dpharker(at)worldnet.att. Guest
Posted: Tue Dec 18, 2007 9:49 am Post subject: Marker Beacon Diplexer Question |
I plan to have one marker beacon antenna feed two marker beacon receivers.
Comant makes a diplexer CI-509 that does this and it costs about $110.
Anybody see a problem with using a plain old VHF splitter for a TV set to do
this? It costs about $5 bucks and covers the frequency range. 75 Mhz
Don Harker
RV7A Finishing
nuckolls.bob(at)cox.net Guest
Posted: Tue Dec 18, 2007 2:15 pm Post subject: Marker Beacon Diplexer Question |
At 11:47 AM 12/18/2007 -0600, you wrote:
<dpharker(at)worldnet.att.net>
Marker transmitters are exceedingly strong for
the task . . . since you pass over them at or
below 1000'
A wet string will serve as an antenna on most
receivers. What kind of airplane are you building
and what kind of antenna have you installed. Also,
if you have a perception of increased system reliability
for having dual receivers, have you considered putting
the waypoints into your GPS for the markers and using
that as a back-up for the 75 Mhz receivers?
Finally, the TV couple will probably work fine too.
But carrying two MB receivers doubles the probability
of having to have an MB receiver repaired while
pressing a GPS receiver that's already in place into
backing up an MB receiver is a reduction in complexity,
weight, and cost of ownership.
( -Thomas Paine 1776- )
BobsV35B(at)aol.com Guest
Posted: Tue Dec 18, 2007 6:10 pm Post subject: Marker Beacon Diplexer Question |
Good Evening Don,
I know this is rather late in the discussion, but do you really feel you will need the marker beacons?
Fan markers are being phased out. If you have any IFR approved GPS, there is a good chance, though not a certainty, that you will be able to use a GPS position instead of a fan marker for any required waypoint identification. While I would certainly spend a few bucks getting the marker beacons operating, it would not be high on my list of things that were needed.
If you have not already purchased them, maybe you could eliminate some weight and cost as well as free up some space that could be better used in another manner.
Just a thought!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 12/18/2007 11:51:45 A.M. Central Standard Time, dpharker(at)worldnet.att.net writes:
| Quote: | --> AeroElectric-List message posted by: "Donald Harker" <dpharker(at)worldnet.att.net>
Don Harker
See AOL's top rated recipes and easy ways to stay in shape for winter.
