Posted: Sun Jan 27, 2008 8:23 pm Post subject: Starter Problem |
I've had a problem lately where the first time I hit the starter switch on the first start of the day, all I get is a "click", but the prop doesn't even twitch. I assume the noise is the starter relay.
On the second or third attempt, the starter will engage and off we go.
How do I diagnose this? Is it the relay, or something with the Prestolite starter, maybe the bendix not extending?
BTW, I know there are better starters out there, but I need weight out front, so the Prestolite is a good way to go for me..
Thanks in advance,
Kyle Boatright
Posted: Sun Jan 27, 2008 8:56 pm Post subject: Starter Problem |
Kyle Boatright wrote:
| Quote: | I've had a problem lately where the first time I hit the starter switch on the first start of the day, all I get is a "click", but the prop doesn't even twitch. I assume the noise is the starter relay.
| I think so.
| Quote: | , or something with the Prestolite starter, maybe the bendix not extending?
| You'd hear the starter running if it was getting power. | Quote: | BTW, I know there are better starters out there, but I need weight out front, so the Prestolite is a good way to go for me..
| The bendix will like some graphite periodically since you're going to keep it.
When you get a new relay, get some plasti-dip and coat the body of the relay really good. Keeping the moisture out (yeah, I know ... they're supposed to be sealed) helps their longevity.
Linn
Thanks in advance,
Kyle Boatright
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Mon Jan 28, 2008 8:12 am Post subject: Starter Problem |
That click is the solenoid trying to fire but doesn't have enough oomph to make good contact. There's a good chance it's the connections to the relay or the ground or the relay itself. Cheapest first step is clean and tighten all the connections. Then replace the relay. A Bendix problem is more likely to spin but not engage (or disengage).
Greg Young
[quote] From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Kyle Boatright
Sent: Sunday, January 27, 2008 10:21 PM
To: rv-list(at)matronics.com
Subject: Starter Problem
Thanks in advance,
Kyle Boatright
