alh1(at)juno.com Guest
Posted: Tue Dec 18, 2007 7:32 pm Post subject: Hartzell Service Letter 272 |
to the group: i realize that the 500 is not big on numbers, i think of the 100 or so originally there are now less than 40. for service bulletins, I would contact barry as i am sure he has them all.
hartzell is standing behind its products and everyone in the group needs to know that. it is good business for everyone.
Please note: forwarded message attached
SERVICE LETTER
HC-SL-61-272
Propeller - New Propeller Installation
HC-SL-61-272
Page 1 of 4
Nov 14/07
1. Planning Information
A. Effectivity
(1) Twin Commander 500 aircraft with a Hartzell HC-A2(X,V,MV)K-2( ) steel hub
propeller installed are affected by this Service Letter.
NOTE: A Hartzell aluminum hub compact propeller is already approved for
installation on the Twin Commander 500A, B, S, and U. The Twin
Commander 500A, B, S, and U are not affected by this Service
Letter.
B. Reason
(1) Hartzell X and V shank propellers are subject to the repetitive inspection
requirements of Hartzell Service Bulletin HC-SB-61-217 and FAA Airworthiness
Directive AD 97-18-02.
(2) In 1998, Hartzell made a design improvement to the existing V shank propellers
that are identified as MV propellers.
(3) There have been several occurrences of clamp cracks found on the MV series
propellers. Hartzell issued Alert Service Bulletin HC-ASB-61-292 to require an
initial and repetitive visual inspection of the clamps.
(4) Propeller model HC-C3YR-2UF/FC8468A-6R has been approved for
installation on the Twin Commander 500 aircraft by a Supplemental Type
Certificate, STC SA01792SE issued to Hartzell Propeller Inc. This propeller
model is not affected by Hartzell Alert Service Bulletin HC-ASB-61-292.
(a) The engine crankshaft counterweights and rollers for dynamic compatibility
with the propeller must be changed. The counterweights and rollers
required are not supplied by Hartzell. Instructions to change the engine
crankshaft counterweights and rollers are provided in Installation Report
AC500. Hartzell will supply this report with the STC documentation.
(5) Installation of the HC-C3YR-2UF/FC8468A-6R is terminating action for the
inspections required in Hartzell Alert Service Bulletin HC-ASB-61-292 and FAA
Airworthiness Directive AD 97-18-02.
© 2007 - Hartzell Propeller Inc. - All rights reserved
_____________________________________________________________
Buried in medical files? Click here for information on an electronic system.
http://thirdpartyoffers.juno.com/TGL2111/fc/Ioyw6iigiKyPukcGcU3lJtMreMDJRNyIXvUuj63QM4bNwz3LrWmuph/
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
