trumanst(at)netins.net Guest
Posted: Wed Dec 05, 2007 3:05 pm Post subject: ANL 60 |
Bob, I have burned two ANL 60 series limiters in six months. I have no idea why.
The circumstances were the same both times though. I had just put my engine back on the plane after some maintenance. After start up I excite the field. This has been my method to check that the alternator is working. Both times the LV light has remained on. With no indication of charging. I thought my battery might have been low, but putting on the charger this morning indicated not. Not a huge deal, but at $20 a copy it is getting old.
Any suggestions?
Using a 55 amp DN IR alt. with crowbar OV.
Kevin Boddicker
Tri Q 200 N7868B 79.6 hours
Luana, IA.
nuckolls.bob(at)cox.net Guest
Posted: Wed Dec 05, 2007 9:56 pm Post subject: ANL 60 |
At 05:05 PM 12/5/2007 -0600, you wrote:
| Quote: | Bob,
is getting old.
Any suggestions?
If you have 70+ hours on the airplane, do I presume
correctly that the system HAS functioned most of
the time without blowing the limiter?
Normally, there's but two things that will open
this limiter. (1) hard fault on the alternator
side of the limiter. I.e. shorted diodes in
alternator or shorted wiring between alternator
and b-lead terminal or (2) battery in backwards.
or external battery connected to system is
jumper cabled in backwards.
If you have an internally regulated alternator
do I also presume correctly that you're using
Z-24 with b-lead contactor as the ov disconnect
scheme?
Posted: Thu Dec 06, 2007 6:03 am Post subject: ANL 60 |
| Quote: | If you have an internally regulated alternator
scheme?
Yes I do have the b-lead contactor in line after the ANL 60.I have had no trouble with the system other than this. Happened twice. Both times after engine removal. Seems odd.
The first time I thought it was the alternator, so I took the engine back off and had it checked. The tests came out fine. I think he checked the diodes, then ran it up to check for output. Again fine. After I replaced the ANL 60 things were working smoothly. I did have the engine off during annual, and to trouble with that reinstall when I fired it up.
Not so this time.
Thanks for your help,
Kevin Boddicker
Luana, IA.
On Dec 5, 2007, at 11:54 PM, Robert L. Nuckolls, III wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>
| Quote: | Bob,
Any suggestions?
scheme?
-- Please Support Your Lists This Month --
(And Get Some AWESOME FREE Gifts!)
November is the Annual List Fund Raiser. Click on
the Contribution link below to find out more about
this year's Terrific Free Incentive Gifts!
List Contribution Web Site:
--> http://www.matronics.com/contribution
Thank you for your generous support!
- The AeroElectric-List Email Forum -
--> http://www.matronics.com/Navigator?AeroElectric-List
- MATRONICS WEB FORUMS -
--> http://forums.matronics.com
mprather(at)spro.net Guest
Posted: Thu Dec 06, 2007 8:22 am Post subject: ANL 60 |
It's an internally regulated alternator and you "excite the field".. By
what means? Are you just connecting the sense line?
Do you know that the ANL is blown before turning on the alternator? I
wonder if it's actually being blown out by a bad ground. I can't
visualize a conduction path at the moment, but possibly the b-lead
represents a ground path during starter operation?
Another thought.. Are you sure it's actually a 55A alternator? Would a
110A unit blow an ANL60? Maybe not given the long time constant of ANL's,
and assuming a charged battery.
Matt-
| Quote: | > If you have an internally regulated alternator
> scheme?
> Bob . . .
I fired it up.
Not so this time.
Kevin Boddicker
Luana, IA.
> <nuckolls.bob(at)cox.net>
>> Bob,
>> idea why.
>> Any suggestions?
> scheme?
> Bob . . .
Posted: Thu Dec 06, 2007 3:14 pm Post subject: ANL 60 |
Kevin Boddicker
Tri Q 200 N7868B hours
Luana, IA.
On Dec 6, 2007, at 10:08 AM, Matt Prather wrote:
| Quote: | --> AeroElectric-List message posted by: "Matt Prather" <mprather(at)spro.net (mprather(at)spro.net)>
I have a split rocker "ala Cessna". After start up I "turn on" excite the field.
It is a 55A DN alt. converted from a Geo Metro.
