chenoweth(at)gwi.net Guest
Posted: Mon Feb 11, 2008 11:58 am Post subject: weight |
I have a friend coming to visit who is an aviation enthusiast and we're talking about my giving him a ride in my IV-1200. The kicker is that he's 5'10" and admits to weighing 260. This would be the biggest/heaviest passenger I've carried by at least 50 pounds and wonder if anyone has had a similar experience. We would definitely not be over-gross but I wonder about seat integrity and control freedom.
wannafly
Posted: Mon Feb 11, 2008 12:17 pm Post subject: weight |
Take the right side stick off and fly with doors open and you won't have a problem.
| Quote: | From: chenoweth(at)gwi.net
Subject: Kitfox-List: weight
Date: Mon, 11 Feb 2008 13:24:04 -0500
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
p://forums.matronics.com
blank>http://www.matronics.com/contribution
| [quote][b]
Michel
Posted: Mon Feb 11, 2008 12:35 pm Post subject: weight |
| Quote: | From: Chenoweth [chenoweth(at)gwi.net]
control freedom.
Bill, the only thing I experience with heavy passenger and a hard langing in my model 3 is that the passenger's door pops open. Nothing to worry about but I usually warn all passenger that it may happen.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
kerrjohna(at)comcast.net Guest
Posted: Mon Feb 11, 2008 1:15 pm Post subject: weight |
the question will be the size of his thighs;-)
[quote]-------------- Original message --------------
Guy Buchanan
Posted: Mon Feb 11, 2008 1:50 pm Post subject: weight |
At 10:24 AM 2/11/2008, you wrote:
| Quote: | | We would definitely not be over-gross but I wonder about seat integrity and control freedom. |
When I checked out in Lowell's IV-1200 I weighed about 195 and the instructor weighed close to 250. We were so tight it was comical, but nobody seemed to think it was a problem, and it wasn't.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
rdmac(at)swbell.net Guest
Posted: Mon Feb 11, 2008 3:07 pm Post subject: weight |
Be ready to add a little power on short final, your sink rate will be a little bit higher. I had someone who was 6’2” and 250 lbs. and I notice a difference.
Roger McConnell, Duncan, OK
Model 7 Trigear, Rotax 912uls
Flying sense Jan. 06
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Chenoweth
Sent: Monday, February 11, 2008 12:24 PM
Subject: weight
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Posted: Mon Feb 11, 2008 4:10 pm Post subject: weight |
Mic,
Not sure where you are but here it's winter. Like teens and low twenties. But the idea does sound like "fun".
Posted: Mon Feb 11, 2008 4:13 pm Post subject: weight |
Guy,
Very reassuring and thanks very much for the info.
Posted: Mon Feb 11, 2008 4:16 pm Post subject: weight |
Michel,
Good point - I had a similar experience with a smaller but still substantial
passenger a few months ago and after the third or fourth hard landing his
door did pop. As Roger pointed out one needs to accommodate the higher sink
rate and it took me a few tries to get it right.
Posted: Mon Feb 11, 2008 4:18 pm Post subject: weight |
John,
That comment has led me off on a whimsical train of thought about some of my large female passengers. Now that I've stopped laughing I want to thank you for the humor.
Float Flyr
Posted: Mon Feb 11, 2008 4:35 pm Post subject: weight |
Just wondering why you say to take the doors off.. I have been in my plane (Model III-A actual Mod II) with myself at close to 250 and another pilot at close to 200 lb. We didn’t fly because we just couldn’t develop enough horsepower ( faulty tach) to get up on step. The With the fuel on board we were around 1050 lb. Which I would probably have done some flight in ground effect. What I’m trying to get at is there was plenty of room with the doors on and both sticks installed. In fact there was more room than in the Stinson 108 I tried to fly.... The yoke in that plane was situated in such a way it would require me to take the door off to give me enough elbow room.
The most room I’ve seen in any plane including the Boeing 737 was the Super Cub.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of mic thiessen
Sent: Monday, February 11, 2008 4:43 PM
Subject: RE: weight
Subject: weight
| Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-Listp://forums.matronics.comblank>http://www.matronics.com/contribution |
0123456789 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 0 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 1 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 2 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 3 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 4 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 5
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Mon Feb 11, 2008 4:39 pm Post subject: weight |
Do you suppose that John McBean still sells the double-pin door latch
kits? I've got 'em on my Speedster, plus the bottom latch...three
points of contact with the door jambs, and the double-pins are almost
foolproof. I doubt that the door would EVER come open short of
wadding up the fuselage.
Also, I've had a 250-pounder in my plane with full tanks (156 lbs),
and at that point we were about 15 lbs over gross...did I just admit
to a violation of the rules? Damn, somebody must be sneaking in here
again and playing with my computer.
Lynn Matteson
flying w/470+ hrs
On Feb 11, 2008, at 7:14 PM, Chenoweth wrote:
Michel,
substantial passenger a few months ago and after the third or
fourth hard landing his door did pop. As Roger pointed out one
needs to accommodate the higher sink rate and it took me a few
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
thesupe(at)hotmail.com Guest
Posted: Mon Feb 11, 2008 7:37 pm Post subject: weight |
Just kidding of course, but I thought, if it really wan't working out; with the door open, no stick, you could drop the right wing, unbuckle him quick while kicking full left rudder, and be back to normal real quick, Jim Chuk
do not archive (or take seriously)
| Quote: | From: noelloveys(at)yahoo.ca
Subject: RE: weight
Date: Mon, 11 Feb 2008 18:05:05 -0330
.ExternalClass .EC_shape {;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_span.HTMLPreformattedChar {font-family:Consolas;} .ExternalClass EC_span.EmailStyle20 {font-family:'Times New Roman','serif';color:windowtext;font-weight:normal;font-style:normal;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
Noel
Subject: RE: Kitfox-List: weight
Subject: weight
| Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 6 | Climb to the top of the charts! Play the word scramble challenge with star power. Play now! [quote][b]
Float Flyr
Posted: Tue Feb 12, 2008 6:34 am Post subject: weight |
Don't feel too bad Lynn.
