Michel
Posted: Mon Feb 27, 2006 12:50 am Post subject: Cruise vs. Vne speed |
Hello guys,
On the Jabiru Engines list, someone was comparing the cruise speed of different Kitfoxes and I was surprised to see someone with a model 2 saying that he cruises at 122 MPH.
I have a model 3 and while I believe I can reach 122 MPH at WOT, my POH says that 100 MPH is Vne, and I respect that. Could it be that the model 2 has a higher Vne that the model 3?
While on the subject of speed, I was wondering when you, guys, decide to slow down to Va, due to turbulence. I know the theory but ... how bad the turbulence must be for you to slow down?
Michel
_________________ Kitfox 3 - Jabiru 2200 |
Graeme Toft
Posted: Mon Feb 27, 2006 2:07 am Post subject: Cruise vs. Vne speed |
Hi Michel, I have always backed off in turbulence because of the real
possibility of exceeding VNE very quickly, in fact excessive speed can occur
so fast that even in mild conditions I tend to find myself flying with my
hand on the throttle. Here in Queensland most of our turbulence is created
by heat with very little mechanical effect due to a relatively flattish
terrain. At times the thermals are so active you can be in a descending
attitude but ascending at over 1500 ft a minute, then as you come out of the
thermal you will enter another that is descending equally as fast. I like to
keep at least 20 knots between VNE and cruise as a safety margin in these
conditions. The figures on the Model 2 in my humble opinion are pushing the
limit.
Cheers
Graeme Toft
Queensland Safety Solutions
Ph: 07 49397011
Mob: 0411476527
jdmcbean(at)cableone.net Guest
Posted: Mon Feb 27, 2006 10:06 am Post subject: Cruise vs. Vne speed |
Michel,
The Vne is 100 mph on the 2 and the 3. I doubt what was being said is the
truth.. There are not that many Fox's cruising around at 122 mph and the
ones that are, have the flatter bottom wing not the high under camber. You
can visit the about Kitfox page on our web
http://sportplanellc.com/about_kitfox.htm regarding the Vne.
As for Va... follow your comfort level if it feels like you should be slower
then slow down... I think you'll find that above mild turbulence in the
Kitfox usually does the trick and you'll slow down. If there is a lot of
gusty type turbulence (gust loads) it is a good idea to be at Va.
Fly Safe !!
John McBean
www.sportplanellc.com
"The Sky is not the Limit... It's a Playground"
spaghettiohead(at)hotmail Guest
Posted: Mon Feb 27, 2006 10:49 am Post subject: Cruise vs. Vne speed |
I doubt that the Model 2 is cruising at 122...what's he got for a
powerplant?
My Model 3 with the 582 doesn't cruise over 80 at WOT, but normal cruise is
65-70. And what would Va be in our earlier models?
Also, it's amazing how quickly the 'Fox picks up speed - in a power-off dive
she'll hit 100 in about 3 seconds!
Andrew
[quote]From: "Graeme Toft" <msm(at)byterocky.net>
Subject: Re: Cruise vs. Vne speed
Date: Mon, 27 Feb 2006 20:02:04 +1000
occur
the
to
limit.
Cheers
Graeme Toft
Ph: 07 49397011
Mob: 0411476527
Rex Hefferan
Joined: 10 Jan 2006 Posts: 147 Location: Olney Springs, Colorado USA "NOT a Kitpig"
Posted: Mon Feb 27, 2006 11:39 am Post subject: Cruise vs. Vne speed |
Hi Michel,
No the Vne has risen with some newer models of Kitfox, never fallen.
Standard Model 2 Vne is also 100 MPH. If someone properly modified their
Model 2 it's possible they might safely operate at a higher Vne, but I
wouldn't know about that.
Rex
M2 - N740GP
Colorado
Michel Verheughe wrote:
Quote: |
Hello guys,
Michel
Karla and Rex Hefferan
Gypsy Bee Innkeepers
719-651-5198 or 719-651-9192
_________________ Rex
N740GP - M2/582
Colorado |
roncarolnikko(at)hotmail. Guest
Hi michel. I have an early model Avid Flyer and one of the differances that
keeps it's VNE slow is the .060 windscreen. At 100 MPH it is pushing in
more than the .090 thick windscreen. With the .090 windscreen it could be
somewhere near 135.
