corey.crawford(at)gmail.c Guest
Posted: Mon Feb 18, 2008 4:35 pm Post subject: Z-19 and multiple busses |
Hello,
I'm looking to use the Z-19 drawings to create the electrical system to power my electrically-dependent Subaru engine and had a question:
Is there a reason I shouldn't go with a single engine bus that's fed by both batteries, with diodes to prevent a bad battery from sucking in all the juice?
The Z-19's show one bus per battery and then using a diode bridge for each component - this would move the diodes between the battery and the bus, instead of being placed between the bus(ses) and the individual components.
Comments?
Corey Crawford [quote][b]
nuckolls.bob(at)cox.net Guest
Posted: Mon Feb 18, 2008 5:35 pm Post subject: Z-19 and multiple busses |
At 05:26 PM 2/18/2008 -0700, you wrote:
| Quote: | Hello,
the juice?
Batteries don't go bad in ways that "suck juice".
I presume that since your airplane is decidedly
dependent on 100.0% availability of power, you'll
not only use modern, RG batteries . . . you'll make
at least some effort to see that they're discarded
for lack of capacity . . . which will happen long
before they don't crank the engine.
| Quote: | The Z-19's show one bus per battery and then using a diode bridge for each
The dual diodes are intended to isolate a battery
with higher state of charge from being tapped by
the equipment that has reduced the other battery
to a lower state of charge. It's not batteries that
are the energy thieves . . . it's stuff you have
turned on.
( -Thomas Paine 1776- )
Posted: Mon Feb 18, 2008 6:12 pm Post subject: Z-19 and multiple busses |
On Feb 18, 2008 6:32 PM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
| Quote: | The dual diodes are intended to isolate a battery
turned on.
I think I got it .. the diodes prevent the Main Battery from being used by components on the Engine Bus and vise versa. If the two busses would feed the exact same components, is there any reason to separate them? The only thing I'd lose is not being able to isolate a battery, or am I missing something? (I'm not sure being able to isolate a single battery is very helpful in this scenario - the whole engine can be isolated with the dc power switch if needed).
Thanks!
Posted: Mon Feb 18, 2008 8:04 pm Post subject: Z-19 and multiple busses |
At 07:09 PM 2/18/2008 -0700, you wrote:
| Quote: | On Feb 18, 2008 6:32 PM, Robert L. Nuckolls, III
> turned on.
I'm not sure about your desire to "isolate a
battery". When the alternator quits, the
energy available is finite and contained totally
within the battery(ies).
When the low volts warning light comes on, wiring
per Z-19 requires no action on the part of the
pilot except to close the endurance bus alternate
feed switch and open both battery master switches.
Then make preparations for a no-alternator
en-route phase of flight followed by approach to
comfortable landing. Once your comfortable landing
is assured (short final over the numbers) close
the master relays and run as much "stuff" as you
like to complete the flight.
Normal operations are with the primary engine
power switch ON and the secondary switch off.
Assuming you've done your homework and have
a considered preventative maintenance program
for batteries, then you KNOW how long you
can operate battery only in the endurance
mode. If you have not done your homework and
find that the engine is not running well for
as long as you anticipated, you may have
to close the secondary power switch to allow
the main battery to support the engine. If
the engine battery's lack of capacity proves
to be a surprise, then the main battery's true
condition is probably a mystery too . . . it's
time to call it an emergency.
The design goal is to minimize in-flight
diagnostics, switch flipping and other
distractions that prevent you from doing
your best as a pilot. With a modicum of
planning it's a no-sweat deal.
Posted: Tue Feb 19, 2008 8:06 am Post subject: Z-19 and multiple busses |
Thanks for setting me straight. I was under the impression that normal operation would see both engine power switches on.
- Corey
On Feb 18, 2008 9:00 PM, Robert L. Nuckolls, III <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
| Quote: | > with higher state of charge from being tapped by
| Quote: | > turned on.
| Quote: | thing I'd lose is not being able to isolate a battery, or am I missing
| Quote: | power switch if needed).
longg(at)pjm.com Guest
Bob, if I "open both battery master switches" which carry my EFI, ECU
and primary fuel pump, my engine will go putt-putt and die. On the other
hand closing the #2 fuel pump switch will provide power to the #2 fuel
pump from the main bus for my non-running engine. I'm sure you were
referring to a standard aircraft engine and not an electrically
dependent one. For Z-19 to be effective, the EFI/ECU/FP require at least
1 live feed. That source is not provided on the e-bus.
Posted: Tue Feb 19, 2008 8:46 am Post subject: Z-19 and multiple busses |
At 11:02 AM 2/19/2008 -0500, you wrote:
Your electrically dependent engine accessories should
run from always hot battery busses as illustrated in
Z-19 and recommended for ALL the Z-figures. If you've
got bad smells in the cockpit you should be able to
open all the battery switches and kill the alternator
and NOT have the engine stop.
Posted: Tue Feb 19, 2008 8:47 am Post subject: Z-19 and multiple busses |
At 09:01 AM 2/19/2008 -0700, you wrote:
| Quote: | Thanks for setting me straight. I was under the impression that normal
The system would "function" with both switches ON. But
the purpose for batteries is to have TWO, KNOWN sources
of stored energy, one for the engine, one for other stuff.
If you do your homework, you never have to close the second
engine power switch except during a pre-flight test.
