jptook(at)jptook.cnc.net Guest
Posted: Thu Sep 20, 2007 5:08 am Post subject: 601 XL overheating |
Do not archive.
I’ve read the recent messages regarding the Jabiru 3300 engine in other than a Jabiru. I have been unable to achieve CHTs within Jabiru’s guidelines. Many thanks to the people that gave me the benefit of their own experiences with a special thank you to Jeff Small who worked with us for several months trying to help. Just for the record, my configuration is an original(older, mechanical lifters/less cooling fins) engine with a Sensenich Carbon Fiber ground adjustable prop and the latest Jabiru 601 cowling, and a Grand Rapids EIS. The engine has about 56 hours on it at this point, the carburetor was replaced with an NOS pre-economizer change carb to be sure the engine was not running lean, all probes have been checked and rechecked, air leaks in the intake system have been eliminated (there were none), compression checks made (hot and cold, automotive and aircraft), valves adjusted every five hours, a ‘lip’ of about 1 ½ to 2 inches has been added to the bottom of the cowl at the air exit to give a greater differential, cowling sealed, baffling ‘tweaked’ repeatedly adding ‘fingerlets’, speed bumps, an additional vertical baffling ‘extension’ at the #6 cylinder, pictures taken of the entire engine compartment as well as very detailed ones of the baffling. These were reviewed by the Jabiru dealer on the West Coast and nothing wrong was seen. I’m sure there have been other things done, I’m just trying to demonstrate that we have tried just about everything possible, without success. The latest numbers at the end of this post indicate we still have a very large problem.
I’d like to ask if anyone has attempted to install baffling which would be more the conventional Continental/Lycoming style, i.e. baffling that directs the ram air over the bottom of the cylinders, not just the top. The Sonex has a system for the 3300 that does just this, and, with some alterations, would fit beneath the cowling of a 601. Obviously the steep slope of the Sonex cowl would call for some change of the baffling, but I called the Sonex site and had the measurements taken directly off their demo and there would not be a very great change to their existing ‘baffle box’. My feeling is that there is inadequate cooling air with the 601/Jabiru cowl and the ‘full upper/lower’ cylinder baffling would make better, more complete use of what is available. The cost is not excessive, $250 plus shipping, and I’m at the end of my rope. My next step is to replace my Jabiru engine with a Corvair. They don’t have overheating problems as the full cylinder heads (3 cylinders per) distribute/dissipate heat more efficiently/evenly. The individual I bought the plane from sold it at 26 hours because he could not solve the problem. He was wiser than I.
Thoughts/comments appreciated.
The latest flight test runs follow:
FLIGHT 9-10-2007
INITIAL CLIMB OUT
283 299 298
351 274 323
CRUISE 3000rpm 110mph indicated
295 321 331
324 274 303
CRUISE 2900rpm 110mph indicated
270 291 320
303 269 292
CRUISE 2800rpm 105mph indicated
271 282 312
299 266 291
TOP SPEED RUN
3300rpm 120mph indicated
oil temp set off alarm at 246
these next numbers are in unknown
configuration but occured after
the top speed run
301 314 333
326 262 270
another 2800rpm CRUISE
269 281 304
299 271 298
oil temp 218
500fpm climb at 2800rpm 95mph ind
217 oil temp
277 285 316
308 280 307
updated a little later
284 296 328
326 294 322
9/19/2007 3:59 PM
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
donmorrisey
Posted: Thu Sep 20, 2007 7:09 pm Post subject: 601 XL overheating |
JP, go to the yahoo groups jabiru engine email list and sign up. Then do a search for "Fisher Dakotahawk". A recent post from a builder in New Zealand did exactly what you are thinking...built the standard lyc/conti air box and got excellent results after everything else he tried failed. Another builder on the list has photos in the photo section of a crossover tube he put between the fiberglass airboxes which helped his problem. It seems to me the standard air box accomplishes both. You could use the vertical pieces of the Sonex air box and rivet on extensions to come up to the top of your cowl and basically create the lyc/conti style box. I plan to install my new engine (ser # 1390) this winter with the fiberglass ducts as provided but if that doesn't work I will quickly switch to what I just described. Good luck.
Don...
www.donsbushcaddy.com
Don Morrisey's Skunkworks
| Quote: | From: jptook(at)jptook.cnc.net
To: jabiruengine-list(at)matronics.com
Subject: 601 XL overheating
Date: Thu, 20 Sep 2007 06:07:27 -0700
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;text-underline:single;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;text-underline:single;} .ExternalClass EC_span.EmailStyle17 {font-family:Arial;color:windowtext;} .ExternalClass EC_span.SpellE {;} .ExternalClass EC_span.GramE {;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
Do not archive.
