gerf(at)gerf.com Guest
Posted: Tue Dec 18, 2007 2:37 pm Post subject: Favorite greasy belly cleaner ? |
(Its a little off topic since it relates to my RV-9)
Do you guys have a favorite cleaner for the "greasy belly" ? I've heard of
the Stoddard cleaner which is supposed to be pretty evil stuff. Simple
Green apparently has issues if used on bare aluminum. There's such a range
of products on Spruce that I don't know where to start ...
Gerry
http://www.n747wg.com
(Haven't opened the box yet.)
Posted: Tue Dec 18, 2007 3:49 pm Post subject: Favorite greasy belly cleaner ? |
Spruce sells a Simple Green Extreme/Aviation that is supposed to not
be a problem on aluminum.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Dec 18, 2007, at 5:35 PM, Gerry Filby wrote:
heard of
Simple
a range
Gerry
rv(at)thelefflers.com Guest
Posted: Tue Dec 18, 2007 5:09 pm Post subject: Favorite greasy belly cleaner ? |
It works wonders on my Cherokee 180.....
Posted: Tue Dec 18, 2007 6:30 pm Post subject: Favorite greasy belly cleaner ? |
A friend gave me a tip to use Scrubbing Bubbles (spray) and it works
GREAT. Spray on, wipe oil off. I have no idea if it has anything bad for
aviation related components. I have only used it a few times.
Robin
DAVELEIKAM(at)wi.rr.com Guest
Posted: Tue Dec 18, 2007 7:53 pm Post subject: Favorite greasy belly cleaner ? |
What about good old Windex or 409? I do not know if either of these would
hurt AL however. They are both good, mild grease cutters.
Dave Leikam
40496
apilot2(at)gmail.com Guest
Posted: Tue Dec 18, 2007 8:24 pm Post subject: Favorite greasy belly cleaner ? |
Windex contains ammonia, which is bad for aircraft and plexi. IIRC 409
also is corrosive.
Dave Leikam
40496
wvu(at)ameritel.net Guest
Posted: Tue Dec 18, 2007 9:19 pm Post subject: Favorite greasy belly cleaner ? |
Joe Zac suggested WD-40 sometime back. Works great.
Anh
N591VU-115hrs
In the middile of Condition Inspection
flysrv10(at)gmail.com Guest
Posted: Wed Dec 19, 2007 3:02 am Post subject: Favorite greasy belly cleaner ? |
Use Goop. The hand cleaner they sell at WallMart. The white color can.
Have used it on my 6 for 10+ years without any ill effects. I figure
if it is good enough for your hands, it is good enough for aluminum.
Rob.
heard of
Simple
a range
Gerry
groves(at)epix.net Guest
Posted: Wed Dec 19, 2007 11:51 am Post subject: Favorite greasy belly cleaner ? |
Good old WD-40
On Dec 18, 2007, at 5:35 PM, "Gerry Filby" <gerf(at)gerf.com> wrote:
heard of
Simple
a range
Gerry
Posted: Thu Dec 20, 2007 10:44 am Post subject: Favorite greasy belly cleaner ? |
Thanks all for the suggestions ...
I happen to have a big can of WD-40 lying around - it seems to work a treat
g
