Slot in CM for LG retraction lever
fklein(at)orcasonline.com
PostPosted: Sun Jan 20, 2008 4:07 pm    Post subject: Slot in CM for LG retraction lever Reply with quote
On Pg 28-1, Step 2, the manual calls for a slot in the CM 75mm and 85
mm off the aircraft centerline for the LG retraction lever.
Having marked it as shown in Fig. 2, I note that about 8" of the port
side edge of the retraction lever guide plate falls to port of the top
horizontal plane of the wheel well tunnel. If I trim the port side of
the plate as called for on Pg. 28-3 I lose quite a bit of the guide
plate metal...this causes me some concern for both functional and
aesthetic reasons.
Left to my own devices, I would reduce the dimensions of the slot to
acft. centerline to 60mm and 70mm respectively.
Have any other mono-builders found this situation and how have you
remedied it?
Comments most appreciated!
Fred
A194
believed to be clean.
paul.the.aviator(at)gmail
PostPosted: Sun Jan 20, 2008 8:02 pm    Post subject: Slot in CM for LG retraction lever Reply with quote
Hi Fred,
I had to add some foam to the side of the tunnel. Take a look at
http://www.europa.net.nz/363/index.html under August 2001.
Paul