I "think I have it figured out. Not sure yet. I think the B-lead at the alt contactor is so close to the alum sheet that covers the firewall, or may be touching. If that is so the current could be able to go to ground via the firewall, forrest of tabs, ground lug to engine. I thought this last summer when I had the trouble, but could not find any sign of an arc. The termination is covered with black shrink tube, but it has some cracks in it. I do remember it getting close to the firewall as I tightened it last Sunday night. I also recall moving it away from the FW last summer and not letting it get close this fall after engine reinstall. I will check it out ASAP and let the group know. May be a while it is snowing here, and the forecast calls for more.
The runway has been close since Saturday due to ice.
Any comments are welcome.
Kevin
| Quote: | | Quote: | If you have an internally regulated alternator
scheme?
I fired it up.
Not so this time.
Kevin Boddicker
Luana, IA.
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III"
| Quote: | Bob,
idea why.
Any suggestions?
scheme?
Posted: Thu Dec 06, 2007 4:15 pm Post subject: ANL 60 |
Sounds like you might have it.. Can you grind the bolt down any and still
get the not and lug on it? Or dent the firewall a bit with some kind of
round tool (a socket of some sort).
Matt-
Kevin Boddicker
Luana, IA.
> <mprather(at)spro.net>
> field".. By
the field.
> Would a
> ANL's,
Kevin
>>> scheme?
>>> Bob . . .
>> I fired it up.
>> Not so this time.
>> Kevin Boddicker
>> Luana, IA.
>>>> Bob,
>>>> idea why.
>>>> Any suggestions?
>>> scheme?
>>> Bob . . .
Posted: Fri Dec 07, 2007 6:48 am Post subject: ANL 60 |
Matt,I know there is plenty of room for the wire. I was just trying to make things look nice. I can rotate the termination 180º. I just need to angle it away from the FW. I also think I will apply another piece of shrink tube over the existing one.
Thanks Again,
Kevin Boddicker
Tri Q 200 N7868B 79..6 hours
Luana, IA.
On Dec 6, 2007, at 5:54 PM, Matt Prather wrote:
[quote]--> AeroElectric-List message posted by: "Matt Prather" <mprather(at)spro.net (mprather(at)spro.net)>
Matt-
Kevin Boddicker
Luana, IA.
field".. By
the field.
Would a
ANL's,
Kevin
scheme?
I fired it up.
Not so this time.
Kevin Boddicker
Luana, IA.
| Quote: | Bob,
idea why.
Any suggestions?
scheme?
klehman(at)albedo.net Guest
Posted: Fri Dec 07, 2007 5:05 pm Post subject: ANL 60 |
Hello Kevin
As I understand it you have a 55 amp alternator and a 60 amp ANL. Yes
the ANL is slow acting but I am not surprised that it would occasionally
blow under the circumstances you describe. After startup the 55 amp
nominal alternator could easilly be putting in excess of 60 amps when
connected to a battery that has been sitting idle for several weeks.
Personally I'd recommend the next size larger ANL.
Ken
Kevin Boddicker wrote:
Kevin Boddicker
Luana, IA.
> <mprather(at)spro.net <mailto:mprather(at)spro.net>>
excite the field.
> ANL's,
Kevin
>>> scheme?
>>> Bob . . .
>> I fired it up.
>> Not so this time.
>> Kevin Boddicker
>> Luana, IA.
>>> <nuckolls.bob(at)cox.net <mailto:nuckolls.bob(at)cox.net>>
>>>> Bob,
>>>> idea why.
>>>> Any suggestions?
>>> scheme?
>>> Bob . . .
Posted: Sat Dec 08, 2007 8:14 am Post subject: ANL 60 |
Thanks Ken,I was afraid to go much larger. Have no reason to have fear accept for lack of knowledge on the subject. I too thought the battery was low, but when I put the charger maintainer on it, the charged light came on within thirty seconds.
I am rethinking the whole system at this time. I have what some consider ancient tech. Long story, but the guys in the know don't like the drive gear arrangement etc on the case mounted alt that I have.
I am looking at B&C or Plane Power as replacements.
Kevin Boddicker
Luana, IA.
