hagargs(at)earthlink.net Guest
Posted: Sun Dec 30, 2007 11:37 am Post subject: Europaprecision? |
Fred:
I find it contrary to the general consensus that you are struck by the
high degree of precision built into the kit. I was struck by what I
considered that each and every model seems to me to be custom built. Many
of the questions on the forum seek the solution to something not fitting or
lining up right. My aircraft flies true but that is only because of the
many hours making fixtures and jigs to line things up or to purposely make
something slightly misaligned so that the left of the aircraft looks
exactly like the right. Having a mill and lathe in the garage was a
godsend. I had developed a high degree of patience and manual dexterity in
crafting the plane. However now that I am older I seem to have lost alot
of the patience.
Old business: I have tore into the top of the cockpit seatback to get at
the gas tank to pull it out because of the crack. Once the top was off what
was present was slightly disturbing. We have our extra support pads to
keep the tank from pooching into our spar cavity and interfering with the
aileron belcrank rod. Every interior surface looks like that. The top of
the tank is vavy from expansion and the back surface exhibits the same
condition. In all cases flat surfaces of the tank are stressed and buckled
because of the expansion. You just don't see it unless you take the lid
off.
I made note to a motorhead friend of mine at work that my airplane had
gotten a crack in its gas tank. He knows nothing of Europas or of
homebuilt aircraft. He asked me if I had a rotomolded polyethelyne tank.
I said yes. He asked me if I left the tank dry for awhile. Yes again. He
noted to me that there is a kit car company out there that makes custom
tanks as these for cars. The company specifically states that if you mount
the tank by fiberglassing it in and let it dry out. It will crack and they
assume no responsibility. You are supposed to buy their mounting kit and
strap it in.
In any case I don't believe I am going to put my replacement polyethelyne
tank back in the aircraft. I am going to pursue making an aluminum
(aluminium for you other guys) tank up with AN fittings.
Also I also have a pair of reamers available 16 and 16.5 mm, one for the
rough cut and one for the fine cut. I have cut them short and machined a
hex on each end. That way you don't have to pull the endine way out and
you can put a ratchet on the end to run them home.
Check some photos of the tank and the crack attached.
Steve Hagar
A 143
Mesa AZ
| Quote: | [Original Message]
To: <europa-list(at)matronics.com>
Date: 12/28/2007 5:57:40 PM
Subject: Europaprecision
Hi Guys...and Happy New Year
From time to time in the course of building I am struck by the high
degree of precision built into our kits. While I salute the company for
its high quality precision parts, I'm finding that occasionally I
haven't done my part (at least the first time around) in ensuring that
the end result measures up to the standard required for the eventual
hours of trouble-free flying which so many of you (sigh) are already
enjoying.
For those of you who are still a'buildin' the monowheel and have yet to
assemble the main landing gear, here's a pitfall I stepped into which
is easily avoided...with just a tad of forethought:
When installing the bushes in the shock absorber bottom plate (now
that's a bit of heavy iron!) LG07, do NOT loctite them in until AFTER
you have ensured that you have smooth rotation on the pin LG04. I
failed to do this and found that my bushes were mis-aligned just enough
to cause the pin to bind...if left in this way, there's no doubt in my
mind that the bushes wouldn't be able to do their job and the result
would be wear in the holes for the pin in the swing arm LG02 and LG02A
which I fear would shortly introduce all kinds of slop.
As a consequence of my mistake, I have attempted to use heat to loosen
the loctite bond to no avail...even w/ a propane torch (while taking
care to not mar my nicely powdercoated LG07). Attempts to remove the
bushes are complicated by the soft nature of the bearings.
Sooooo....I've just received 2 new bushings from mcmaster-carr (P/N
6391K178) and my plan is to drill out the offending bushes and 'ave
another go.
This time I'll do a trial assembly of all the parts which the pin LG04
passes through before indulging w/ the loctite.
Old Pennsylvania Dutch saying: Why do I get so late smarter?
Fred
A194
believed to be clean.
82.82 KB |
269 Time(s) |
99.92 KB |
262 Time(s) |
37.38 KB |
229 Time(s) |
fklein(at)orcasonline.com Guest
Posted: Sun Dec 30, 2007 1:02 pm Post subject: Europaprecision? |
On Sunday, Dec 30, 2007, at 11:33 US/Pacific, Steve Hagar wrote:
| Quote: | I have tore into the top of the cockpit seatback to get at
what
to
the
top of
buckled
lid
off.
