n1cxo320(at)salidaco.com Guest
Posted: Tue Feb 12, 2008 7:21 pm Post subject: Spring Scale Source? |
I just completed the nose gear modification on my RV6A and used a cobbled-up method of checking and setting the 'break out' force as called for by Van. (22-lbs)
I would like to find a source for a push scale, likely a spring scale, to more accurately measure the break out force to insure against any shimmy or other problems. I flew once after the mod and had the force way too light and got good shimmy. I've re-adjusted it but am still a bit leery.
Any sources you know of? I checked the usual ones and came up dry.
Thanks for any pointers.
Posted: Tue Feb 12, 2008 8:19 pm Post subject: Spring Scale Source? |
Almost any fish scale will work. Look in your local big-box store.
Linn
John Fasching wrote:
[quote] I just completed the nose gear modification on my RV6A and used a cobbled-up method of checking and setting the 'break out' force as called for by Van. (22-lbs)
hooverra(at)verizon.net Guest
Posted: Wed Feb 13, 2008 3:52 am Post subject: Spring Scale Source? |
McMaster Carr http://tinyurl.com/x39j
50 lbs. 8 oz. 25 kg 250 g 12" x 1 5/16"
1757T39 <javascript:TargetLink('TR308','tr','PT3081','1757T39');> 43.75
Ralph C. Hoover
RV7A
hooverra at verizon dot net
