tigermoth3(at)hotmail.com Guest
Posted: Wed Jan 23, 2008 4:17 pm Post subject: Egt probes - cht probes |
At that very point myself. Decided the opportunity to monitor all six EGT's as a diagnostic tool will make the install worthwhile.
Now, my question : Installing the six probes under the plugs for the CHT. How can I fit the probe ring under the plug & still get a plug socket on the plug well enough to seat plug/probe ring? what am I missing here?
Bill Murphy
Tiger Moth 31 (building)
Shed those extra pounds with MSN and The Biggest Loser!
http://biggestloser.msn.com/
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
Kayberg(at)aol.com Guest
Posted: Wed Jan 23, 2008 4:56 pm Post subject: Egt probes - cht probes |
In a message dated 1/23/2008 7:17:58 P.M. Eastern Standard Time, tigermoth3(at)hotmail.com writes:
Bill Murphy
Grind a part of the cooling fin off that blocks it at the plug. Will require removing a piece the size of your fingernail
doug
Start the year off right. Easy ways to stay in shape in the new year.
notsew_evets(at)frontiern Guest
Posted: Wed Jan 23, 2008 5:05 pm Post subject: Egt probes - cht probes |
I had the same problem.
Jabiru said to grind off some of the fins on the head. I did not want to
grind off anything on my $21K package.
Jabiru Jim had me purchase Champion spark plugs # 905. These have a small
socket size and work perfectly..
SW
plus2s
Posted: Wed Jan 23, 2008 5:39 pm Post subject: Egt probes - cht probes |
Have heard that you can change to a round terminal and fit it under a
head stud. Apparently it reads a few degrees cooler, but saves oil leaks
etc from plug. Haven't tried it, but sounds like a good idea.
KP
