Lyle Persels
Posted: Wed Dec 26, 2007 3:02 pm Post subject: Tubes for Kingfox tires |
I have a set of Kingfox 22x12x8 smooth tires on my Model
IV-1200/912uls. Grest tires!. Yesterday I had a valve stem twist off
when a tire rotated on the rim on landing. Can anyone give me a
source for tubes for these tires? The tubes are marked 22X11-8.
What tire pressure are others using in this tire?
Lyle Persels
Model IV-1200/450 hrs
Rotax 912 ULS
akanka(at)kiamichiwb.org Guest
Posted: Wed Dec 26, 2007 3:42 pm Post subject: Tubes for Kingfox tires |
Just about any ATV dealership should have them. That's a common ATV tire
and tube size.
John Hart
kitfoxpilot(at)msn.com Guest
Posted: Wed Dec 26, 2007 7:56 pm Post subject: Tubes for Kingfox tires |
You can get tubes at your local lawn and tractor shop!
| Quote: | To: kitfox-list(at)matronics.com
Subject: Kitfox-List: Tubes for Kingfox tires
Date: Wed, 26 Dec 2007 16:00:26 -0600
--> Kitfox-List message posted by: Lyle Persels <lpers(at)mchsi.com>
Lyle Persels
Get the power of Windows + Web with the new Windows Live. Get it now!
david.steade(at)btinterne Guest
Posted: Thu Dec 27, 2007 1:41 am Post subject: Tubes for Kingfox tires |
Lyle
One thing to check when you get your new tubes is what is causing the problem. Most people in the UK run their tyres tube less but I and a friend ran with tubes. Despite positively checking that the tyres never moved on the rim tubes still seemed to occasionally fail.
What seems to happen is that at the low pressures of 8 psi or so, over a long period of time the tubes worked themselves round inside the tyre. Hard to believe but true.
The remedy was simple about 4 times a year I took the valve from the tyre and with it completely deflated gave the tyre a massage.
Sometimes as the tube deflated I could here the tube reposition.
David
ksridsdale(at)mipowerpara Guest
Posted: Thu Dec 27, 2007 2:07 am Post subject: Tubes for Kingfox tires |
Lyle
Purchase your tubes for the King Fox tires from Tires
Express
www.tireexpress.com
your part number is 157-1449 the cost is $10.35 ea.
plus shipping. ($32.70 TOTAL)
This is what we reccomend if a customer really wants
to use a tube with the King Fox tire.
Kevin R.
Mippi Ultralights
--- RAY Gignac <kitfoxpilot(at)msn.com> wrote:
shop!> To: kitfox-list(at)matronics.com> From:
lpers(at)mchsi.com> Subject: Tubes for
Kingfox tires> Date: Wed, 26 Dec 2007 16:00:26
-0600> >
Persels <lpers(at)mchsi.com>> > I have a set of Kingfox
22x12x8 smooth tires on my Model > IV-1200/912uls.
anyone give me a > source for tubes for these tires?
The tubes are marked 22X11-8.> > What tire pressure
are others using in this tire?> > Lyle Persels>
Mod========================> _==============> > >
mikeperkins
Posted: Fri Dec 28, 2007 8:54 am Post subject: Tubes for Kingfox tires |
Might try some rubber glue on the inside of the tires.
