shempdowling(at)gmail.com Guest
Posted: Thu Dec 13, 2007 9:05 am Post subject: Cost of Paint Job |
I'm shopping around for a paint job and am getting sticker shock. The
only "local" shop around Chicago told me his last RV paint job was
$7200. I thought they typically cost around 5000. I've spent a lot of
time on my glass stuff and its pretty much ready to paint. Anyone have
a cost of a good relatively simple 2 color paint job that didnt require
a lot of work by the painters?
Shemp
300+
6a
Chicago
mike humphrey wrote:
<mike109g6(at)insideconnect.net>
Mike,
In my hanger I have the T-12 cold weather 8' units. Great lighting,
work in cold fine, easy to replace, just started replacing bulbs after
3 1/2 years continual use, pricey but great lighting. Lowe's carries
the 8' fixture and bulbs(green ends and they just push in, no
twisting). In my work areas I have added specific lighting to the
situation. Bandsaw, lathe, drill press (dangerous areas) have
separate lighting on switches. I would not hang any lighting on the
16' ceiling though. Lighting disperses geometrically. So whatever
lighting that you choose, suspend it from some cheap chain and lower
it to about 2-3 feet above your highest point on the floor, ie tail of
plane. Reflectors are cheaper than lighting units and you will save
electricity which equals $. More $ to spend on RV's. Remember,
whatever lighting that you put in, you will not want to replace
anytime soon, if ever, by lowering your units, maintenance will be
easier also, unless you just happen to have a 16' step ladder.
Mike H
9A/8A
andygold(at)rkymtnhi.com Guest
Posted: Thu Dec 13, 2007 10:03 am Post subject: Cost of Paint Job |
I painted my plane with three colors of Imron. The total cost of materials
was about $400. I did all the prep work myself, built a booth in my garage,
and asked a local pro to come over and squirt the top coat. He did a great
job and had about 2 hours into the whole thing. I bought him a case of
scotch and went flying with him a couple times. Everyone walked away very
happy.
With mine, the prep work was just that - "work". Its nothing difficult or
anything that requries any unusual skills. But it takes a lot of time and
that's why your local shop wants $7200. The only part of the job that takes
skill and experience to get right is the final squirt.
If you want to see how to prep and paint your RV, get Sam James's Painting
101 video. (Its at Builder's Bookstore www.buildersbooks.com )
Andy
cjensen(at)dts9000.com Guest
Posted: Thu Dec 13, 2007 10:04 am Post subject: Cost of Paint Job |
Shemp,
Rarely is the prep work done by a builder even close to the degree of finish that a quality painter requires. The builder/owner thinks just a few hours of touch up is all that is required, but more often, its like several days or a week or more. If the local shop does a high quality prep job and paint to match, $7,200 isn't unreasonable. If he's doing an "Earl Schribe" type paint job, then $5,000 is way too much.
Chuck
n212pj(at)gmail.com Guest
Posted: Thu Dec 13, 2007 10:33 am Post subject: Cost of Paint Job |
Take a look at Randy's Lervold's write-up of his RV-3B paint process. I've
seen the final outcome and it looks great. He is a meticulous and
thoughtful builder, so you can trust his commentary. I have never painted
more than the interior walls of my house, so cannot say anything about this
topic, but the statement below, "the prep work...takes a lot of time and
that's why your local shop wants..." $$ is the truth. You just need to
know what to do and how to do it. Then you need to decide if your labor is
worth the savings. Applying the paint is the skill part. The rest is time
and effort.
http://www.romeolima.com/RV3hq/Paint/paint.htm
John J
40328
sbuc(at)hiwaay.net Guest
Posted: Thu Dec 13, 2007 10:34 am Post subject: Cost of Paint Job |
Andy Gold wrote:
materials was about $400. I did all the prep work myself, built a booth
in my garage, and asked a local pro to come over and squirt the top
coat. He did a great job and had about 2 hours into the whole thing. I
bought him a case of scotch and went flying with him a couple times.
Everyone walked away very happy.
or anything that requries any unusual skills. But it takes a lot of
time and that's why your local shop wants $7200. The only part of the
job that takes skill and experience to get right is the final squirt.
Painting 101 video. (Its at Builder's Bookstore www.buildersbooks.com )
When I painted my RV-6 eight years ago, my cost of materials (PPG
Concept single stage) was close to $1000.
