Commander Heater Photos
moe(at)rosspistons.com
PostPosted: Tue Jan 01, 2008 11:59 am    Post subject: Commander Heater Photos Reply with quote
Sorry these are so late. N680RR was locked in the hanger where the annual
is being done.
Moe
DSCN1105
DSCN1100
DSCN1101
DSCN1102
DSCN1103
DSCN1104
 Filesize:  146.4 KB
 Viewed:  348 Time(s)
 Filesize:  99.62 KB
 Viewed:  361 Time(s)
 Filesize:  80.07 KB
 Viewed:  347 Time(s)
 Filesize:  67.21 KB
 Viewed:  359 Time(s)
 Filesize:  42.16 KB
 Viewed:  347 Time(s)
 Filesize:  78.9 KB
 Viewed:  351 Time(s)
Kamala(at)MSN.COM
PostPosted: Tue Jan 01, 2008 3:51 pm    Post subject: Commander Heater Photos Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> mm, appox how much $ was the conversion? gmc
dfalik(at)sbcglobal.net
PostPosted: Tue Jan 01, 2008 4:02 pm    Post subject: Commander Heater Photos Reply with quote
The conversion for my 500S from the janitrol to the CD unit including the solid state controller (an option) was in the neighborhood of $3500.00.
Don
tfisher(at)commandergroup
PostPosted: Wed Jan 02, 2008 7:02 am    Post subject: Commander Heater Photos Reply with quote
Thanks Moe, the images turned out great,
If you also have any showing the routing of all the air ducts then we can
figure out what we can pull out in the way of old plumbing and components
related to the pressurization and air conditioning both of which I no longer
have.
Tom.
C-GISS
PostPosted: Sun Jan 06, 2008 8:13 pm    Post subject: Commander Heater Photos Reply with quote
Hi Tom,
Please excuse me for being so slow to reply, however, I retired at the end
of the year and have experienced a few email problems while moving from the
Ross office to my new private hobby shop office.
If it will help you, I can scan the pages from the
Commander book which show a pretty good diagram of how the system works.
Please advise if you need them.
Moe
PostPosted: Sun Jan 06, 2008 8:16 pm    Post subject: Commander Heater Photos Reply with quote
Mason,
A little over $ 3,000.00 as I recall, which is less than the fuel bill to Micxhigan from Hawthorne, CA.
Moe
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of MASON CHEVAILLIER
Sent: Tuesday, January 01, 2008 3:51 PM
Subject: Re: Commander Heater Photos
John Vormbaum
PostPosted: Sun Jan 06, 2008 8:35 pm    Post subject: Commander Heater Photos Reply with quote
Moe, congrats on your retirement! Will you have a phone, or will we
still have to tell the sentry that we're "from the airport" if we want
to talk to you?
Smile
/John
Moe - Ross Racing Pistons wrote:
Hi Tom,
Moe
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Sun Jan 06, 2008 9:47 pm    Post subject: Commander Heater Photos Reply with quote
Thanks for the offer, I have the commander books but they don't show me what
a modified system might be set up like as I have the Mr. RPM conversion
without the air conditioning or pressurization. So if someone with that
configuration could take images. I do not have the scoop on top of the
aircraft, should I? I have no idea.
Tom.
rcdettmer(at)charter.net
PostPosted: Mon Jan 07, 2008 1:24 pm    Post subject: Commander Heater Photos Reply with quote
Hi Moe,
As you may know, I am currently having re-built engines installed on my 680F. I am concerned that the props may have metal in them from the engine failures, and may need to be overhauled. Do you know what the TBO is on those props..?? They were overhauled about 700 hours ago. Thanks.
<![if !supportEmptyParas]> <![endif]>
Randy Dettmer, AIA
680F / N6253X
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->[img]cid:image001.gif(at)01C8511C.AB176370[/img]
Dettmer Architecture
663 Hill Street, San Luis Obispo, CA 93405
805 541 4864 / Fax 805 541 4865
http://www.dettmerarchitecture.com/
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com]On Behalf Of Moe - Ross Racing Pistons
Sent: Sunday, January 06, 2008 8:16 PM
Subject: RE: Commander-List: Commander Heater Photos
Mason,
Moe
Subject: Re: Commander-List: Commander Heater Photos
----- Original Message -----
From: Moe - Ross Racing Pistons (moe(at)rosspistons.com)
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Sent: Tuesday, January 01, 2008 1:57 PM
Subject: Commander Heater Photos
is being done.
