dav1111(at)erfwireless.ne Guest
Posted: Fri Feb 08, 2008 3:52 am Post subject: magnetometer location |
I would recommend that you put the magnetometer in the wingtip. Make a 90 degree bracket and rivet the bracket to the outboard rib. In stall one pop rivet in either the front or back of the bracket so that you can rotate the bracket on one end up or down to get the bracket leveled with the in flight position of the wing. Check the bottom of the cabin door with a level and then just level the bracket to the same bubble or degree as the bottom of the cabin door and then put in the rest of the mounting rivets and bolt on the magnetometer (non steel bolts).
Russ Daves
N710RV - 190+ hours
tomhanaway
Posted: Fri Feb 08, 2008 4:51 am Post subject: Re: magnetometer location |
Russ,
Have you had any issues with proximity of wingtip strobes to magnetometer in this installation?
tom
Tim Olson
Posted: Fri Feb 08, 2008 6:18 am Post subject: magnetometer location |
I'd agree with Russ. There are a couple good locations for
magnetometers, and I'd recommend those instead of in the cabin.
A good magnetometer is very sensitive, and it wouldn't take
much in the way of portable electronic gadgets, and
passenger wearables to throw some nasty heading effects into
the equation. Even more important than using non-magnetic
screws, and things like that, is that you want it to be a
fairly magnetically constant area, where there aren't lots of
variables happening, because the constants you can somewhat
calibrate for. The variability brought into the equation
by passengers and cabin items would be almost impossible
to predict.
Russell Daves wrote:
Quote: | I would recommend that you put the magnetometer in the wingtip. Make a
Russ Daves
N710RV - 190+ hours
Posted: Fri Feb 08, 2008 6:59 am Post subject: magnetometer location |
I've never seen the inside of magnetometer, but is the the fact that there might be a lot of vibration at the end of the wing any concern for longevity of the unit. Should it be mounted on foam pads?
JOhn 409
Posted: Sat Feb 09, 2008 3:15 am Post subject: magnetometer location |
No problem.
Russ
