sam(at)fr8dog.net Guest
Posted: Tue Feb 19, 2008 11:04 am Post subject: EIS resistor |
I'm having trouble with my EIS 6000. Thinking about changing the 27k resistor, but I can't find one. My question is, can I put a 22k and a 5.5k in series instead?
Sam Marlow
nuckolls.bob(at)cox.net Guest
Posted: Tue Feb 19, 2008 11:46 am Post subject: EIS resistor |
At 01:58 PM 2/19/2008 -0500, you wrote:
| Quote: | I'm having trouble with my EIS 6000. Thinking about changing the 27k
in series instead?
Sam Marlow
Sure . . . Or even consider
a 50K potentiometer so that you
can adjust it to exactly what's needed.
Posted: Tue Feb 19, 2008 4:53 pm Post subject: EIS resistor |
Can I get one at a local Radio Shack, and what exactly do I ask for?
Sam
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)cox.net>
> Thanks,
> Sam Marlow
mlas(at)cox.net Guest
Posted: Wed Feb 20, 2008 7:48 am Post subject: EIS resistor |
Sam,
What is the problem you are having with your EIS 6000? If it is with the RPM indication, are you driving the RPM from the P-lead? If so what resistor value are you currently using? If you are using a resistor in the range required and it is not working you should call Grand Rapids. There is a mod that is required on some 6000’s which calls for the removal of a resister internally. It is a simple process and they can walk you through it or you could send it back assuming this is the issue.
-----Original Message-----
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Marlow
Sent: Tuesday, February 19, 2008 11:58 AM
Subject: EIS resistor
Sam Marlow
10/2/2007 11:10 AM
10/2/2007 11:10 AM
Posted: Wed Feb 20, 2008 8:14 am Post subject: EIS resistor |
It's puzzling, because it worked fine for 6 months, then the mag died. When I reinstalled the repaired mag, the tach started wondering, mostly at higher RPMs.
It's the 27k resistor, supplied by Grand Rapids. I sent a Demo log to G/R this morning, hope to here something soon.
I did the mod on the circuit board, before first flight, if that's the one your referring to.
Mike wrote: [quote] <![endif]--> Clean Clean DocumentEmail MicrosoftInternetExplorer4 <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} <![endif]--> <![endif]--> <![endif]-->
Sam,
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Sam Marlow
Sam Marlow 0 1 2 3 4 5 6 7 8 9
10/2/2007 11:10 AM
10/2/2007 11:10 AM
0 _popupControl();[b]
Posted: Wed Feb 20, 2008 5:20 pm Post subject: EIS resistor |
Sam,
Yes that’sthe mod I was talking about. Let me know what GRT says.
mlas(at)cox.net
Sent: Wednesday, February 20, 2008 9:09 AM
Subject: Re: AeroElectric-List: EIS resistor
Mike wrote:
<![endif]--> Clean Clean DocumentEmail MicrosoftInternetExplorer4 <![endif]--> <![endif]--> <![endif]-->Sam,
Sam Marlow
10/2/2007 11:10 AM
10/2/2007 11:10 AM | Quote: | | href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution |
_popupControl();
10/2/2007 11:10 AM
10/2/2007 11:10 AM
