chuck(at)chuckdirect.com Guest
Posted: Tue Dec 18, 2007 11:24 am Post subject: Strobe and Antenna Wire in Same Conduit |
Has anyone run their Strobe wire and Antenna wire in the same conduit? Results?
Chuck
Posted: Thu Dec 20, 2007 9:10 am Post subject: Strobe and Antenna Wire in Same Conduit |
Has anyone run their Strobe wire and Antenna wire in the same wing conduit? Any interference or other problems? My Electronics guru says there should be none since all wires are shielded. Anyone?
Chuck
ScooterF15
Posted: Thu Dec 20, 2007 9:19 am Post subject: Strobe and Antenna Wire in Same Conduit |
The strobe wire and nav antenna coax are in the same bundle on the way out to the wingtip on my RV-10. If I remember right, I believe I can hear the faintest tick-tick-tick from the strobes when listening to NAV audio. It's hardly noticeable.
-Jim
N312JE
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
In a message dated 12/20/2007 12:12:01 P.M. Eastern Standard Time, chuck(at)chuckdirect.com writes:
| Quote: | Has anyone run their Strobe wire and Antenna wire in the same wing conduit? Any interference or other problems? My Electronics guru says there should be none since all wires are shielded. Anyone?
Chuck
See AOL's top rated recipes and easy ways to stay in shape for winter.
coop85(at)cableone.net Guest
Posted: Thu Dec 20, 2007 4:19 pm Post subject: Strobe and Antenna Wire in Same Conduit |
No interference with my setup, in fact (oddly enough) the slight background hum decreases when I turn the strobes on!
Marcus
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chuck Weyant
Sent: Thursday, December 20, 2007 11:10 AM
Subject: Strobe and Antenna Wire in Same Conduit
Chuck
0123456789012345
