VG's effect on Runway Leingth
JetPilot
PostPosted: Fri Jan 11, 2008 11:59 am    Post subject: VG's effect on Runway Leingth Reply with quote
A picture is worth a thousand words, so below are a couple pictures.
First picture is my Kolbs runway without VG's, Second is my Kolbs runway with VG's. Any questions Wink
Runway my Kolb needed Without VG's
 Filesize:  180.95 KB
 Viewed:  793 Time(s)
Runway For my Kolb with VG's
 Filesize:  193.64 KB
 Viewed:  750 Time(s)
Kolb MK-III Xtra, 912-S
slyck(at)frontiernet.net
PostPosted: Fri Jan 11, 2008 1:33 pm    Post subject: VG's effect on Runway Leingth Reply with quote
Steve B's are those long blue ones.
runway with VG's. Any questions [Wink]
"NO FEAR" - If you have no fear you did not go as fast
as you could have !!!
http://forums.matronics.com/viewtopic.php?p=157518#157518
http://forums.matronics.com//files/runwaywithoutvgs_905.jpg
http://forums.matronics.com//files/runwaywithvgs_131.jpg
jindoguy(at)gmail.com
PostPosted: Fri Jan 11, 2008 1:35 pm    Post subject: VG's effect on Runway Leingth Reply with quote
So if you put on VG's you can't get the Kolb lined up with the runway? Smile
Rick
On Jan 11, 2008 1:59 PM, JetPilot <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)> wrote:
[quote]--> Kolb-List message posted by: "JetPilot" < orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)>
First picture is my Kolbs runway without VG's, Second is my Kolbs runway with VG's. Any questions [Wink]
http://forums.matronics.com//files/runwaywithoutvgs_905.jpg [quote][b]
NeilsenRM(at)comcast.net
PostPosted: Fri Jan 11, 2008 2:28 pm    Post subject: VG's effect on Runway Leingth Reply with quote
If you need that long of a runway for your kolb you need a whole lot more
than just VGs.
I sill would like to see a objective comparison between the same airplane
with VGs and without.
Rick Neilsen
Redrive VW powered MKIIIC
R. Hankins
PostPosted: Sat Jan 12, 2008 10:13 pm    Post subject: Re: VG's effect on Runway Leingth Reply with quote
Holy large runways Batman! Thanks for the chuckle. Smile
Here is a picture taken just before launch from my brother's place. His house and trees are behind me, so it is one way in and out. Made aprox. 10 landings over two days visit last July. Field elevation is 4100'. I had to use my new brakes once on day two with a tailwind.
Oh. I almost forgot to mention that I don't have VG's
 Filesize:  226 KB
 Viewed:  768 Time(s)
Roger in Oregon
1992 KXP 503 - N1782C
JetPilot
PostPosted: Mon Jan 14, 2008 8:31 am    Post subject: Re: VG's effect on Runway Leingth Reply with quote
I was hoping someone would see the humor in that Smile When I saw how that picture turned out, I just had to post it. At 11,200 feet long, even the newbies I often let fly can hit it most of the time...
That does look short ! Do you go over, or turn away from the power lines ? The cows in the next field look like interesting targets Wink Do they run or just ignore you as you fly over ?
Mike
Russ Kinne
PostPosted: Mon Jan 14, 2008 8:46 am    Post subject: VG's effect on Runway Leingth Reply with quote
Cows run. Where do you think whipped cream comes from??
[Wink] Do they run or just ignore you as you fly over ?
Mike
&quot;NO FEAR&quot; - If you have no fear you did not go as fast
http://forums.matronics.com/viewtopic.php?p=158011#158011