Steve,
Thanks for sharing your frustrations w/ your fuel tank and passing on
your thoughts on the issue of cracking....sobering thoughts and pixs
indeed. A couple of questions:
- When you say "extra support pads", do you mean that you installed
some pads in addition to those called for?...If so, can you describe
them?
- At some point, I seem to recall that the supplied tanks were changed
in some way to eliminate or reduce expansion. When did you purchase
your original tank? Do you know if you have one of the earlier or later
versions of the tank?
- Do you attribute your tank's failure (in part) to any extreme
temperature conditions which it may have been exposed to in your part
of the world?
To Anyone: Would you be willing to share any protocols you follow which
you believe will guard against tank shrinkage and stress cracking?
| Quote: | I made note to a motorhead friend of mine at work that my airplane had
tank.
again. He
custom
mount
they
and
strap it in.
I got to confess that I questioned (to myself) the implications of
fibreglassing in a tank which is subject to expansion, but blithely
went ahead and installed it per plans, ignoring that little voice
saying, "Hey...this can't be good, there's got to be a better way!"
As for my previous post about my opinion of the high degree of
precision built into the kit, I made that as an architect and
homebuilder, not as a machinist, so the world of tight tolerances is
one in which I've had virtually no direct experience. I do marvel at
some of the various hardware assemblies and know that if left to my own
devices for fabrication the results would not be
satisfactory...sometimes the designs seem a bit too clever but that's a
story for another time.
| Quote: | Also I also have a pair of reamers available 16 and 16.5 mm, one for
the
machined a
and
That sounds excellent...thanks for your offer to make them available to
others!
Regards and good luck w/ getting your plane back in the air soon,
Fred
karelvranken(at)hotmail.c Guest
Posted: Sun Dec 30, 2007 1:49 pm Post subject: Europaprecision? |
Steve,
Most of us are "older". Nevertheless I admire your courage. You will find
every time the solution for the problems that occur. May 2008 be for you
without new mods and without old misfits. Think about the joy when you will
fly your bird very soon.
Happy New Year.
Karel Vranken F-PKRL.
gregoryf.flyboy(at)comcas Guest
Posted: Sun Dec 30, 2007 5:25 pm Post subject: Europaprecision? |
Steve,
Keep us informed, if you come up with a solution. It would be intriguing to
try something else. I saw a picture somewhere of one other member that built
an aluminum tank.
Thanks for the informative pics.
Greg.
-----snip-----
Steve Hagar
A 143
Mesa AZ
craigb(at)onthenet.com.au Guest
Posted: Mon Dec 31, 2007 12:04 am Post subject: Europaprecision? |
Steve
just on the subject of tanks and making new ones, Have you considered making
a tank out of carbon fiber and vinyl-ester resin
One of the fibreglass sellers i know tells me it is virtually totally
chemically resistant and if you add wax in styrene to the resin
it's even better again. I intend to try it and find out for myself with a
test tank, I told him if was for an aircraft and he wasnt concerned at all,
which
given everybodys desire to cover their asses or not even deal with aircraft
because of the liability issues speaks volumes. The resultant tank
would be very light and very strong and rigid, Could be a better way to go.
only issue i can see, is you cant use vinylester and epoxy together
as it wont bond properly, I was told, so you would have to make mounts and
bolt it in, which may not be such a bad idea
craig
avgashead(at)btinternet.c Guest
Posted: Mon Dec 31, 2007 12:33 am Post subject: Europaprecision? |
Does anybody know who made and supplied the few fibreglass tanks that
were available to builders in the UK? I bought my kit with the tank
already fitted into the cockpit module, and from distant memory,(it was
two and a half years ago that I bonded the module in) the tank is
mounted in the same way as the polyethelyne one.
A weight penalty is inevitable but I'm trusting that the glass tank will
give me better service and not be so prone to distortion as the factory
issue.
Richard Scanlan
#103, wiring and upholstery to go.
Posted: Mon Dec 31, 2007 5:08 am Post subject: Europaprecision? |
No problem with vinyl ester, but I would recommend to use glass instead
of carbon. Carbon is too stiff and would stop the airplane flexing.