Moe
DSCN1105
DSCN1100
DSCN1101
DSCN1102
DSCN1103
DSCN1104 <![if !supportLineBreakNewLine]> <![endif]>
<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]>href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-Listhref="http://forums.matronics.com">http://forums.matronics.com<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Commander-List Email Forum - --> http://www.matronics.com/Navigator?Commander-List   - MATRONICS WEB FORUMS - --> http://forums.matronics.com   - List Contribution Web Site - Thank you for your generous support!     -Matt Dralle, List Admin. --> http://www.matronics.com/contribution<![if !supportEmptyParas]> <![endif]>
 Filesize:  2.97 KB
 Viewed:  7601 Time(s)
yourtcfg(at)aol.com
PostPosted: Mon Jan 07, 2008 6:40 pm    Post subject: Commander Heater Photos Reply with quote
There is no "official" TBO on Hartzell propellers. They like them to be O/H every 60 calendar months, with no regard to time in service. The metal from the engines should have caused no trouble in the props. There is only one "O" ring that would have been affected. It is the large ring on the prop dome. You mechanic should have flushed the propellers and replaced that "O" ring, and the other two, when they installed the propellers on the new engiens. jb
 Filesize:  2.97 KB
 Viewed:  7606 Time(s)
BobsV35B(at)aol.com
PostPosted: Mon Jan 07, 2008 8:01 pm    Post subject: Commander Heater Photos Reply with quote
Not Moe here, but would you consider having them inspected and relubed rather than overhauled?
If an approved shop does an "Overhaul", they are required to grind the blades for stress relief. The IRAN is generally a better idea for a prop that has a potential of metal contamination.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 1/7/2008 3:25:28 P.M. Central Standard Time, rcdettmer(at)charter.net writes:
Hi Moe,
Randy Dettmer, AIA
680F / N6253X
Start the year off right. Easy ways to stay in shape in the new year.
jtaddington(at)verizon.ne
PostPosted: Mon Jan 07, 2008 8:52 pm    Post subject: Commander Heater Photos Reply with quote
I will through my two cents in. You don't have to worry about an official TBO, Hartzell will come out with an AD every very few years that will end up in an over haul or parts replacement.
Jim A
N444BD
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of yourtcfg(at)aol.com
Sent: Monday, January 07, 2008 8:27 PM
 Filesize:  2.97 KB
 Viewed:  7602 Time(s)
PostPosted: Mon Jan 07, 2008 9:25 pm    Post subject: Commander Heater Photos Reply with quote
John, Thank you for the congratulations. My cell phone number is
310.350.4594. We do not have a home phone number, so I can always be
reached on the cell phone. There will be no screen unless you are a bill
collector, The Los Angeles Times wanting me to subscribe, an attorney, a
politician or a cheritable organization seeking donations, in which case "no
habla English" or any other language known to man.
Best regards,
Moe
N680RR
680F(p)
PostPosted: Mon Jan 07, 2008 9:40 pm    Post subject: Commander Heater Photos Reply with quote
Hi Randy,
It appears that these guys are giving you wise council.
Moe
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of JTAddington
Sent: Monday, January 07, 2008 7:04 PM
Subject: RE: Commander Heater Photos
Jim A
N444BD
From: Randy Dettmer, AIA <rcdettmer(at)charter.net>
Sent: Mon, 7 Jan 2008 11:01 am
Hi Moe,
Randy Dettmer, AIA
680F / N6253X
[img]cid:505232705(at)08012008-00B2[/img]
From: owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com) [mailto:owner-commander-list-server(at)matronics.com ([email]owner-commander-list-server(at)matronics.com?[/email])]On Behalf Of Moe - Ross Racing Pistons
Mason,
Moe
From: owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com) [mailto:owner-commander-list-server(at)matronics.com ([email]owner-commander-list-server(at)matronics.com?[/email])] On Behalf Of MASON CHEVAILLIER
Subject: Commander-List: Commander Heater Photos
is being done.
Moe
DSCN1105
DSCN1100
DSCN1101
DSCN1102
DSCN1103
DSCN1104
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-Listhref="http://forums.matronics.com">http://forums.matronics.com < /SPAN> - The Commander-List Email Forum -
size=2 width="100%" align=center>
More new features than ever. Check out the new AOL Mail!
 Filesize:  2.97 KB
 Viewed:  7600 Time(s)
PostPosted: Tue Jan 08, 2008 7:43 am    Post subject: Commander Heater Photos Reply with quote
Yes, thanks for the excellent input. We will be flushing out the props and giving them an inspection.
RD
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->[img]cid:image001.gif(at)01C851C2.39073CA0[/img]
Sent: Monday, January 07, 2008 9:28 PM
Hi Randy,
Moe
Jim A
N444BD
 Filesize:  2.97 KB
 Viewed:  7604 Time(s)
 Filesize:  2.97 KB
BillLeff1(at)aol.com
PostPosted: Thu Jan 10, 2008 7:31 pm    Post subject: Commander Heater Photos Reply with quote
No need to overhaul the props. Just ave them cleaned out, or have them dissassembled inspected, reassembled and returned to service. Overhaul is 2500 hrs or 12 years.
Bill Leff
