drc(at)wscare.com Guest
Posted: Tue Jan 15, 2008 2:56 pm Post subject: [Spam] Re: GT50 Flight Data System in my Yak52 |
If you can identify a drain on the battery, i.e. not a bad battery or other problem, then there are several inexpensive trickle chargers that are meant for this very problem. I have a couple of cars I put up for the winter in Green Bay. One with all of its electronics will drain the battery in about 4 weeks of not running. I do not like to disconnect the battery for the winter because I may drive it and the codes in the clocks, stereo, GPS and the electronic keys get messed up with no power. I put one of these low amperage chargers that mounts to the posts and then has a short cord with a plug on the end that is mounted under the hood. I pop the hood and plug in the charger - it works great.
Herb
On Jan 15, 2008, at 1:07 PM, b747crew2003(at)aol.com (b747crew2003(at)aol.com) wrote:
[quote]Dennis; Thanks for the information. I'm just attempting to sort out the problem and think it through so that I understand whats happening. Th GT50 is a "Flight Data Systems".
When I left the aircraft before the battery went dead I was sure that I pulled all the appropriate C/B's and turned everytrhing off. ( None of the avionics is on a master sw and must be turned off individually ) Now when I got to the Aircraft the Battery was down to about 6 VDC. from a full charge. That said I reason the only things that could have drawn down the ships battery was either the GPS or the GT50 unless there is a direct short somewhere in the system somewhere. Now when I pulled the batteries out of the aircraft they appear to be origional to the ship and 2 terminals were corroded so that prompted me to buy 2 new batts which I havn't yet installed but will this next weekend. I'm thinking that the entire avionics package needs to be on an avionics bus with a seperate master sw......... Your Thoughts?? By the way did you get my check?
Kindest Regards
Jack
Posted: Tue Jan 15, 2008 4:10 pm Post subject: [Spam] Re: GT50 Flight Data System in my Yak52 |
A battery that is old or marginal to begin with will go to hell in a
handbasket when the temperature drops. That is just the nature of
batteries, especially old ones.
However this is a very simple problem to take a look at, and the best
answer is NOT to theorize, but to actually MEASURE. You simply need to
turn every darn thing you can OFF including the master and other things,
etc., etc., then go back to the battery and remove the negative lead off
the battery. Connect an ammeter, between the negative lead you just
took off and the negative terminal of the battery itself. Assuming the
meter is set properly, and you have the meter leads attached to the
meter properly (get someone who knows how to do this in advance) then
you will read the actual current draw on the battery with everything
turned off. This number... This value... Is what needs to be KNOWN
before anyone can determine whether the battery should be able to supply
it for days or weeks on end, or... That it is excessive due to some
fault somewhere, that is not going to be fixed by new batteries.
I agree with Herb, that trickle chargers and especially desulfactor
arrangements are smart purchases, but the actual current draw should be
done as an immediate first step and not after buying new batteries,
putting on a trickle charger etc.
Have everything fully charged and ready to go, then measure the current
draw. It's a 5 minute task.
Mark Bitterlich
B747crew
Posted: Tue Jan 15, 2008 4:19 pm Post subject: [Spam] Re: GT50 Flight Data System in my Yak52 |
Mark; What good advice. I'll do exactly that.
Jack
_________________ Jack Snodgrass
4305 Claridge Ct.
Apex, NC 27539
919-745-7434 |
Posted: Tue Jan 15, 2008 4:20 pm Post subject: [Spam] Re: GT50 Flight Data System in my Yak52 |
Thanks Mark. You're right on the money....again. The batteries in Jack's
newly acquired 52W are most likely the originals. Thus '99 or 2000 vintage.
7 or 8 years on batteries is unheard of. It is definitely time to replace
them.
Dennis
Posted: Tue Jan 15, 2008 4:50 pm Post subject: [Spam] Re: GT50 Flight Data System in my Yak52 |
I am sure you are absolutely correct Dennis. Same thing happened to Tom
Johnson's 50. Batteries that old are just waiting to fail on you
completely when you least expect it... Like cold weather.
By the way, I am not sure how to spell "Desulfator"... Anyway, the
device that puts out about a 3 Mhz pulse and blasts the plates clean on
batteries. Darn things are amazing, and using them can actually extend
aircraft battery life to twice or even thrice normal age. Considering
you can buy one in kit form for about $25, they are a steal. I have 2
gel cells that were totally dead (off of an electric wheel chair... 12
volt 35 AH jobs), that I ran one of these devices for two weeks straight
on. They now charge and work perfectly. That is in the "WOW" category.
Mark