Ron NB Ore
Subject: Cruise vs. Vne speed
Date: Mon, 27 Feb 2006 09:46:12 +0100 (CET)
Hello guys,
Michel
Michel
Posted: Mon Feb 27, 2006 2:03 pm Post subject: Cruise vs. Vne speed |
Thank you, Graeme, Jim, Andrew, Ron and Rex, for your answers.
For the cruise speed, on the Jabiru list, someone was asking for the
performance of a Jabiru 2200 (that's your answer, Andrew) on a draggy
plane similar to a Kitfox or Avid Flyer. Several answered and the
person was puzzled that it may vary from 80 MPH (my cruise speed) to
122 MPH (one reported by a friend Kitfox 2 owner). I agree with you,
it must be exaggerated or, the owner has a special model 2 and likes
fast cruising!
For the Va speed, I understand that it is a matter of comfort and that,
when in turbulent air, Vne is quickly exceeded as both vertical and
indicated speed needles move fast in all directions. But, I remember
that I once sailed into a French harbour to hear French yachtsmen who
had just arrived before me, talking about sailing in a storm ... when I
would have called it a moderate gale. It's all in the observator's eye.
As a novice pilot, any turbulence is a bit scary and I was wondering
what is real bad stuff that needs to stay at Va to avoid structural
damages. Do I have to loose my denture, wig and glass eye, to call it
significant turbulence? So far, the worse I have experienced is a short
moment when I felt my feet lifted from the floor ... it must have been
negative Gs. Is that "bad turbulence" or ... "moderate gale?"
I also like Rod Machado's saying: "Turbulence are like waves at sea,
only that you don't see them ... and that's what horror movies are made
of!"
Michel
Posted: Mon Feb 27, 2006 5:05 pm Post subject: Cruise vs. Vne speed |
Michel,
Describing turbulence is very difficult..
One pilot's light chop is another's moderate-to-severe. Perception varies
with aircraft weight, type, and speed. A large, heavy, fast plane with high
wing loading has inertia in its corner and will be less disturbed by a given
bump than will a small, slow, lightly laden machine.
According to the AIM, if occupants feel a slight strain against their seat
belts and there is a slight, erratic change in aircraft altitude or
attitude, it is "light" turbulence. But what might be light turbulence to
the pilots of a 747 could be moderate to severe to the occupants of a
four-place single, who might feel definite strains against their seat belts
and have loose objects dislodged (moderate), or who may be forced violently
against their belts and experience large, abrupt changes in aircraft
altitude or attitude.
Turbulence may also be reported as occasional, intermittent, or continuous,
corresponding to less than 1/3, more than 1/3, or more than 2/3 of the time.
Turbulence also comes in two reportable varieties: Normal turbulence is a
dose of the shakes; chop is bumpy and rhythmic, akin to a speedboat skimming
across a rough lake. UDDF is a corollary comment, standing for "strong
up-and-down drafts." Make it quantitative if you must: "2000 FPM UDDF."
The definition according to the Aeronautical Information Manual.. AIM 7-1-24
Light: Turbulence that momentarily causes slight, erratic changes in
altitude and/or attitude (pitch, roll, yaw). Report as Light Turbulence or
Turbulence that causes slight, rapid and somewhat rhythmic bumpiness without
appreciable changes in altitude or attitude. Report as Light Chop.
Occupants may feel a slight strain against seat belts or shoulder straps.
Unsecured objects may be displaced slightly. Food service may be conducted
and little or no difficulty is encountered in walking.
Moderate: Turbulence that is similar to Light Turbulence but of greater
intensity. Changes in altitude and/or attitude occur but the aircraft
remains in positive control at all times. It usually causes variations in
indicated airspeed. Report as Moderate Turbulence or Turbulence that is
similar to Light Chop but of greater intensity. It causes rapid bumps or
jolts without appreciable changes in aircraft altitude or attitude. Report
as Moderate Chop.
