AEC9004 Status?
jskiba(at)icosa.net
PostPosted: Sun Dec 30, 2007 5:07 pm    Post subject: AEC9004 Status? Reply with quote
I guess this is more of a question for BOB but I figured the list might have
info on it also:
I was getting ready to do my Electrical system Final design after many
different version - ideas and after re-reading several articles and "the
book". I seem to need to know what the current status of the new AEC9004
Alternator controller.
My understanding is that this device will be able to control an internally
regulated Alternator on-off and also be able to handle the "possibility" of
"load dump" triggered by Crow bar Over volt protection in the current z24
diag.
Ref article:
http://www.aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf
If it is not done, time frame?
Are there any changes to the doc to do until it is ready?
I have an internally regulated alternator, and am planning on getting an
SD-20 for emergency mode of main alternator failure.
Thanks in advance
jskiba(at)icosa.net
PostPosted: Mon Dec 31, 2007 7:34 am    Post subject: AEC9004 Status? Reply with quote
AS a follow up I did a little tweaking on z-14 to illustrate what I mean...
It's attached... please let me know what I am missing as far as adding the
Bridge diodes for both fuel pumps and ECU.
Aka I still have the below questions
Thanks and HAPPY NEW YEAR
Z14_fadec_Model_(1).pdf
 Filename:  Z14_fadec_Model_(1).pdf
 Filesize:  139.77 KB
 Downloaded:  293 Time(s)
nuckolls.bob(at)cox.net
PostPosted: Mon Dec 31, 2007 10:56 am    Post subject: AEC9004 Status? Reply with quote
At 09:25 AM 12/31/2007 -0600, you wrote:
[quote]AS a follow up I did a little tweaking on z-14 to illustrate what I mean...