FLIGHT 9-10-2007
INITIAL CLIMB OUT
283 299 298
351 274 323
295 321 331
324 274 303
270 291 320
303 269 292
271 282 312
299 266 291
TOP SPEED RUN
the top speed run
301 314 333
326 262 270
269 281 304
299 271 298
oil temp 218
217 oil temp
277 285 316
308 280 307
284 296 328
326 294 322
9/19/2007 3:59 PM
| Gear up for Halo® 3 and get a $25 Best Buy gift card. It’s our way of saying thanks for using Windows Live™. Get it now! [quote][b]
_________________ Don...
BushCaddy R120
http://www.donsbushcaddy.com |
tonyplane(at)bellsouth.ne Guest
Posted: Thu Sep 20, 2007 8:21 pm Post subject: 601 XL overheating |
Instead of the "air dam" for the oil cooler, I used rubber engine baffeling type material to seal off most of the gaps around the oil cooler to cowling so that air mostly passes through the oil cooler and not around it.
Also, of course as mentioned here many times, I only fill my oil to a max of about 40% on the dip stick. In hot weather, in the 90+F area, I still can not go high power low airspeed for long without going red line on CHT (always my #2, the left hand fwd cylinder.)
I also have deflectors in the ducts for my #4 and #3 cylinders, about 3/4 inch by 4 inches and bigger deflectors for the #5 and #6.
Do not close off the rear area where the duct ends around the #6 and #5 cylinder.
Also, see below from my archives for anything that may help. Note: this was with the original economy mod, before the amendment to lower the EGTs
Tony Graziano
601XL/Jab3300; N493TG, 291 hours
Submitted By:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
charles.long(at)gm.com ([email]charles.long(at)gm.com?Subject=Your%20Photos%20at%20http://www.matronics.com/photoshare/charles.long(at)gm.com.10.23.2005[/email])
Email List:
Zenith-List
Name:
Charles F. Long
Date:
Oct 23 2005
Subject:
Cooling improvements on the Zenith 601HDS w/Jabiru 3300
During my first few hours of flight, I experienced elevated cylinder head temperatures on my Zenith 601HDS with Jabiru 3300A engine. Also had issues with Exhaust Gas Temperature imbalance at full throttle. The following is a summary of changes made to improve the situation. This really just builds on the recommendations of Jabiru and Zenith to provide plenty of cooling for the 6 cylinder engine. I would like to thank Jeff Small, Fred Hulen, Stan Challgren as well as Pete Krotje at US Jabiru and Andy Sylvester at Sun Coast for their contributions. As a place to start, US Jabiru provides some good cooling suggestions at their website:
My aircraft has the following modifications:
1) Fuel Economy Carb Kit as supplied by Jabiru.
2) Gull wing baffles between cylinders as recommended by Jabiru
3) Full deflectors angled down between the spark plugs of cylinder #5 & #6 as recommended by Jabiru.
4) Smaller deflectors angled down between the spark plugs of #3 & #4. These middle cylinder deflectors usually need some tuning. Would suggest starting with 3/4" tall. On #3, I stayed at 3/4", on #4 ended up trimming down to 1/2".
5) The inlet to the ram air ducts has a gap between the duct and the cylinders at the bottom. This allows air to escape downward without doing any useful work. I added some .025" aluminum plates that butt up against cylinder's #1 & #2 to prevent this from happening. To reduce the over cooling of the front two cylinders and force more air upward to the rear cylinders, I angled the material upward about an 2-3¡¨. The exact height needs to be determined by trial end error. The new XL cowl has openings that are quite small and located high on the cylinders. My modification attempts to duplicate the XL cowl openings and seems to work quite well. At the onset, this change appears to be counter-intuitive. Just keep it mind, the goal is to get as much use out of every air molecule as possible!
6) Small baffles mounted between valve tappet covers. This prevents more air from escaping without doing any useful work.
7) There is a temptation to add an L angle to the bottom rear of each ram duct. I tried this change and it elevated my temps rather than reducing them.
The oil cooler inlet is keep quite small to allow more air to find it's way through the cylinders. I ended up with about a 1.75" x 4.00" opening. The Jabiru website provides a good discussion on this. I tried a much bigger opening as can be seen in the picture and it provided very little benefit.
9) Don't forget to keep your oil level midway between the Full and Add mark. Jabiru indicates that overfilling can cause high oil temps.
My #1 cylinder was running much cooler than the #2 cylinder with identical intake openings. I rotated the bottom of the carb 5-10 degrees towards #1 and that took care of it. The main jet feeds the carb at the bottom so if the carb is tilted, it can direct more fuel towards one bank of cylinders than the other.