Graham
craig bastin wrote:
Steve
Posted: Mon Dec 31, 2007 5:34 am Post subject: Europaprecision? |
yes the one i intend to make as a test, will be glass an vinyl ester.
craig
Posted: Mon Dec 31, 2007 5:55 am Post subject: Europaprecision? |
Those support pads that are "called for" are indeed "extra" as they were
not in the original design and were put in as an afterthought when problems
started coming about. The tank I have is one of the later versions as the
replacement I have is exactly the same.
Yes is does get hot here, however this has happened to others and it
seems issues point to the fact that this material and the mounting design
don't lend themselves to having the tank being emptied allowing it to dry
out and have the material migrate. The SOP with aircraft is to refuel
them before you put them away so this We could do a scientific experiment
and have every one drain their tank and let them sit for six to 10 weeks
and find out what the failure rate is. The issue is that this is an issue
and as I have noted another manufacturer has issued a warning about this
and now this should be formally documented as a characteristic of the
aircraft.
I did think of possibly molding a unit up from another material as kevlar
or graphite however another individual mentioned that it would have to be
bolted or otherwise mounted securely mounted in other than bonding.
However I hate to act as a guinea pig on something that is not in
widespread use. If I changed the mounting routine to something other than
bonding, the polyethelyne tank would probably be more than satisfactory and
that may be exactly what I do if the cost and logistics of making an
aluminum tank become too onerous. I don't believe an aluminum tank would be
bonded in either. I was sent a photo of an aluminum tank. I would very
much like to know how it was installed and what kind of service it is
giving if you are out there listeninng?
Steve Hagar
A143
Mesa AZ
Date: 12/30/2007 2:11:22 PM
Subject: Re: Europaprecision?
> what
> to
> the
> top of
> buckled
> lid
> off.
Steve,
them?
of the world?
> tank.
> again. He
> custom
> mount
> they
> and
> strap it in.
> the
> machined a
> and
others!
Fred
pat(at)zbit.net Guest
Posted: Mon Dec 31, 2007 6:14 am Post subject: Europaprecision? |
Steve how many hours is on this plane?
How much heavier will the aluminum tank be?
Pat Ellison
FSX sim Europa (poor subsitute but all I have now!)
Wellington, FL
Posted: Mon Dec 31, 2007 8:13 am Post subject: Europaprecision? |
you will need to check the sizing on the glass cloth. Not all sizing is
compatible with ester resins. The sizing helps bonding of the resin to
the glass fibers
Graham
craig
budyerly(at)msn.com Guest
Posted: Mon Dec 31, 2007 1:47 pm Post subject: Europaprecision? |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Sorry to get into this so late but on the subject of fiberglass tanks.
Grahm is correct about the carbon fiber. The tank needs to move with the plane. I haven't had the courage to fill my four year empty tank. Pray for me.
On the fiberglass resins for fuel tanks consider a hard lesson learned by my friends at Tampa Bay Aerosport. They had to disassemble a wing to remove the tanks after a gas station accidentally added ethanol to the premium fuel. Even the vinyl ester is affected as it turns it into a sticky sludge. Epoxy is worse. I never knew that the resins were so intolerant to ethanol. If you use auto fuel rather than 100LL keep an ethanol tester handy or only get auto fuel from a trusted fuel depot. For normal gasoline and av-gas, you'll have no problem. If you are unlucky like us in the green state of Florida many of our stations are adding 10% ethanol to all blends, they are supposed to post it on the pumps so be careful.
The boating industry up north has sealed all their tanks (mostly poly and vinyl ester tanks) with a special coating for the inside of fiberglass tanks which makes them impervious to ethanol. I'll see if I can get a brand name and pass it on.
Bud Yerly
Posted: Mon Dec 31, 2007 2:21 pm Post subject: Europaprecision? |
The coating MAY be the "wax in styrene" that i was told i "Should" use but didnt have to. It is added to the vinyl ester to make it non porous
at a molecular level apparently. Lets face it though, in most places the use of Auto fuel with ethanol is not allowed for aviation. At this point
about 60% of the fuels in Australia have ethanol in them, and MOST of the 98 and 100 octane fuels have at least 5% ethanol.
When I eventually get to the test sample tank, i will try the "wax in styrene" and then test it with a 50% ethanol blend and let you all know the results.
craig
[quote] --
