dwight purdy
Posted: Mon Feb 11, 2008 4:48 pm Post subject: Serial numbers |
Would someone please tell me if any of the airframes were marked with a
serial number, in particular the model IV. Where would it be?
Dwight Purdy
model II
dwight
_________________ dwight
model II |
darinh
Posted: Mon Feb 11, 2008 4:53 pm Post subject: Re: Serial numbers |
My Series 7 is stamped on the right side upper seat belt tab. Don't know for sure where they stamped the IV but I would assume they did.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
kitfoxpilot(at)msn.com Guest
Posted: Mon Feb 11, 2008 5:38 pm Post subject: Serial numbers |
I have a IV, and never found any stamps on the airframe!
[quote] Subject: Re: Serial numbers
Date: Mon, 11 Feb 2008 16:53:40 -0800
--> Kitfox-List message posted by: "darinh" <gerns25(at)netscape.net>
Darin Hawkes
Series 7 (under Construction)
914 Turbo
Kaysville, Utah
http://forums.matronics.com/viewtopic.php?p=163604#163604
_-==============================================
Need to know the score, the latest news, or you need your HotmailŪ-get your "fix". Check it out.
dwight purdy
Posted: Mon Feb 11, 2008 6:30 pm Post subject: Re: Serial numbers |
I have a model IV kit that I bought from the original purchaser. The invoice was folded and the number was in the fold and the carbon paper was turned blue. It was bought from Skystar in 1996. Supposed to be a model IV Speedster except he wanted the full wing. Can I tell if it is a 1200 gross by the diameter of the struts ? Maybe the length(height) of the tail post would be better.
My wife says one of my toys need to go and I would like to know for sure what I will be advertising.
model II |
dan(at)azshowersolutions. Guest
Posted: Mon Feb 11, 2008 6:49 pm Post subject: Serial numbers |
roncarolnikko(at)hotmail. Guest
Posted: Mon Feb 11, 2008 6:54 pm Post subject: Serial numbers |
My 92 speedster is on a tab behind the seat. I believe it is on the center of the first upper cross tube behind the flaperons. GBSO33 G=7th month B=92 S=Speedster This was the transition time to Skystar and they soon changed the format of the serial number. Ron NB Ore
| Quote: | From: kitfoxpilot(at)msn.com
Subject: RE: Re: Serial numbers
Date: Tue, 12 Feb 2008 01:36:05 +0000
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;} I have a IV, and never found any stamps on the airframe!
| Quote: | Subject: Re: Serial numbers
Darin Hawkes
914 Turbo
Kaysville, Utah
Need to know the score, the latest news, or you need your HotmailŪ-get your "fix". Check it out. | Quote: |
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
| Connect and share in new ways with Windows Live. Get it now! [quote][b]
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Feb 11, 2008 6:57 pm Post subject: Re: Serial numbers |
Dwight, My 1994 Classic 4 is a 1200 Gross airframe. Tail post is 53 and 1/4 inches near as I can measure on the trailer with the wings folded. Wing struts are one inch OD. serial number is on the rear of the triangular plate that the front of the Horizontal stab attaches to.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
dwight purdy
Posted: Mon Feb 11, 2008 7:26 pm Post subject: Serial numbers |
Now that is what I call service. Thanks for all of the replies.
Dwight
model II
At 06:57 PM 2/11/2008 -0800, you wrote:
Tom Jones
Classic IV, Phase one
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=163625#163625
5:28 PM
model II |
Lynn Matteson
Posted: Mon Feb 11, 2008 8:47 pm Post subject: Serial numbers |
Mine is on the tab that the inner shoulder harnesses bolt to. It is
triangular in shape. My understanding of the alpha-numeric sequence
is: 1st digit =month; 2nd digit=year, with 1991 being '1', 1992 being
'2', etc.; don't know what the 3rd digit is but mine is a Speedster,
and the designation on mine is "U", followed by 150, which I was led
to believe (by Frank Miller, for whatever that's worth) was the
number of units built that year.
Lynn Matteson
flying w/470+ hrs
On Feb 11, 2008, at 9:51 PM, ron schick wrote:
| Quote: | My 92 speedster is on a tab behind the seat. I believe it is on
number. Ron NB Ore
> From: gerns25(at)netscape.net
> To: kitfox-list(at)matronics.com
they did.
> Darin Hawkes
> 914 Turbo
> Kaysville, Utah
get your "fix". Check it out.arget=_blank>http://www.matronics.com/
Navigator?Kitfox-Listp://forums.matronics.comblank>http://
Connect and share in new ways with Windows Live. Get it now!_-
============================================================ _-
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Mon Feb 11, 2008 8:48 pm Post subject: Serial numbers |
Center shoulder harness tab...look hard, it'll probably be nearly
filled in with powdercoat.
Lynn Matteson
flying w/470+ hrs
On Feb 11, 2008, at 8:36 PM, RAY Gignac wrote:
| Quote: | I have a IV, and never found any stamps on the airframe!
they did.
> Darin Hawkes
> 914 Turbo
> Kaysville, Utah
get your "fix". Check it out._-
contribution_-
N369LM |