Wish I could've sprayed my plane in two hours...bet I had 15 hours just
in masking.............. )-:
I used to think aircraft paint jobs were outrageously priced. After
painting a couple of planes, I am amazed a paint shop can stay in
business by only charging $7000.
Sam Buchanan
rickrv8(at)msn.com Guest
Posted: Thu Dec 13, 2007 11:10 am Post subject: Cost of Paint Job |
I had my -8 painted two summers ago. I probably got a dozen quotes from
companies with RV experience from all over the country. Mine was a
multi-colored paint scheme and my quotes ranged from about $4900 to $7000
for a single stage job and $6500 to $12,000 for a base coat/clear coat job.
I decided on a base coat/clear coat for $8500 from Prestige Paint in upsate
Vermont (see the Yellerpages). I would suggest you shop around.
Additionally, virtually every shop I spoke to said they include a few hours
labor for prep in their quote because they rarely experienced an airplane
that was indeed ready for final color coating. You'll be hard pressed to
get them to quote less unless they see your work.
Rick McBride
RV-8 N523RJ
[quote]From: Shemp <shempdowling(at)gmail.com>
Reply-To: rv-list(at)matronics.com
Subject: Cost of Paint Job
Date: Thu, 13 Dec 2007 10:59:57 -0600
I'm shopping around for a paint job and am getting sticker shock. The only
"local" shop around Chicago told me his last RV paint job was $7200. I
thought they typically cost around 5000. I've spent a lot of time on my
glass stuff and its pretty much ready to paint. Anyone have a cost of a
good relatively simple 2 color paint job that didnt require a lot of work
by the painters?
Shemp
300+
6a
Chicago
>Mike,
>In my hanger I have the T-12 cold weather 8' units. Great lighting, work
>in cold fine, easy to replace, just started replacing bulbs after 3 1/2
>years continual use, pricey but great lighting. Lowe's carries the 8'
>fixture and bulbs(green ends and they just push in, no twisting). In my
>work areas I have added specific lighting to the situation. Bandsaw,
>lathe, drill press (dangerous areas) have separate lighting on switches.
>I would not hang any lighting on the 16' ceiling though. Lighting
>disperses geometrically. So whatever lighting that you choose, suspend it
>from some cheap chain and lower it to about 2-3 feet above your highest
>point on the floor, ie tail of plane. Reflectors are cheaper than
>lighting units and you will save electricity which equals $. More $ to
>spend on RV's. Remember, whatever lighting that you put in, you will not
>want to replace anytime soon, if ever, by lowering your units, maintenance
>will be easier also, unless you just happen to have a 16' step ladder.
>Mike H
>9A/8A
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Thu Dec 13, 2007 11:33 am Post subject: Cost of Paint Job |
In a message dated 12/13/2007 12:36:18 PM Central Standard Time, sbuc(at)hiwaay.net writes:
| Quote: | I used to think aircraft paint jobs were outrageously priced. After
business by only charging $7000. |
Same here. Doug Reeves used to have paint shop reviews on his Vans Air Force website, but it looks like they are gone. Here is a description of my most excellent paint shop experience, courtesy of Bobby Potts at TCL, Tuscaloosa, AL (you didn't REALLY want to paint in the snow, didja?!). Damage was $7K almost 3yrs ago, and very happy to pay it:
http://websites.expercraft.com/n51pw/
(The Expercraft website seems to down right now, but try later- select Painting link from bottom of left column of homepage above)
Mark Phillips
Columbia, TN
See AOL's top rated recipes and easy ways to stay in shape for winter.
_________________ From The PossumWorks... |
panamared5(at)brier.net Guest
Posted: Thu Dec 13, 2007 12:41 pm Post subject: Cost of Paint Job |
| Quote: | When I painted my RV-6 eight years ago, my cost of materials (PPG
just in masking.............. )-:
Sam Buchanan
I agree. And I only painted a single color with no primer! Even
with a single color, you still have to mask!?!
Bob
RV6 "Wicked Witch of the West"
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Thu Dec 13, 2007 2:44 pm Post subject: Cost of Paint Job |
Heres a pic of my 6a getting painted at my shop. I parked it in front during the day to showoff but had to move it because it caused a few accidents with the traffic out front. Any quality auto paint shop can do a great job. Just pull the wings and flatbed the fuse. I did mine in basecoat clearcoat because the painters were most familiar with that system. I think I have 500-600 in materials and 20hrs of shop time.
