chasb(at)satx.rr.com Guest
Posted: Tue Feb 28, 2006 1:19 pm Post subject: Jihostroj Governor Control Arm |
I have a Whirlwind prop and a Jihostroj Governor on my RV-6A. The prop
control cable came from Van's and provides a one and three quarter inch
movement from full fine to full increase. However, the cable will only
move the governor control arm through about 2/3s of its arc. There is
only one hole on the control arm to attach the cable, so no adjustment
is available. Whirlwind didn't seem to know of any problems.
Do any of you RVers with a Whirlwind prop and a Jihostroj governor have
a similar problem? It has been suggested that a full increase prop is
never used, so there is no prolem. Any comments or fix suggestions?
Charlie Brame
RV-6A N11CB
San Antonio
dan(at)rvproject.com Guest
Posted: Tue Feb 28, 2006 1:47 pm Post subject: Jihostroj Governor Control Arm |
Same deal on my setup. Been flying like that for about 830 hours. I've had
no trouble running at any desired RPM in flight.
)_( Dan
RV-7 N714D
http://www.rvproject.com
