stranfaer(at)btinternet.c Guest
Posted: Wed Dec 05, 2007 12:56 pm Post subject: Rotax 912 run on |
We have of late been experiencing a run on with the engine after switching
off!
The only way we have been able to shut down has been by turning off the
fuel.
It does not do it evrytime, however the instances are becoming more
frequent, I have only subscribed to the list for just over a year and dont
recall any other instances?
However if there are any ideas or suggestions I would be gratefull?
rgds
David J Joyce B-BWON
terrys(at)cisco.com Guest
Posted: Wed Dec 05, 2007 1:06 pm Post subject: Rotax 912 run on |
Hi,
We used the typical mag switch from Aircraft Spruce, and now with 500
hours on it, we have had the occasion when it will not shut off the
engine. It seems to be dirty contacts in the switch, which is supposed
to short both mag wires to ground. Moving the switch to on, then back
to off eventually cures the problem.
Terry Seaver
A135 / N135TD
Posted: Wed Dec 05, 2007 1:21 pm Post subject: Rotax 912 run on |
Hi Dave,
I had this on my 914 and it turned out to be a partially broken mag
wire. It was right at the crimp connector. The wire on those modules
isn't too good.
Paul
rlborger(at)mac.com Guest
Posted: Wed Dec 05, 2007 1:40 pm Post subject: Rotax 912 run on |
David,
Most likely, one (or both) mags are not being properly shorted to ground when switched off. Do you get a proper mag check? That is, do you get a RPM drop when you check Mag A and Mag B individually on your run up mag checks? If you do not, then one of the mags has a bad ground wire. If you do get a proper RPM drop on both Mags, then your switch does not properly ground one or both mags when switched off. Check the switch connections in the off position to make sure both mag wires have continuity to ground.
Let us know what you find.
Great flying,
Bob Borger
On Wednesday, December 05, 2007, at 03:12PM, "David Joyce" <stranfaer(at)btinternet.com> wrote:
off!
fuel.
rgds
rparigor(at)suffolk.lib.n Guest
Posted: Wed Dec 05, 2007 2:25 pm Post subject: Rotax 912 run on |
Hello David
"We have of late been experiencing a run on with the engine after
switching off! It does not do it evrytime, however the instances are
becoming more frequent"
As mentioned, check switch, connections and wires first. If still doing
it, I have heard if you get ignition modules hot, the first symptom is you
can not turn off motor. Wrong time of year to first manifest??
On 914 anyway, you can swap ignition modules for a test, but it is not
recommended to leave it that way, may help a bit in narrowing down
problem.
Ron Parigoris
jeff(at)rmmm.net Guest
Posted: Wed Dec 05, 2007 2:56 pm Post subject: Rotax 912 run on |
David,
I just went through this last summer and as Paul said it's probably at
the mags. The wire coming out of them is very cheep and needs a pig
tail of quality tefzel (Not sure of that spelling) wire. We then
soldered the ground wires direct to the pigtails and the problem has
never come back. Make sure you tie wrap the pigtails and put some
shrink tubing at the solder joint. Vibration is your enemy right at the
mag. A partially broken wire gave me fits until this list told me to
look there.
Jeff R.
A258 - N128LJ / Gold Rush 96 hours and climbing slowly.
switching off!
the fuel.
dont recall any other instances?
rgds
rehn(at)rockisland.com Guest
Posted: Wed Dec 05, 2007 3:33 pm Post subject: Rotax 912 run on |
I would put my money on this as the cause! I also have seen this and talked
to 912 and 914 drivers with the same. Tie all those wires tight after
fixing!
Jerry
Posted: Thu Dec 06, 2007 4:15 pm Post subject: Rotax 912 run on |
Thanks for all the replys, I will check the results and report back to the
list....
rgds
David J Joyce G-BWON
