Firewall penetration
ericparlow(at)hotmail.com
PostPosted: Wed Jan 30, 2008 11:39 am    Post subject: Firewall penetration Reply with quote
Subject: RE: AeroElectric-List: Firewall penetration
Date: Wed, 30 Jan 2008 10:00:56 -0500
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;} We used a similar fitting but it has a barbed extension to clamp flexible conduit over it.
$2.50 ea from Lowes Aviation dept.
See photos attached
We used 4 of theses on our RV-10 mounted in the firewall center recess.
The wires pass thru the bulkhead fitting with a connector on either side.
The wires are wrapped in fire sleeve and potted with sealant similar to the SafeAir design.
After the pass-thrus are in the firewall the FWF side connectors are mounted on to the back side of a SS plate which covers the recess.
Eric Parlow
RV-10, 40014
N104EP
Date: Tue, 29 Jan 2008 10:10:07 -0600
Subject: Re: AeroElectric-List: Firewall penetration
I saw a clever use of EMT tubing set screw connectors (ie steel electrical
conduit tubing). You can see a picture here (search for 'set-screw'):
http://www.alliedtube.com/electrical-raceways/conduit/emt-connectors-couplings.asp
 Filesize:  34.86 KB
 Viewed:  380 Time(s)
 Filesize:  26.04 KB
 Viewed:  380 Time(s)
 Filesize:  30.56 KB
 Viewed:  380 Time(s)
 Filesize:  23.63 KB
 Viewed:  364 Time(s)
 Filesize:  27.75 KB
 Viewed:  369 Time(s)
