hotwheels
Posted: Thu Feb 07, 2008 9:59 am Post subject: AC 43.13 - Where did it go? |
I wasn't able to find the AC 43.13 (ACCEPTABLE METHODS, TECHNIQUES, AND PRACTICESAIRCRAFT INSPECTION AND REPAIR) anywhere at the FAA website. Maybe I didn't type in the right search parameters?
http://www.airweb.faa.gov/
I did read over the AEC11 file AC43.13-1B_Change1.pdf. Is this version still in process of review? If so, what's the timeframe?
Jay
mprather(at)spro.net Guest
Posted: Thu Feb 07, 2008 11:08 am Post subject: AC 43.13 - Where did it go? |
I googled "AC 43.13" and came up with the following link (which seems
usable):
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99C827DB9BAAC81B86256B4500596C4E?OpenDocument
or:
http://tinyurl.com/ynopgy
Also found from http://www.faa.gov/ go to "Regulations and Policies" then
"All other ACs" then entered 43.13 into the search. The first hit is
essentially the same link as above.
Matt-
Jay
http://forums.matronics.com/viewtopic.php?p=162842#162842
stinsonwagon(at)yahoo.com Guest
Posted: Thu Feb 07, 2008 11:12 am Post subject: AC 43.13 - Where did it go? |
Jay,
You're right it's not list in the current section,
but I found it in the history section.
Good luck,
--- jayb <jaybrinkmeyer(at)yahoo.com> wrote:
Jay
Looking for last minute shopping deals?
nuckolls.bob(at)cox.net Guest
Posted: Thu Feb 07, 2008 7:26 pm Post subject: AC 43.13 - Where did it go? |
At 09:59 AM 2/7/2008 -0800, you wrote:
Goto
http://www.aeroelectric.com/Reference_Docs/FAA/
for a number of FAA documents including AC43.13
in it's entirety, an excerpt of electrical section
only and the Change 1 revision pages.
jmcburney(at)pobox.com Guest
Posted: Fri Feb 08, 2008 6:40 am Post subject: AC 43.13 - Where did it go? |
Greetings, all,
Go to FAA.GOV, find the link to "Advisory Circulars", use the search engine
for AC 43.13-1B. Copy it exactly the way it is here. Caution if you're on
dial-up -- it's BIG. You get the entire file on .pdf, so you need Adobe
reader.
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