Steve dinieri
Iflyrv10
60.95 KB |
331 Time(s) |
acepilot(at)bloomer.net Guest
Posted: Thu Dec 13, 2007 3:05 pm Post subject: Cost of Paint Job |
Man, am I glad I'm going the polished route!! I think I can do the few
fiberglass parts with spray bombs from Wal Mart...
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
booth in my garage, and asked a local pro to come over and squirt the
top coat. He did a great job and had about 2 hours into the whole
thing. I bought him a case of scotch and went flying with him a couple
times. Everyone walked away very happy.
Andy
doug.medema(at)comcast.ne Guest
Posted: Thu Dec 13, 2007 3:14 pm Post subject: Cost of Paint Job |
I just got done having my plane painted. I also shopped around and
had quotes of $7000 (plus any required body work) to $10,000. I
decided it was too much and would do it on my own. Boy was I
naive!
I couldn't do anything in my own hangar at a public airport, so I
made arrangements to work at a friend's hangar at an airpark. I
proceeded to take the whole airplane apart and set up a paint
booth in a Costco car tent in my back yard. I bought a big
compressor and a DeVilbiss FinishLine 3 HVLP gun. Based
on Randy Lervold's recommendations, I went with PPG Concept.
I washed, acid etched, scuffed and alodyned all the aluminum. I
spent a lot of time on the fiberglass and used almost a whole gallon
of K38 high build primer, most of which ended up on everything
in my shop when I sanded it off. I also used quite a bit of
SuperFil. I started painting the color coats with white Concept.
It wasn't great, but it wasn't horrible either. Had the usual
problems with dust, runs, and orange peel. There is a real art
to putting on the final coat. You really can't sand very much
because you will cut through a rivet or just a high spot on the
aluminum. When I painted the empennage fairing with a dark
blue, I kind of lost it. The one piece had orange peel, runs, and
dust everywhere, even with fans and filters. I decided I couldn't
do a job I would be happy with. I went back to the shop who
quoted $10,000 and asked them how much just to put on
the color. They said between $3000 and $4000. Based on
really good review from a person I trust (Terry Burch), I decided
to go ahead an do that. I brought the pieces to them in
sanded primer/sealer. They had to spray a coat of primer and
then basecoat clearcoat. I ended up eating some Concept,
but that's the way it goes. I spent upwards of 200 hours
over the summer doing the prep and priming. I know it's a lot
of hours, but there is a lot to do, especially with the fiberglass
work. There are a lot of pin holes and they will show up if
you don't totally take care of them. I had one of the very first
S type cowls, and it was rough in places. I ended up spending
about $3000 for materials plus $3800 to the paint shop. This
doesn't count the compressor, paint gun, tent, lights, fans, etc.
Plenty of people paint there own airplanes, and I admire them
for it. It is a lot of work. I took my plane down in late April
and didn't fly again until September. In hindsight, I really
wished I had just bit the bullet and had the whole thing done.
That is one person's opinion. Your mileage may vary.
If your curious on how it came out, check out:
home.comcast.net/~doug.medema.
Doug Medema
RV-6A N276DM
12/13/2007 9:15 AM
rblassett(at)alltel.net Guest
Posted: Thu Dec 13, 2007 3:47 pm Post subject: Cost of Paint Job |
Doug,
Man you hit the nail on the head. I've painted a few airplanes and the amount of work required for a nice finish is much more than you would think.
Russ
[quote] --
d-burton(at)comcast.net Guest
Hi Doug,
Good advice. There is the pride of having done most of it yourself and I’m sure it was a good learning experience. Regardless of how you got there the plane looks fabulous! I can’t wait to see it in person.
Dave,
RV6
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Doug Medema
Sent: Thursday, December 13, 2007 3:13 PM
To: RV-List(at)matronics.com
Subject: Re: Cost of Paint Job
[quote]I just got done having my plane painted [b]
Posted: Sat Dec 15, 2007 11:27 am Post subject: Cost of Paint Job |
So how much did you have to pay the auto paint guys?
Shemp
