Gig Giacona
Posted: Tue Jan 29, 2008 6:17 am Post subject: Are Copper Nico Sleeves OK? |
I ordered some extra Nico sleeves from ACS and instead of the zinc plated ones they sent copper sleeves.
Are these an acceptable replacement or do I need to send these back?
601XL Under Construction
cookwithgas
Posted: Tue Jan 29, 2008 6:47 am Post subject: Re: Are Copper Nico Sleeves OK? |
Hey Gig:
If I remember correctly you want to use the zinc-plated sleeves with stainless steel cable. With galvanized cable, the copper sleeves are fine. I remember reading this in the Aircraft Spruce catalog a while back - you might want to call them and make sure. 877-477-7823
I hope this helps.
Scott Laughlin
www.cooknwithgas.com
601XL/Corvair Finished & Flying
klr12(at)psu.edu Guest
Posted: Tue Jan 29, 2008 7:21 am Post subject: Are Copper Nico Sleeves OK? |
Gig,
Plated sleeves (Tin Or Zinc) are required on stainless cables due to
electrolysis caused by different types of metals.
Plain copper is used on galvanized cable.
Kevin Rupert
601XL TD/ Corvair
Gig Giacona
Posted: Tue Jan 29, 2008 7:33 am Post subject: Re: Are Copper Nico Sleeves OK? |
Thanks guys. Back to ACS they go.
Posted: Tue Jan 29, 2008 8:23 am Post subject: Are Copper Nico Sleeves OK? |
Gig,
From that, I take it you are using Stainless Steel cable. You might
find this interesting:
| Quote: | General aviation aircraft generally use control cable made from either
stainless steel or galvanized steel. Each type has its advantages and
disadvantages. Generally,
Galvanized rope is stronger
Galvanized rope has less wear
Galvanized rope is easier to inspect for corrosion damage
Stainless steel is more corrosion resistant
Stainless steel has considerably less service life due to high wear
Stainless steel cannot be inspected for corrosion damag
The poor wear resistance of stainless steel rope has resulted in
aircraft control problems. More frequent inspections are required. For
more information on this subject reference: Special Airworthiness
Information Bulletin: SAIB CE-01-30, July 11, 2001. Frayed stainless
steel control cable is suspect in a Twin Otter crash killing 14
passangers in Tahiti in August of 2007.
There are several reasons why stainless wears more than galvanized
steel when used on flight controls:
Galvanizing is a natural lubricant. For example, galvanized threads
have a lower friction (K) factor then plain steel. The individual
wires can easily move about with very little friction and wear.
Stainless steel on the other hand has high friction and has a
reputation for seizing and galling when rubbed together. Every time
the wire rope is flexed, the stainless wires rub together. High
friction creates high wear.
Wear resistance can be increased by changing how the wire stands are
wound. In the picture above the individual wires are horizontal
(parallel to the axis of the rope). This is called "right regular lay"
and is the standard lay.
Another method of winding the wire stands is so that they form an
angle to the axis of the rope. This is called "lang lay". Lang lay
increases fatigue strength and abrasion resistance without any
decrease in ultimate strength.
Another method of changing the wire characteristics of fatigue
strength,. abrasion resistance, and flexibility is to use wires of
different diameters. For example, Douglas Specification DMS2192 calls
for a Warrington Seal (IWRC) construction. This type of wire rope has
larger wires on the outside and and smaller wires on the inside.
There are other wire rope designs that the engineer can call for to
optimize specific performance goals. This is why when we replace wire
rope we should make sure that the replacement meets the original
manufacturer's specifications.
Kevin Rupert
601XL TD/ Corvair
victorbravo(at)sbcglobal. Guest
Posted: Tue Jan 29, 2008 8:41 am Post subject: Are Copper Nico Sleeves OK? |
Copper color Nico sleeves are completely acceptable... they're the
original ones that were used on certified airplanes for a million years.
