kbob(at)cox.net Guest
Posted: Sat Feb 09, 2008 2:59 pm Post subject: Nose Gear spacer tip |
I also built a spacer about a year ago at annual. This year at annual the
wheel bearings had play in them when torqued down tight. It appears the
bearings have worn a touch and now it's loose. I trimmed the spacer and few
thousands and all is well. Keep this in mind if you build a spacer then fly
a bunch.
Kelly Patterson N716K
RV-6A PHX, AZ ~200 hours
Subject: Nose wheel axle torque
On the 6A my son Eric & I are completing, we chose to put a spacer between
the inner races of the tapered roller bearings. This permits the axle nut
to
be fully tightened without overloading the bearings.
Having a metal lathe in our shop made it simple to trim the spacer to
exactly the right length. If you have easy access to a lathe, it is a
worthwhile improvement.
Paul s. Petersen, Minnetonka MN
