tjs22t(at)verizon.net Guest
Posted: Wed Feb 13, 2008 8:51 am Post subject: Rudder cable tension for HD/HDS |
[quote] I am building a 601HD and do not recall any cable tension called out.
+++ The older Construction Manual received with the HD/HDS kits (or plans) lists 30 pounds. Check around page 29 if memory serves - but it's the first to go.
*** Just checked, yep, on page 29 with the info on the control surface deflection is a note that cable tension "between 30 to 40 pounds." In the archives you will find a few mentions that both Nick and Chris say 25 to 30 pounds. That's from others, I never heard from either but then I never asked.
Dave A.'s comment to tension them with nose wheel off ground (presuming tri-gear) is good, do that here.
do not archive jeff
Jeyoung65(at)aol.com Guest
Posted: Wed Feb 13, 2008 1:46 pm Post subject: Rudder cable tension for HD/HDS |
Thanks Jeff, I did miss it and had too look twice to find it. Jerry of Ga. Do not archive
In a message dated 2/13/2008 11:53:23 A.M. Eastern Standard Time, tjs22t(at)verizon.net writes:
| Quote: | I am building a 601HD and do not recall any cable tension called out.
do not archive jeff
f="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
The year's hottest artists on the red carpet at the Grammy Awards. AOL Music takes you there.
