jeynon2
Joined: 25 Oct 2007 Posts: 24 Location: Southern Illinois
Posted: Mon Feb 04, 2008 9:17 am Post subject: Gear legs - flipside |
First off, I would like to say a heartfelt thank you to everyone participating on this forum. You are an invaluable resource to the lone builder (cue: coyote howling in distance).
With a satisfied sigh of relief, my gear legs have slipped into their respective tubes. I'm now at the - fit gear legs into axle weldments until they bottom out - step. Here the difficulty seems to be that the taper on the gear leg begins about 1/2" before the leg bottoms. I don't think sanding is going to fix this one.
So now my question is: Machine shop?, Don't worry about bottoming?, Some other insightful solution I haven't thought of?
Thanks again.
John Eynon
Lightning #53
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
reames(at)frontiernet.net Guest
Posted: Mon Feb 04, 2008 10:47 am Post subject: Gear legs - flipside |
This is from experience, first step, make sure that there is no ring of
paint around the inside start of the taper socket of the axel weldment.
BA
sttwig(at)wabroadband.com Guest
Posted: Mon Feb 04, 2008 10:49 am Post subject: Gear legs - flipside |
John,
I have the same observation with the bottom of the gear legs. I thought
there was two ways to interpret the "bottom out" statement. One is to
make sure they actually hit the bottom of the weldment socket and the
other is to just make sure they were in as far as they would go. Right or
wrong I chose to go the latter after spending considerable time sanding
and not making any head way. The same was true for the bottom end of the
nose gear.
Steve
Kit #48
Thanks again.
John Eynon
Lightning #53
http://forums.matronics.com/viewtopic.php?p=162337#162337
jeynon2
Posted: Mon Feb 04, 2008 10:53 am Post subject: Re: Gear legs - flipside |
Just wanted to correct my last post. The bottom of the gear legs are not as far off as I thought. With a good night's sleep and fresh sanding muscles, the wheel side of the gear legs are sand-able. I've sanded. They're sanded. They've bottomed. I'm good. My baby's going to walk.
John Eynon
Lightning #53
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
