VHMUM(at)bigpond.com Guest
Posted: Thu Dec 20, 2007 3:03 pm Post subject: Headset jacks |
OK dumb question with headset jacks.....Headphone and mic jacks have the
same number of terminals but one has a larger hole than the other. So which
one is Mic and headphone
regards Chris
wcurtis(at)nerv10.com Guest
Posted: Thu Dec 20, 2007 3:24 pm Post subject: Headset jacks |
The smaller one is the mic. The outer is ground, the "tip" is the PTT and the "ring" is mic audio.
The larger one is the earphone. The outer is ground, the "tip" is earphone audio left, the "ring" is earphone audio right.
Most don't wire the "tip" on the microphone jack, but the benefit of wiring it is that that in a pinch, you can connect a regular hand mic with a PTT into the jack and it will work.
William
http://wcurtis.nerv10.com/
"Be who you are and say what you feel because those who mind don't matter and those who matter don't mind."
-- Dr. Suess
rnewman(at)tcwtech.com Guest
Posted: Thu Dec 20, 2007 3:27 pm Post subject: Headset jacks |
The bigger one is for the headphones. 1/4" diameter.
jpiamber(at)yahoo.com Guest
Posted: Thu Dec 20, 2007 4:00 pm Post subject: Headset jacks |
The larger is for the Headphones quarter inch if I recall correctly.
JP Instruments
Amber Wilson
FAA STC Administrator
JPIAmber(at)yahoo.com (JPIAmber(at)yahoo.com)
800-945-4574 X204
Find them fast with Yahoo! Search. [quote][b]
