henry.voris
Joined: 02 Mar 2007 Posts: 116 Location: Pueo Field, Kula, Maui
Posted: Mon Jan 14, 2008 9:24 am Post subject: iron for fabric repair |
14jan08
Fellow Kolbers...
I have to perform a repair on a tear in the fabric on my plane's wing...
I'm looking for information on a good iron...
A. Brand?
B. Where to purchase?
C. Same questions on a unit to calibrate the iron's temperature.
Thanks..
Aloha,
_________________ Henry
Firefly Five-Charlie-Bravo
Do Not Archive |
jhankin(at)planters.net Guest
Posted: Mon Jan 14, 2008 11:20 am Post subject: iron for fabric repair |
A good iron for repairs on a tear is a radio control molders covering iron,
available at hobby shops.
A good test heat unit is found at Harbor Freight, it is a hand held point
and read instrument, sells for about $65.00 and can be bought on sale for
$35.00. Also good for reading CHT on the engine.
Jimmy Hankinson
Rocky Ford, Ga.
N6007L Firefly
henry.voris
Posted: Tue Jan 15, 2008 7:02 am Post subject: Re: iron for fabric repair |
Jimmy,
Thank you. That's just what I was looking for... Ya gotta love this Kolb List...
Aloha,
Do Not Archive |
planecrazzzy Guest
Posted: Tue Jan 15, 2008 2:23 pm Post subject: Re: iron for fabric repair |
For the Hobby Iron.....I used my old one but the heat wasn't very controllable....
I bought the "Black Baron" from ACS for about the same price....
it holds the temp a little better...
Gotta Fly...
Mike & "Jaz" in MN
henry.voris
Posted: Thu Jan 17, 2008 10:47 am Post subject: Re: iron for fabric repair |
Mike or maybe Jaz...
Thanks for the word on the "Black Baron" from ACS. I checked their catalog and it looks like the unit for me.
Early next week I'll be on the mainland, so I'll drop by Harbor Freight and check out the IR senseing unit Jimmy recomended.
Got the rest of the materails together... So I should be able to get to work on the tear when I return at the end of the month.
Aloha
Do Not Archive |
Posted: Thu Jan 17, 2008 11:21 am Post subject: iron for fabric repair |
Henry,
No need to wait on Harbor Freight for your digital thermometer. I just recently purchased this model on eBay and I am very satisfied with its performance and quality. Here's the link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190183316352
It works VERY well and appears to be a quality item!! I read the surface temp of the iron every 30-45 seconds....only takes a couple of seconds to read with the red laser dot, and is accurate to a 10th of a degree.
eBay has dozens and dozens of models of digital thermometers. I can't see the need of a more expensive one than the one I got.
Mike Welch
Kolb MkIII. PolyFiber finished on fuselage and tailfeathers. Yay!! Wings are next. And whoever said "putting PolyFiber on is easy" is nuts!! It's a Major job! But, I'm not complaining! You can't complain when you are working on your airplane!!
| Quote: | Subject: Re: iron for fabric repair
Date: Thu, 17 Jan 2008 10:47:31 -0800
Aloha
Henry
http://forums.matronics.com/viewtopic.php?p=158827#158827
Connect and share in new ways with Windows Live.
http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_012008
henry.voris
Posted: Fri Jan 18, 2008 8:26 am Post subject: Re: iron for fabric repair |
Guys,
Thank you for all the good advice.
I'm gonna get the "Black Baron" from ACS & the IR sensor from eBay...
Aloha,
Do Not Archive |