At full throttle, EGT's from left to right bank were 150 F different. I suspected that air entering the carb through the 90 degree intake elbow was piling up on the outside of the curve. I installed a vertical divider in the elbow to keep left side air separated from the right side air. This worked beautifully. My EGT's are now balanced within roughly 50 F at all throttle settings including WOT. The divider was fabricated out of a piece of 6061T6 aluminum - 5.25" x 3" x .016". The upper and lower edges were rolled around a 1/16" cable to add stiffness and prevent cutting of the rubber elbow. Finished height is just slightly over 2.25 inches so it fits snuggly within the elbow. After rolling the edges, the part was bent 90 degrees to fit the elbow contour by wrapping around a 2" diameter plastic pipe. After it springs back, you end up with a 2" bend radius whichis equivalent to the center radius of the elbow. Once the part is finished, the cable can be removed (prevents a potential corrosion issue). The rubber elbow is quite pliable in the free state, so the flow divider installs quite easily. After installation, the divider is trapped pretty well in all directions.
With the Aid of my Engine Information System from Grand Rapids Technology, I was able to monitor my progress for each Cylinder Head Temperature: I now have the following readings at 60 F ambient temperature (my engine has 28 hours TT, so temps have fallen after break-in):
| Quote: | | RPM IAS CHT1 CHT2 CHT3 CHT4 CHT5 CHT6 EGT5 EGT6 |
| Quote: | | 2600 110 247 228 259 247 272 245 1465 1423 | | Quote: | | 2700 120 242 221 253 239 265 240 1486 1451 | | Quote: | | 2800 125 242 226 252 242 265 244 1512 1498 | | Quote: | | 2900 130 253 246 260 260 268 262 1482 1538 | | Quote: | | WOT 138 288 293 293 298 301 297 1463 1482 |
This was a quickie test and temps/speeds were not totally stabilized. Oil temps varied from 200-230F depending on Throttle setting. This is an area where a NACA inlet could improve Oil Cooler efficiency. The new XL cowl incorporates one of these. The Flight Test was run at 3500 ft MSL and an ambient of 60F. Wheel pants and gear fairings are installed with an otherwise stock airframe.
The Jabiru is running very nice. I'm happy with the installation, power and smoothness after getting through these initial teething problems. Fuel burn at lower cruise settings is estimated at a miserly 4 gph. With the fat wing, I suspect fuel burn will go way up at the higher cruise speeds.
Chuck Long
Zodiac 601HDS
N601LE, 28 hr TT
Subject: [b]Subject: [i]601 XL overheating From: E.T.Gmerek (jptook(at)jptook.cnc.net ([email]jptook(at)jptook.cnc.net?subject=Re:%20601%20XL%20overheating&replyto=01b901c7fb87$32c66cd0(at)Eds[/email])) Date: [b]Thu Sep 20 - 6:08 AM[/b] | Quote: | | Quote: | Do not archive.
I=92ve read the recent messages regarding the Jabiru 3300 engine in
other
than a Jabiru. I have been unable to achieve CHTs within Jabiru=92s
hours, a =91lip=92 of about 1 =BD to 2 inches has been added to the
bottom of
baffling =91tweaked=92 repeatedly adding =91fingerlets=92, speed bumps,
an
additional vertical baffling =91extension=92 at the #6 cylinder,
pictures
and nothing wrong was seen. I=92m sure there have been other things
done,
I=92m just trying to demonstrate that we have tried just about
everything
I=92d like to ask if anyone has attempted to install baffling which
would
=91baffle box=92. My feeling is that there is inadequate cooling air
with
the 601/Jabiru cowl and the =91full upper/lower=92 cylinder baffling
would
excessive, $250 plus shipping, and I=92m at the end of my rope. My next
step is to replace my Jabiru engine with a Corvair. They don=92t have
| [/i][/b] From: E.T.Gmerek (jptook(at)jptook.cnc.net ([email]jptook(at)jptook.cnc.net?subject=Re:%20601%20XL%20overheating&replyto=01b901c7fb87$32c66cd0(at)Eds[/email])) Date: [b]Thu Sep 20 - 6:08 AM[/b] [quote] | Quote: | Do not archive.
other
bottom of
an
pictures
done,
everything
would
with
would
| [b]
Don McIntosh
Joined: 02 Jul 2007 Posts: 24 Location: Sandpoint, Idaho
Posted: Mon Dec 10, 2007 3:30 pm Post subject: Re: 601 XL overheating |
This is a reply to Don, on his suggestion on 9/20/07 to go to the Jabiru engine Yahoo Group and look up Fisher Dakotahawk. As I just received my 3300 today (Yayyy!) for my Kitfox, I am interested in seeing the "Continental Style" ducting, but I was not successful in the search mentioned. Do you know the date of the post or possibly more info?
_________________ Don McIntosh
Kitfox Series 7
Jabiru 3300 |
