jack.byrne(at)bigpond.com Guest
Posted: Thu Feb 21, 2008 10:31 pm Post subject: AUX BAttery Charging |
All.
I have a 4AMP/HR battery as an AUX battery for my EFIS.
I am charging it via the main bus.
Bus-5amp fuse-diode-aux bat. 18G wire
The Diode has the #'s 339 and IN5400 on it.
The 5 amp fuse blows!
How can I get around this. I am assuming the AUX bat is drawing a greater current if it gets depleted a resonable amount and this is blowing th fuse.
Do I need to increase the size of the wire and fuse?
What is the max AMPs that will be drawn by the AUX bat?
Chris Byrne
SYDNEY
mprather(at)spro.net Guest
Posted: Fri Feb 22, 2008 7:21 am Post subject: AUX BAttery Charging |
That sounds like a decent mix of components to get the job done. What's
the voltage on the aux battery?
The max amps will depend on the state of charge and the internal
resistance of the battery and the voltage drop across the diode. I would
have guessed that 5A would be plenty.
Is this diode a two-lead device (anode and cathode only - I see that it's
listed as a rectifier diode)? Do you only have two of the leads
connected?
I assume you have it wired like this:
main_bus --> 5A fuse --> diode --> +lead on aux battery
What model/brand/specs is the aux battery?
Matt-
All.
fuse.
Chris Byrne
SYDNEY
nuckolls.bob(at)cox.net Guest
Posted: Fri Feb 22, 2008 7:59 am Post subject: AUX BAttery Charging |
At 05:25 PM 2/22/2008 +1100, you wrote:
All.
Chris Byrne
SYDNEY
What you're experiencing is one of several reasons
I crafted the aux battery management module some
years ago. See:
http://www.aeroelectric.com/articles/bat_iso2.pdf
http://www.aeroelectric.com/Catalog/AEC/9005/9005-701B.pdf
The AEC9005 product has been discontinued and
will be replaced by a newer design. In the mean
time, there's no reason that folks can craft a
similar device themselves.
However, understand that it's real easy to get
wrapped around the "aux battery isolation" axle.
Whether your system has two or ten batteries
in the system, the generalized operating scenario
says for normal operations, ALL batteries can
be hard-connected to the charging system. By
"hard" I'm saying closed contacts of a switch
or relay.
When and if the low volts warning light comes
on, we now have the task of SEPARATING each
of the batteries into it's unique duties for
mitigating the effects of alternator failure.
The time that a pilot has to effect this
separation IS NOT a tense, borderline emergency
situation demanding millisecond response.
It's perfectly okay if battery isolation is
immediate and automatic by means of diodes
and/or aux battery management systems . . .
but if the pilot decided to finish a cup
of coffee or fold some maps before manually
opening the connection pathways that isolate
various batteries, the outcome of the flight
would not be measurably different.
The sum total of energy on the batteries
needs to be a known quantity, part of your
plan-B for dealing with alternator failure.
It's my fondest wish that everyone who reads
these words is PLANNING, DESIGNING, and
MAINTAINING their battery management philosophy
for HOURS of no-sweat, alternator failure-management
flight. This is diametrically opposed to the
FAA blessed notion of carrying a minimum of
30-minutes of EMERGENCY operation.
So, it's a perfectly okay thing if your aux battery
charging path were simply replaced with a switch
as opposed to the diode mentioned. It's also
perfectly okay that the aux battery charging
feeder be some kind of boss-hog conductor. Say
14AWG and 15A fuse. Now, keep in mind that there
are huge current sources at BOTH ends of this feeder
so BOTH ends should be fused if the feeders are
of significant length.
No doubt what you've observed is a demonstration
of the capability for even a very small battery
to ACCEPT charging currents at rates much higher
than the anticipated loads on the battery itself.
This is why I like to place ALL batteries close
together, tie them together in a cluster with
hard contacts and short, fat wires. This is why
you don't see any fuses or long feeders in the
Z-figures to wire multiple batteries.
When the various and sundry manufacturer's
of products recommend some itty-bitty "back
up" battery to support their customer's desire
to keep the product working, the dirty little
details of the physics for making seamless
installation the battery can start jumping
up to nibble at your heels.
If your airplane's electrical system will
benefit from multiple power sources over
and above the classic single-battery/single-
alternator architecture, first add the second
alternator if you can (Z-13/ . If a second
battery is your only viable option, then consider
a REAL battery sitting right next to the
MAIN battery and connected to the system
by a fat wire and hard switched contactor.
In your particular case, it may be that you're
too far down the path of adding an itty-bitty
backup battery to the system so consider
first upsizing the feeders and their protection
levels. If the wires either side of the diode
are relatively short, say 6-12" you can leave
the fuses out entirely. I'd upsize the diode
to one leg of a more robust device like:
http://www.aeroelectric.com/Pictures/Wiring_Technique/diode_wiring.jpg
Posted: Fri Feb 22, 2008 3:56 pm Post subject: AUX BAttery Charging |
Thanks to Bob, Matt and Max for your replies.
Bob the AUX Batt is just being used to power the EFIS during engine cranking. I lose the EFIS initialization and have to sit in the one spot for 2 mins after engine start for the GYRO's to align. It is also a last ditch power source for the SBY ADI (TRUTRACK) in case every thing turns to poo.
I have the Z13/8. One main batt and 35 AMP ALT and the B & C 8 AMP ALT.
I think I will try and optimise the setup I have. The wires to and from the diode are less than 12 inches. I had see your AUX BATT drawing but wanted to try and keep this as simple as possible, providing it works of course.
THanks again guys.
Chris Byrne
SYDNEY
Posted: Sun Feb 24, 2008 10:45 am Post subject: AUX BAttery Charging |
At 10:52 AM 2/23/2008 +1100, you wrote:
Then your concerns for supporting the ADI with
a second battery are overkill. 13/8 is exceedingly
unlikely to leave you with a dark panel.
| Quote: | I think I will try and optimise the setup I have. The wires to and from
course.
Then parallel a second, small battery with the main
battery a-la Z-35 . . .
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z35A.pdf
Power your protected electro-whizzies from
the Aux Battery Bus. Leave it's master switch
OFF until after the engine is started. The
S704-1 relay is only a 100 mA load and not
a major no-value-added load during alternator
out operations . . . which you're not going to
experience anyway with two alternators. Dump
the diode and fuse.
schaefer(at)rts-services. Guest
Posted: Sun Feb 24, 2008 1:44 pm Post subject: AUX BAttery Charging |
This is a function of the internal resistance of the battery.
A good battery will draw more current.
This is a bad idea to charge this in this manner.
It's OK to use this to maintain the battery. But if you use the battery you
should remove it and charge it on a regular charger and then re-install it
to the circuit.
