KITFOXZ(at)aol.com Guest
Posted: Sun Feb 24, 2008 5:48 am Post subject: Of Test Pilots And Light Paint |
Guys,
Lurking among these recent posts, I have decided to NOT paint nor even Poly-tack the covering on my beauty. I am removing most structural adhesive in favor of scotch tape and very light bailing wire. Does any one of you have an extremely light weight "Experimental" decal I could buy?
John P. Marzluf (John Z.)
Columbus, Ohio
Series V Outback (Out Back In The Garage)
20% Complete, Not Currently Building
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
Lynn Matteson
Posted: Sun Feb 24, 2008 6:23 am Post subject: Of Test Pilots And Light Paint |
John-
I was thinking that if you took the normal "Experimental" decal, and
cut horizontal strips out of the material...say 1/4" wide...you could
probably cut the weight in half...a HUGE saving in weight, and the
word would still be readable. And stand by....I'm currently working
on a method of drilling lightening holes in bailing
wire...**aluminum** bailing wire.
Lynn Matteson
flying w/475+ hrs
On Feb 24, 2008, at 8:46 AM, KITFOXZ(at)aol.com wrote:
| Quote: | Guys,
Columbus, Ohio
AOL Living.
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Sun Feb 24, 2008 7:41 am Post subject: Of Test Pilots And Light Paint |
Great Scot Lynn!, Genius! As many have said before, this list is a wealth of Kitfox, indeed, aircraft construction knowledge! BTW, I just discovered that my fuselage frame weldment is built out of HOLLOW tubing! I'm now 1/2 finished! Even Wilber and Orville nit-picked their way to success you think? ; ^ )
--John
In a message dated 2/24/2008 9:25:03 A.M. Eastern Standard Time, lynnmatt(at)jps.net writes:
| Quote: | --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
John-
Lynn Matteson
flying w/475+ hrs
| Quote: | Guys,
Columbus, Ohio
========================he es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; =========================
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sun Feb 24, 2008 8:32 am Post subject: Re: Of Test Pilots And Light Paint |
you guys are playing with fire.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Guy Buchanan
Posted: Sun Feb 24, 2008 8:38 am Post subject: Of Test Pilots And Light Paint |
At 05:46 AM 2/24/2008, you wrote:
| Quote: | Lurking among these recent posts, I have decided to NOT paint nor
LOL! I always wondered if you could do the entire plane in Monokote.
Any model builders out there?
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Jim Shumaker
Posted: Sun Feb 24, 2008 9:28 am Post subject: Of Test Pilots And Light Paint |
I am currently test flying one of our EAA chapter members newly built experimental. (Not a Kitfox but the same weight class.) During the painting process he had trouble getting the paint on smooth so he added a few coats extra to smooth it out. He used two part industrial paint from his work. The extra paint added over 70 # to the target weight. Performance was hampered as well as the useful load.
A coat of white under a light color will still be brighter than a light color over poly spray alone. Probably be as light or lighter also.
Jim Shumaker
_________________ Jim Shumaker |
Lynn Matteson
Posted: Sun Feb 24, 2008 12:45 pm Post subject: Of Test Pilots And Light Paint |
O & W probably argued over using just plain Scotch Tape, or fiber
reinforced Scotch Tape...HEAVY...to hold the toothpicks together.
Lynn Matteson
flying w/475+ hrs
On Feb 24, 2008, at 10:38 AM, KITFOXZ(at)aol.com wrote:
| Quote: | Great Scot Lynn!, Genius! As many have said before, this list is a
--John
John-
Lynn Matteson
flying w/475+ hrs
> Guys,
> Columbus, Ohio
> Do Not Archive
AOL Living.
N369LM |
akflyer
Posted: Sun Feb 24, 2008 12:57 pm Post subject: Re: Of Test Pilots And Light Paint |
Guy Buchanan
San Diego, CA
Do not archive |
only built a couple hundred... I would lean towards super coverite, monokote gets too brittle in the cold. No nead to paint and rib stitching is optional if you use balsa rite.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Sun Feb 24, 2008 1:08 pm Post subject: Of Test Pilots And Light Paint |
Yup! But my favorite covering was Ultracote, not Money-Cote (as my
friends used to call it) The Ultracote seemed to stretch better in
all directions, unlike the Monokote...that I tried at least...which
seemed to stretch better in one direction than the other. My last
plane to cover was a still-unfinished (guess why?) Top Flite Giant
Scale Stinson Reliant SR- 9. Got everything built, and started to
cover with Stits Lite cloth, and was having so much fun with this
covering and shrinking deal that when it came time to do the 'fox, it
was a natural segue. I was amazed at how the fabric made the 3-
dimensional transition from the horizontal tail surface to the
vertical fin surface on the model. The same thing happened when I did
the same area on the Kitfox...that curve was pure sex!
Lynn Matteson
flying w/475+ hrs
On Feb 24, 2008, at 11:22 AM, Guy Buchanan wrote:
Monokote. Any model builders out there?
Guy Buchanan
San Diego, CA
N369LM |
Lynn Matteson
Posted: Sun Feb 24, 2008 1:36 pm Post subject: Of Test Pilots And Light Paint |
Do you remember Supershrink Coverite? It was a fabric that I covered
a Top Flite Gold Edition P-40 with...over the balsa sheeting. They
discontinued the Supershrink shortly after I finished that plane. I
still have the plane. It was flown for me twice...I was too chicken-
- - - to fly it myself at the time. It has a YS 120AC engine in it...
2.45 "supercharged" 4-stroke ponies in that bad boy....2-strokes
suck!...in my humble opinion, of course.
Lynn Matteson
flying w/475+ hrs
On Feb 24, 2008, at 3:57 PM, akflyer wrote:
> Guy Buchanan
> San Diego, CA
> K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar.
> Do not archive
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
http://forums.matronics.com/viewtopic.php?p=165983#165983
N369LM |