On Dec 7, 2007, at 7:02 PM, Ken wrote:
[quote]--> AeroElectric-List message posted by: Ken <klehman(at)albedo.net (klehman(at)albedo.net)>
Hello Kevin
As I understand it you have a 55 amp alternator and a 60 amp ANL. Yes the ANL is slow acting but I am not surprised that it would occasionally blow under the circumstances you describe. After startup the 55 amp nominal alternator could easilly be putting in excess of 60 amps when connected to a battery that has been sitting idle for several weeks. Personally I'd recommend the next size larger ANL.
Ken
Kevin Boddicker
Luana, IA.
| Quote: | --> AeroElectric-List message posted by: "Matt Prather" <mprather(at)spro.net <mailto:mprather(at)spro.net (mprather(at)spro.net)>>
The runway has been close since Saturday due to ice. Any comments are welcome. Thanks,
Kevin
scheme?
I fired it up.
Not so this time.
Kevin Boddicker
Luana, IA.
<nuckolls.bob(at)cox.net <mailto:nuckolls.bob(at)cox.net (nuckolls.bob(at)cox.net)>>
| Quote: | Bob,
idea why.
Any suggestions?
scheme?
Posted: Sat Dec 08, 2007 8:48 am Post subject: ANL 60 |
Kevin
Well the thing is that the only purpose for the ANL is to prevent a fire
in the rare case of a short in the alternator or the heavy wire from the
alternator. The battery will normally supply enough current to blow a
fairly large ANL. So the only other consideration is the size of the
wire (the B lead) from the alternator. That wire is sized to handle the
current output of the alternator. A problem in the alternator or with
the wire is almost always a dead short that will flow much higher
current than the alternator could ever put out and therefore pop a large
ANL quite quickly before the wire gets hot. Generally the ANL or circuit
breaker or fuse on the B lead needs to be a bit larger than the
alternator can ever put out. Perhaps 20% higher than rated.
Even with a fully charged battery I would expect the regulator to
command max output for a few seconds after cranking. If the rpm
immediately goes high enough to actually produce max amperage you will
indeed get it. Keeping the rpm low for perhaps 20 seconds or so would
prevent tripping your ANL as the battery rapidly recovers from cranking,
but I think your symptoms are hinting that a larger ANL is a good idea.
Good luck with it.
Ken
| Quote: | Thanks Ken,
Kevin Boddicker
Luana, IA.
Posted: Sat Dec 08, 2007 2:37 pm Post subject: ANL 60 |
At 08:02 PM 12/7/2007 -0500, you wrote:
Hello Kevin
Ken
ANL and ANN series devices are not called "fuses" for
a reason. The physics of their operation is described
at:
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
Note that both of the ANL30 devices are infinite carry
time at 90 Amps! An ANL 60 is infinite carry time at
somewhere around 130 Amps. These devices are clearly
intended to avoid nuisance trips due to continuous
normal current at nameplate rating COMBINED with
the occasional bodacious inrush current or other
transient.
The problem Kevin is experiencing is certain to be
the result of some "hard" fault somewhere.
Posted: Mon Dec 17, 2007 7:27 pm Post subject: ANL 60 |
Bob and others that responded.Today I was able to get the ANL 60 replaced, and checked the B lead wire.
It was indeed touching the firewall and appeared to be grounding out there. Via the aluminum sheet on the FW back to engine ground. I did not fire it up, as it was dark by then and only 20°F. If I have further trouble I will post again.
Thanks for all the replies.
Kevin Boddicker
Luana, IA.
| Quote: | Bob,
Any suggestions?
scheme?
Posted: Tue Dec 18, 2007 3:15 pm Post subject: ANL 60 |
Bob and listers.Flew today, after repositioning the B lead wire and replacing the ANL 60.
All systems worked normally!!!!
Thanks and Merry Christmas.
Kevin Boddicker
Tri Q 200 N7868B 80.6 hours
Luana, IA.
| Quote: | --> AeroElectric-List message posted by: Ken <klehman(at)albedo.net (klehman(at)albedo.net)>
Hello Kevin
Ken
at:
transient.
Posted: Wed Dec 19, 2007 6:02 am Post subject: ANL 60 |
At 05:19 PM 12/18/2007 -0600, you wrote:
| Quote: | Bob and listers.
Very good sir! Seems you've demonstrated the
validity of our faith in installing such devices.
This one did it's job!
