rv7(at)b4.ca Guest
Posted: Mon Jan 14, 2008 2:12 pm Post subject: Home-made 406 MHz alternatives? |
On 12:46 2008-01-14 "Larry James" <larry(at)ncproto.com> wrote:
| Quote: | Our intent has nothing to do with meeting FAA regs; it is simply a
tool that lets me (or us) let loved ones know where we are and that
we are safe; and has the likelihood of being more useful than
currently available ELT and PLB devices in an emergency. Our Super D
has the FAA legal ELT in it to meet regs.
Someone else brought up the point that the Spot doesn't meet FAA
requirements for a locating device... Your email prompted me to reply, and
create a new thread on this, as it's something i've been wondering for a
long time...
The Spot doesn't meet FAA requirements for a locating device, but is there
any reason that a similar, home-made, device couldn't meet the
requirements? We're flying around in airplanes that we're frequently told
"do not meet standards for factory built aircraft". At least, in Canada we
have to have a sticker prominently visible to the passenger telling them
that (in both English *and* French, no less!). So why can't our location
device also "not meet standards"? Why couldn't we start with a (cheap)
406Mhz PLB, rig up our own GPS interface, and our own inertial or manual
trigger?
Technically, there's nothing stopping any of us from doing this, it's
really not rocket science. The question is, why isn't it acceptable, if
the plane is experimental in the first place?
Discuss...
-Rob
acepilot(at)bloomer.net Guest
Posted: Mon Jan 14, 2008 2:52 pm Post subject: Home-made 406 MHz alternatives? |
Technically, here in the states we have a pesky problem to get around
called the FCC (Federal Communications Commission) that regulates any
and all transmitters. Most must be type certified by the FCC. One
exception to type certification is amateur (ham) radio stuff, but 406
MHz is not in a ham band...
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Rob Prior wrote:
Discuss...
-Rob
rv7(at)b4.ca Guest
Posted: Mon Jan 14, 2008 3:25 pm Post subject: Home-made 406 MHz alternatives? |
On 14:52 2008-01-14 Scott <acepilot(at)bloomer.net> wrote:
| Quote: | Technically, here in the states we have a pesky problem to get around
True, but that's a regulatory issue too, not a technical one. And i'm not
advocating designing your own transmitter, far from it. I'd like to see
someone rig up a "hack" to an existing 406 MHz PLB, that would make it do
all the things an aircraft-certified one would, at 1/10th the cost.
I'm just continually amazed that it costs so much to get a certified
aviation-quality 406MHz ELT into an airplane, when you can buy a
technically superior unit (the Spot) for so little. All it's missing is a
G-switch.
-Rob
Posted: Mon Jan 14, 2008 3:38 pm Post subject: Home-made 406 MHz alternatives? |
Rob Prior wrote:
long time...
trigger?
Discuss...
-Rob
I think I suggested this earlier, but it might have been on another
list; this topic is hot on 3 different lists right now. You'd still be
legally required to carry at least the 121.5 unit (that requirement is
outside the homebuilt rules) but there's no reason not to rig a G-switch
on a PLB. (They've already got the manual trigger.)
Charlie
Posted: Mon Jan 14, 2008 3:52 pm Post subject: Home-made 406 MHz alternatives? |
Well, I won't split hairs too much, but by "hacking" an existing
transmitter that I presume is type certified, it WON'T be type certified
after the hack and the operator would be subject to FCC enforcement on
this side of the border. That said, a regular ELT is STILL required over
here so adding a 406 transmitter is just additional cost. The FCC does
allow the use of "any means possible" to communicate in an emergency,
but, assuming you survive the wreck, they may send you (sorry, us U.S.
citizens) an offical invitation to respond in writing to their questions
as to the nature of the emergency...do not archive
Scott
Rob Prior wrote:
G-switch.
-Rob
John.Morrissey(at)csiro.a Guest
Posted: Mon Jan 14, 2008 4:10 pm Post subject: Home-made 406 MHz alternatives? |
Unless you live in New Orleans
John Morrissey
Posted: Mon Jan 14, 2008 4:22 pm Post subject: Home-made 406 MHz alternatives? |
Remember, the 'hack' doesn't have to be internal. Take a look at some of
the older 121 ELTs. The G switch is just a hinged weight next to an off
the shelf miniature toggle switch. All you need is the right amount of
weight hanging behind the activation switch, & a mount for the PLB in
the correct orientation so a crash swings the weight into the switch.
Charlie
Scott wrote:
Scott
> not
> is a
> G-switch.
> -Rob
ronlee(at)pcisys.net Guest
Posted: Mon Jan 14, 2008 5:38 pm Post subject: Home-made 406 MHz alternatives? |
Why the problem. If you need a G-switch to activate it then you may
be dead. Mount it where you can push the one 911 button when you need it.
Ron Lee
sportav8r(at)gmail.com Guest
Posted: Mon Jan 14, 2008 7:05 pm Post subject: Home-made 406 MHz alternatives? |
On Jan 14, 2008 6:52 PM, Rob Prior <rv7(at)b4.ca (rv7(at)b4.ca)> wrote:
| Quote: | --> RV-List message posted by: "Rob Prior" <rv7(at)b4.ca (rv7(at)b4.ca)>
On 14:52 2008-01-14 Scott < acepilot(at)bloomer.net (acepilot(at)bloomer.net)> wrote:
G-switch.
-Rob
| C'mon, somebody... make the G-Spot joke that Rob is begging for...
gmcjetpilot
Posted: Tue Jan 15, 2008 9:24 am Post subject: Home-made 406 MHz alternatives? |
| Quote: | "Technically, there's nothing stopping any of us from
doing this"
Yes there is. Nice try but ELT's are one device that
MUST meet strict specifications regardless of type of
aircraft its mounted to. Not saying you can't make a
homemade ELT, but it would be illegal and break FAA,
FCC and international SAR regulations. The ELT and
transponder are two devices that must be "certified"
even if in an experimental aircraft.
Fork over $1000 for a Artex 406ME, be done,
and also get a $600 PLB.
| Quote: | From: "Rob Prior" <rv7(at)b4.ca (rv7(at)b4.ca)>
Subject: Home-made 406 MHz alternatives?
Why couldn't we start with a (cheap) 406Mhz PLB, rig
manual trigger?
doing this, it's really not rocket science. The question
is, why isn't it acceptable, if the plane is experimental in
the first place?
Discuss... -Rob
Be a better friend, newshound, and [quote][b]
Posted: Tue Jan 15, 2008 9:56 am Post subject: Home-made 406 MHz alternatives? |
My suggestion for the below comment is get the GPS enabled 406 MHz ELT
and the Spot unit for everyday notification of your position.
The most important thing is don't make stupid decisions about piloting.
Ron Lee
[quote] and also get a $600 PLB.