They eventually offered zinc plated ones for better corrosion
resistance. If you get silver looking ones all you have to do is make
sure they are copper underneath... and not aluminum, which I believe is
NOT OK.
Put a piece of heat shrink tubing over the cable before you do the
Nicopress process, and when you're done slide the heatshrink back onto
thesplice to cover the cut end of the cable and shrink it. This prevents
the cut end from unraveling into sharp little injury machines later.
Posted: Tue Jan 29, 2008 9:24 am Post subject: Are Copper Nico Sleeves OK? |
I have to take back some of what I wrote here... I forgot to mention the
stainless and galvanized issue. However I do know that the standard
copper Nico sleeves are used on tens of thousands of certified
airplanes, and those planes include ones with galvanized and ones with
stainless cables.
Bottom line (despite what I wrote here and previously) use whichever one
does not create a corrosion problem with your cables.
Bill Berle wrote:
years. They eventually offered zinc plated ones for better corrosion
is NOT OK.
prevents the cut end from unraveling into sharp little injury machines
later.
Gig Giacona wrote:
> <wr.giacona(at)suddenlink.net>
> W.R. "Gig" Giacona
> http://forums.matronics.com/viewtopic.php?p=161051#161051
Gig Giacona
Posted: Tue Jan 29, 2008 9:52 am Post subject: Re: Are Copper Nico Sleeves OK? |
Oops. Never mind. For some reason I was thinking the cables that came from Zenith were SS. My buddy Jay B set me straight, as he often does.
bobefx(at)yahoo.com Guest
Posted: Tue Jan 29, 2008 11:18 am Post subject: Are Copper Nico Sleeves OK? |
The zink plated sleeves are copper. They can be use interchangeably. I work in the motion pix biz and we use them on galvinized, stainless steel, and all types of cable. aircraft, crain, etc.
Just make sure you use the proper crimping tehnique and a go-nogo gauge.
N642Z reserved
amyvega2005(at)earthlink. Guest
Posted: Tue Jan 29, 2008 12:21 pm Post subject: Are Copper Nico Sleeves OK? |
Bill,
you can use Copper all day long, its on all taildraggers built since God was a toddler.
Juan
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Tue Jan 29, 2008 12:33 pm Post subject: Re: Are Copper Nico Sleeves OK? |
Another Q.
What should they be pull tested to? I read that the cables only have to be 30lb tension but what should I pull test to, to make sure my sleeves are OK to use.?
Chris.
Posted: Tue Jan 29, 2008 1:11 pm Post subject: Are Copper Nico Sleeves OK? |
chris,
its not a pull test. the niccos go on with a diameter setting, and you measure it with slot tester. if it is crimped,correctly,(center first, then out from center) you can move it in and out of the slot tester. The 30 lbs, is inch pounds, and its roughly 4 foot lbs with a cable tensionomter. Borrow one if possible, they run expensive. other option is to tighten until just before they start to impedemovement on full deflection. That is what I did. Just tight enough for comfortable movement. Too loose and you can get little bit of flutter, to much and you are arm wrestling it.
NOTE: after 5 or so hours, RETENSION THE CABLES! they do loosen up.
Juan
bryanmmartin
Posted: Tue Jan 29, 2008 1:21 pm Post subject: Are Copper Nico Sleeves OK? |
You don't pull test them. After crimping the correct sleeve on the
correct size cable, a go/no go gauge is used to check the size of the
crimp. If it falls within the minimum and maximum size range, the crimp
is good. The go/no go gauge should come with the nicopress tool.
chris Sinfield wrote:
Another Q.
Chris.
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
John Bolding
Posted: Tue Jan 29, 2008 3:44 pm Post subject: Are Copper Nico Sleeves OK? |
Lots of folks do this but I stopped many yrs ago when I discovered a sleeve
that was slipping under the heatshrink. The heatshrink was crinkled slightly
which gave it away. Now I put witness paint on the bitter end along with a
little clear fingernail polish on the extreme end to keep it from
unraveling.
LO&SLO John
