noelk
Joined: 05 Oct 2007 Posts: 10 Location: Canberra, Australia
Posted: Mon Dec 17, 2007 5:06 pm Post subject: Battery Contactors |
I have just started wiring up a Jabiru 3300 installation, which includes a battery contactor. I wanted to test that the basic power wiring was OK before going too far with the wiring, so I connected a bench power supply to the input side of the contactor, and selected the battery position on the master switch. Everything seemed to be working correctly, except that the contactor became quite hot to touch once it had been on for a while. (There was no load on the main bus at this stage, the only current through the contactor was the coil current.) I removed it and replaced it with a second borrowed contactor, with the same result. I also took the contactors out of the aircraft, and checked them on the bench, and again, they became quite hot. Both contactors drew a coil current of about 750 mA.
Is it normal for battery contactors to run hot, or have I encountered two faulty contactors?
Noel Karppinen
rjquillin
Posted: Mon Dec 17, 2007 5:27 pm Post subject: Battery Contactors |
At 16:59 12/17/2007, you wrote:
| Quote: | Is it normal for battery contactors to run hot, or have I encountered two faulty contactors?
Noel Karppinen |
Do you perhaps have contactors rated for intermittent (starter) service rather than continuous (battery) service?
Ron Q.
schaefer(at)rts-services. Guest
Posted: Mon Dec 17, 2007 5:59 pm Post subject: Battery Contactors |
It’s normal for them to be a little too warm to touch.
The current is about right.
Look at this at a 10W heater. It will get warm!
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Noel Karppinen
Sent: Monday, December 17, 2007 6:59 PM
Subject: Battery Contactors
Noel Karppinen
noelk
Posted: Wed Dec 19, 2007 1:24 am Post subject: Battery Contactors |
>>Noel Karppinen
>Ron Q. | Hi Ron
The original contactor came from Aircraft Spruce, and is one of their master relays, rated for continuous use. The other came fom a local LAME (or A&P, I believe, for all you guys in the US). Since I asked for a battery contactor, I'm pretty sure that would also be for continuous use.
Noel
noelk
Posted: Wed Dec 19, 2007 1:35 am Post subject: Battery Contactors |
>It's normal for them to be a little too warm to touch. The current is about right. Look at this at a 10W heater. It will get warm!
| Quote: | _____
>>From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)
>>[mailto:owner-aeroelectric-list-server(at)matronics.com] ([email]owner-aeroelectric-list-server(at)matronics.com%5D[/email]) On Behalf Of Noel
>>Karppinen
Thanks, Richard. That makes me feel more confident that there is no real problem.
Noel Karppinen
Peter Laurence
Posted: Wed Dec 19, 2007 5:12 am Post subject: Battery Contactors |
Noel
Check the resistance on the coil. A continuous duty contactor will show a resistance of 10 to 18 ohms. An intermittant one will show 3 to 5 ohms
Peter
nuckolls.bob(at)cox.net Guest
Posted: Wed Dec 19, 2007 5:51 am Post subject: Battery Contactors |
At 08:32 PM 12/19/2007 +1100, you wrote:
| Quote: | "Richard T. Schaefer"
Dead on target Richard. In times past that this
conversation was conducted, I went to the bench
and held one of our stock battery contactors
in an energized condition until its temperature
stabilized. See:
http://www.aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_1.jpg
The effects of temperature rise were obvious
too in terms of the current draw for the
contactor. Room temperature current draw
was on the order of 0.8 amps. But after
two hours of operation . . .
http://www.aeroelectric.com/Pictures/Contactors/Battery_Contactor_Temps_2.jpg
. . . current draw is down to about
0.56 amps. This phenomenon is a function
of the positive temperature coefficient of
copper wire used to wind the coil. As the
device warms up, it's resistance goes up
and the current goes down.
In terms of a gross test of a contactor's
intermittent or continuous duty status, if
it's still functioning after 5 minutes of
continuous operation then it MUST be a
continuous duty device. The intermittent
duty devices tailored for starter motor
control would have spit out all their smoke
after 5 minutes!
It's not often that we are physically able
to "feel" a piece of operating equipment and
find that it's too hot to touch but it can
raise concerns when the device is not
OBVIOUSLY designed to run hot . . . like
engines and exhaust stacks.
The contactors that dissipate about 10
watts don't heat up real fast . . . but in
still air they'll get pretty toasty.
includes a
was OK
power supply to
position on the
that the
while. (There
through the
with a second
contactors out of
became quite
noelk
Posted: Thu Dec 20, 2007 2:52 am Post subject: Battery Contactors |
Hi Peter
The resistance of mine is 16 Ohms when cold, so it is right in the ball park.
Noel
noelk
Posted: Thu Dec 20, 2007 2:54 am Post subject: Battery Contactors |
Thanks for that comprehensive reply, Bob. Now I am completely convinced that there is nothing to worry about.
Noel
