putting the oil cooler behind the #4 cylinder with its cutout for airflow feeding the oil cooler.
My heater/mufflers require cooling air over them even when they're not heating the cockpit according to Larry.
I'm thinking that taking the cooling air for both heater/mufflers from the back plate behind the #2 cylinder should be OK - since I'm taking a chunk from each side.
Is this a valid thought? - or does it not matter since I have a plenum.
For the cabin heat air, would it be better to take the air from the vertical plate or the 40 degree angled plate below it?
Ralph
rv9jim(at)juno.com Guest
Posted: Mon Feb 25, 2008 12:44 pm Post subject: Firewall foreward cooling air needs |
Ralph,
I have the same situation. I put in a air source on the ramp for
the #2 cyl for the left muffler. I put in a source for the port side on
the angled baffle behind #3 cyl. This seems to be my best way. I am not
flying yet but the bird is at the painters right now. Hopefully I'll be
flying by the end of March.
Jim
N15JN
