		CJohnston(at)popsound.com Guest
				 Posted: Tue Dec 18, 2007 12:47 pm    Post subject: Cooling tube on lightspeed ignition box? |
				Hey all –
 I was monkeying around with the install of my LSE ignition box and in the instructions it says:
 On 6-cylinder systems, cooling air should be supplied to the box via the cooling port on the 15-pin connector side of the ignition module.  For 6-cyl. systems that do not have a cooling port, contact LSE for this modification.  Cooling is not required for 4-cyl. systems.
 I’m wondering how others routed cooling air into this small (3/8” ish) tube on the side of the unit?  any suggestions?
 Thanks!
 cj
 www.perfectlygoodairplane.net
		zackrv8
				 Posted: Tue Dec 18, 2007 7:01 pm    Post subject: Re: Cooling tube on lightspeed ignition box? |
				CJ,
   I bought a 3 port blower fan from Stein.  I will use the other ports for the Avionics LRU's and one for the Lightspeed.
 Zack
  _________________ RV8 #80125
RV10 # 40512 |
		bcondrey
				 Posted: Wed Dec 19, 2007 6:13 am    Post subject: Cooling tube on lightspeed ignition box? |
				Chris,
 I made an adapter to reduce the standard 5/8” cooling tube down to 3/8 out of some sort of poly tubing that I found at a home improvement store.  Seemed to work pretty well.
 Bob
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston
  Sent: Tuesday, December 18, 2007 2:47 PM
  Subject: Cooling tube on lightspeed ignition box?
 Hey all –
 Thanks!
 cj
    0123456789012345
		drfred(at)suddenlinkmail. Guest
				 Posted: Wed Dec 19, 2007 9:39 am    Post subject: Cooling tube on lightspeed ignition box? |
				zackrv8 wrote:
 Zack:
 I'm getting ready to start assembly of the panel and associated boxes.
 Any chance you could take a pic of your installation?  Trying to get
 placement of items solidified in my mind.
 Fred
 40515.  On the gear, starting wheel pants.
		PILOTDDS(at)aol.com Guest
				 Posted: Sat Dec 22, 2007 3:22 pm    Post subject: Cooling tube on lightspeed ignition box? |
				For those of us with older lightspeeds Klaus wants them returned for internal updates as well as a provision for cooling tubes.I should have put those boxes where they were easier to get to.
 See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004)  [quote][b]
		mritter509(at)msn.com Guest
				 Posted: Sat Dec 22, 2007 4:13 pm    Post subject: Cooling tube on lightspeed ignition box? |
				What's the definition of an "older Lightspeed"?  I've had my Plasma 111 going on three years.
  Mark
  RV-10/N410MR
  170 hours
 <html><div></div></html>
   	  | Quote: | 	 		    From: PILOTDDS(at)aol.com
 Date: Sat, 22 Dec 2007 18:22:13 -0500
 Subject: Re: Cooling tube on lightspeed ignition box?
 See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004)  	  | Quote: |
 get=_blank>http://www.matronics.com/Navigator?RV10-List
 p://forums.matronics.com
  | 	  Share life as it happens with the new Windows Live. Share now!
				 Posted: Sat Dec 22, 2007 4:34 pm    Post subject: Cooling tube on lightspeed ignition box? |
				If it didnt come with a provision for a cooling tube you are effected.Three years is about the timeline, although Klaus was not specific to the date.
