Posted: Thu Jan 24, 2008 6:13 am Post subject: Data plate questions |
Does anyone have a link to a document that states the minimum requirements for the Airframe Data plate?
All the government documents that I've found so far are gibberish and refer to the engine. I know that some kit manufacturers sell data plates for the individual builder to have engraved and install and I have seen them in use so they must meet some minimum requirements.
What I'm specifically interested in is the requirement for accuracy of the date of manufacture. My airframe is built and registered - but not yet declared airworthy. I need to have the plate installed prior to airworthiness inspection - so I'll need to have it engraved prior....what data do I put there?
Ralph
Working on the million little things......
n616tb(at)btsapps.com Guest
Posted: Thu Jan 24, 2008 6:43 am Post subject: Data plate questions |
I just put the month and year I anticipated the inspection to be within.
The DAR never even looked at it.
[quote] --
Posted: Thu Jan 24, 2008 7:10 am Post subject: Data plate questions |
Ralph E. Capen wrote:
With no data to support it (nothing I could find at the time), I used
the date that the airplane was 'finished' and ready for inspection.
Linn
Ralph
passpat(at)aol.com Guest
Posted: Thu Jan 24, 2008 8:23 am Post subject: Data plate questions |
Builders name/manufacture
Model as RV-7-A
Serial number xxxx
rv8a2001(at)yahoo.com Guest
Posted: Thu Jan 24, 2008 12:46 pm Post subject: Data plate questions |
Model
Manufacturer
Ser #
Thats all I have.
Scott Bilinski
RV-8a
carlosh(at)structuralaz.c Guest
Posted: Thu Jan 24, 2008 2:39 pm Post subject: Data plate questions |
Question about serial #'s....
I've "heard" here and there that FAA wants the serial # to match the
builders number. I don't think is is that way but It shouldn't matter if
I wanted to register with serial # 17BYLOS does it?
Carlos in AZ
STILL saving money for the -7A wings
scott bilinski wrote:
Model
Manufacturer
Ser #
Thats all I have.
Scott Bilinski
RV-8a
acepilot(at)bloomer.net Guest
Posted: Thu Jan 24, 2008 2:57 pm Post subject: Data plate questions |
Shouldn't make a rat's butt of difference. It just has to be unique
within the system
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Carlos Hernandez wrote:
<carlosh(at)structuralaz.com>
if I wanted to register with serial # 17BYLOS does it?
Carlos in AZ
> Model
> Manufacturer
> Ser #
> Thats all I have.
> Scott Bilinski
> RV-8a
Gary.A.Sobek
Posted: Thu Jan 24, 2008 8:39 pm Post subject: Data plate questions |
http://www.rvdar.com/FAR_45.htm
Permanent attached Fireproof Data Plate with Builder's Name (Make), Model Designation, and Builder's Serial Number.
The above info MUST match the registration info that is on the 8050-3 that comes from Oklahoma City.
The MODEL and Serial Number can be anything that you like but the only model with the serial number that you assign. If your aircraft is an RV-?, then it is best to use the builder's number that Van's assigned. IF you purchase a kit from Van but register it as "YOUR NAME Special", the S/N can be anything you want or the number that Van assigned.
Gary A. Sobek
2,077 + Flying Hours So. CA, USA
[quote] Date: Thu, 24 Jan 2008 09:10:55 -0500
To: rv-list(at)matronics.com
Subject: Data plate questions
--> RV-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net>
Ralph
Working on the million little things....========================Climb to the top of the charts! Play the word scramble challenge with star power. Play now! [quote][b]
aerobubba(at)earthlink.ne Guest
Posted: Fri Jan 25, 2008 11:29 am Post subject: Data plate questions |
Hi Carlos-
RE: Question about serial #'s....
| Quote: | I've "heard" here and there that FAA wants the serial # to match the
Actually, the fed DOES want you to use van's type designation and serial number. They want it that way so that it is easier to compile accident / safety stats. Apparently, making a note in their report that the Whiz-Bang 5000 was actually kitted as an RV-x is more than they can achieve. However, the pertinent thing here is that they WANT you to do that. You don't HAVE to do that. You may wonder how I know this....
Glen Matejcek
mrobert569(at)hotmail.com Guest
Posted: Fri Jan 25, 2008 7:49 pm Post subject: Data plate questions |
Ralph,
Per FAR 45 there are only three things required on the airframe dataplate. The Make, model, and serial number are those three things. Anything else is up to you.
Mike Robertson
Das Fed
| Quote: | From: recapen(at)earthlink.net
Ralph
Working on th===========
Need to know the score, the latest news, or you need your Hotmail®-get your "fix". Check it out. [quote][b]
