Colin K.
Posted: Wed Jan 30, 2008 6:52 pm Post subject: Builders - Inboard Aileron Hinge |
Section 16 Wing Final Assembly and Installation says:
"5. With the aileron attached, place the aileron at full up deflection, this is measured at the tip and must be 3.5 inches."
So there is the up range. What's the down range?
Colin K.
OK
http://www.mykitlog.com/cojaken
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
_________________ Colin K.
OK |
Colin K.
Posted: Wed Jan 30, 2008 7:20 pm Post subject: Builders - Inboard Aileron Hinge |
Section 13 of the manual says:
"Clamp the hinge bracket in place and move the aileron through its operating range."
My question is, what is the operating range? Degrees up and down or trailing edge inches up and down, without contacting the wing? The neutral point being where the aileron trailing edge is aligned with the flap trailing edge.
Colin K.
OK
OK |
vettin74(at)yahoo.com Guest
Posted: Thu Jan 31, 2008 5:59 am Post subject: Builders - Inboard Aileron Hinge |
Aileron neutral point is the flap than move about 3.5" up and about 2" down and check clearances...
nick
"Colin J. Kennedy" <cjk129(at)cox.net> wrote:
[quote] Section 13 of the manual says:
My question is, what is the operating range? Degrees up and down or [quote][b]
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