When I was a kid I flew all over Newfoundland with my father in a C170B on
floats. Most of the time we were salmon fishing and the old bird, CF-HIM,
was half decent at getting us in (and out) of some nice ponds, close to the
type of pools that dreams are made of. Of course we took everything we
needed to survive for about fifty years (exaggeration...maybe) The running
joke around the hangar is the normal takeoff weight for our plane was about
a hundred pounds or so overweight. For years I thought it was normal to
have the last compartment of both floats submerged when slow taxiing.
Noel
Kitfox III-A
Float Flyr
Posted: Tue Feb 12, 2008 6:44 am Post subject: weight |
When I was in the Stinson I was thinking about a bubble door with enough room to get my elbow into the bubble. J BTW the same plane with a stick would have had thousands of room. It was just that the yoke takes up so much room and was close to the door. The guy who owned the plane is around 5’6” and when he flared he had to wrap his arm around the yoke to give himself enough room to pull it fully back. I’m 5’11” with 39” arms... 30” legs... should have made a good football player... low CG J.
I was in the right seat and I’m left handed... using the yoke left handed wasn’t a problem except I couldn’t handle the yoke and throttle at the same time. The next plane I flew was a Super Cub... Loved it... Much like the Kitfox with a growl. It did take a bit of getting used to using the stick with my right (wrong) hand. By the third landing I had it down pretty well. One of the amazing things about the Super Cub is the amount of space in the cockpit. The left seat in a 737 has much less room and is actually harder to get in and out of.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Jim_and_Lucy Chuk
Sent: Tuesday, February 12, 2008 12:05 AM
Subject: RE: weight
Subject: RE: weight
Noel
Subject: RE: weight
Subject: weight
| Quote: | | http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.com | 01
234567
Climb to the top of the charts! Play the word scramble challenge with star power. Play now! 89 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 0 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 1 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 2 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 3 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 4 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 5 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 6 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 7 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 8 | Quote: | | arget=_blank>http://www.matronics.com/Navigator?Kitfox-List | 9 | Quote: | | p://forums.matronics.com | 0 | Quote: | | p://forums.matronics.com | 1 | Quote: | | p://forums.matronics.com | 2 | Quote: | | p://forums.matronics.com | 3 | Quote: | | p://forums.matronics.com | 4 | Quote: | | p://forums.matronics.com | 5 | Quote: | | p://forums.matronics.com | 6 | Quote: | | p://forums.matronics.com | 7
Kitfox III-A
patreilly43(at)hotmail.co Guest
Posted: Tue Feb 12, 2008 9:41 am Post subject: weight |
Lynn, Are there any photo's or drawings of the "double pin" latch?
Pat Reilly
Mod 3 Rebuild
Rockford, IL
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: weight
Date: Mon, 11 Feb 2008 19:37:29 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
flying w/470+ hrs
> --> Kitfox-List message posted by: "Chenoweth" <chenoweth(at)gwi.net>
> Michel,
> tries to get it r========
Lynn Matteson
Posted: Tue Feb 12, 2008 11:16 am Post subject: weight |
Here are two shots that I have, Pat. The kit that I had required
several parts to be made from stock that was furnished. Instructions
came with the kit as supplied in 1994.
Above: This is the bellcrank that transmits the center, turning
motion into fore-and-aft rods that engage pins into sockets in the
fuselage.
Above: On the left is the fuselage socket (fastened with 4 SS
rivets), with the pin engaged, and on the right is the guide
(fastened with 5 SS rivets)
and the actuating rod. I hope this makes sense. It's hard to get the
overall picture of how it works because I zoomed in a little too
close when I shot it.
Lynn Matteson
flying w/470+ hrs
On Feb 12, 2008, at 12:38 PM, patrick reilly wrote:
| Quote: | Lynn, Are there any photo's or drawings of the "double pin" latch?
Pat Reilly
Mod 3 Rebuild
Rockford, IL
100.76 KB |
525 Time(s) |
110.92 KB |
523 Time(s) |
N369LM |
n85ae
Posted: Tue Feb 12, 2008 1:01 pm Post subject: Re: weight |
Not to be a critic, but riveting into the airframe tubing isn't really a good
idea, nor necessary since you already have the tab there.
Jeff
Posted: Tue Feb 12, 2008 1:07 pm Post subject: weight |
Lynn, I can't wait to meet you, maybe at Oshkosh. I can't believe you have pictures of the door latch system back to me immediately. I have found the Kitfox "Mother Lode" on this website and sent my contribution to Matt last week. With the info you "experts" have that is available to us beginners, I ought to make it a monthly contribution.
Pat Reilly
Mod 3 rebuild
Rockford, IL
Subject: Re: Kitfox-List: weight
Date: Tue, 12 Feb 2008 14:11:59 -0500
pulsair(at)mindspring.com Guest
Posted: Tue Feb 12, 2008 2:42 pm Post subject: weight |
Lynn,
That is the best latching system I have ever seen! I wonder why they did
away with it? Jeff CMH Classic IV