Occupants feel definite strains against seat belts or shoulder straps.
Unsecured objects are dislodged. Food service and walking are difficult.
(Walking not an option in a Fox)
Severe: Turbulence that causes large, abrupt changes in altitude and/or
attitude. It usually causes large variations in indicated airspeed. Aircraft
may be momentarily out of control. Report as Severe Turbulence.
Occupants are forced violently against seat belts or shoulder straps.
Unsecured objects are tossed about. Food Service and walking are impossible.
Extreme: Turbulence in which the aircraft is violently tossed about and is
practically impossible to control. It may cause structural damage. Report as
Extreme Turbulence.
High level turbulence (normally above 15,000 feet ASL) not associated with
cumuliform cloudiness, including thunderstorms, should be reported as CAT
(clear air turbulence) preceded by the appropriate intensity, or light or
moderate chop.
Fly Safe !!
John & Debra McBean
dcaofak(at)acsalaska.net Guest
Posted: Mon Feb 27, 2006 5:31 pm Post subject: Cruise vs. Vne speed |
I believe there is a Vne issue with the model III and earlier Kitfoxes because the wings are not rib stitched.
I have some memory (?) of there being something from the FAA limiting Vne to 100 mph if the fabric on the wings is only held with glue.
John Stoner
KFIII, 582
Alaska
bmwebb(at)cox.net Guest
Posted: Mon Feb 27, 2006 6:46 pm Post subject: Cruise vs. Vne speed |
Skystar SB'd the Model 2 to 90mph, due to a couple flutter incidents. I
think this was raised to 100 once the dual counter-weights are installed.
Bradley
lcfitt(at)sbcglobal.net Guest
Posted: Mon Feb 27, 2006 7:53 pm Post subject: Cruise vs. Vne speed |
Hi, John,
It has been always my understanding that the VNE in the earlier Kitfoxes was
at least in part a windsheld issue. I have a model IV and the VNE is 125
mph. I believe that the Speedster - thicker windshield with clipped wings
has a VNE of 135 mph. Rib stitching was not part of my building
instructions, but due to list influence, I did rib stitch mine. The one
inch capstrips are pretty unique to our class of airplanes and the factory
determined that with those wide capstrips rib stitching was not necessary.
There have been tons of discussion on the list and opinions on ribstitching
are many. In fact the subject of false ribs have come up on the list lately
and brought up a question of my own.
Has anyone rib stitched the false ribs - the upper ones most specifically.
I did not.
Also when replacing my windshield, I stuck with the thin lexan. It does
move a bit getting close to VNE, but I have seen it so much that It really
doesn't bother me. I must have had 500 hours on the original and changed it
out because I finally got tired of looking at a big scratch I put on it
while building. Also the thinner Lexan is a bit more flexible - obviously -
and moves around the top corner a bit easier.
Lowell
jopatco(at)mindspring.com Guest
Posted: Tue Feb 28, 2006 6:04 am Post subject: Cruise vs. Vne speed |
150 mph is glued on one inch cap strips.I;ve been over 140 mph and still
here.
Quote: | [Original Message]
To: <Kitfox-List(at)matronics.com>
Date: 2/27/2006 6:41:32 PM
Quote: | I have some memory (?) of there being something from the FAA limiting Vne
Quote: | John Stoner
KFIII, 582
Alaska
wingnut
Posted: Tue Feb 28, 2006 7:39 am Post subject: Re: Cruise vs. Vne speed |
I've been following this thread with interest because I've always felt that it was strange how close 75% cruise is to to Vne on my airplane. According to Rotax, setting the manifold pressure to 27 inches then pitching the IVO prop for 5200 rpm constitutes 75%. At that setting, I'm pushing about 115mph. That's only 10mph short of Vne. All I have to do is lean forward a little to get a closer look at my chart to pitch the nose down enough to blow past Vne. Is this something that I should be worried about? Should I keep the speeds down until I have a better feel for keeping the airspeed constant?
-Luis
