Backup alternator questions
mike.corder(at)sbcglobal.
PostPosted: Fri Dec 28, 2007 7:53 pm    Post subject: Backup alternator questions Reply with quote
I have the B&C 8 amp backup alternator along with a main Plane Power 60
amp unit. When I have them both on line, it seems like the voltage jumps
around a lot. Suspect the two voltage regulators are "fighting" each
other as voltage is stable with either unit running by itself. Is this a
problem ?
I'd like to leave the backup unit offline and only bring it online when
the primary unit goes away. However, since both warning lights are taken
to Ground to light up, I can't figure out a circuit which would allow
this mode of operation. Any suggestions ?
m
____________________________
mike.corder(at)sbcglobal.net
Cell 831-239-0915
nuckolls.bob(at)cox.net
PostPosted: Sat Dec 29, 2007 8:03 am    Post subject: Backup alternator questions Reply with quote
around a lot. Suspect the two voltage regulators are "fighting" each other
as voltage is stable with either unit running by itself. Is this a problem ?
Won't hurt anything but these two devices were
not designed nor intended to operate together.
to Ground to light up, I can't figure out a circuit which would allow this
Wire per 13/8 and leave the waring light off
the SD8.
( -Thomas Paine 1776- )
andrewbutler(at)ireland.c
PostPosted: Sat Dec 29, 2007 11:50 am    Post subject: Backup alternator questions Reply with quote
Hi Mike,
Attached is my Z13/8 variation that splits the bus for dual power supply to an electronic ignition with a cross over relay in case either power supply fails.
Haven't wired it up yet, but this is my general plan. I also struggled with a low voltage warning for each power supply prior to splitting the bus, and I ended up concluding that it doesn't make real sense unless the bus is split.
In practise, I will probably monitor the backup bus voltage from my AFS3500 EFIS, that allows you to hook up a primary and secondary power source and then set alarms on each.
Andrew.
[quote]---
Dual_Batt_&_Alt_-_8Amp_Backup_-_Split_Bus.pdf
 Filename:  Dual_Batt_&_Alt_-_8Amp_Backup_-_Split_Bus.pdf
 Filesize:  491.82 KB
 Downloaded:  237 Time(s)
