need advice on extra fuel tank hook up
Jimmy Young
PostPosted: Tue Dec 04, 2007 6:24 pm    Post subject: need advice on extra fuel tank hook up Reply with quote
I've got a Firestar II, and there is plenty of room behind the seat to add a temp. 5 gal tank for extended trips. I know many Kolb owners use extra tanks for the same purpose, but I've never seen how they have them hooked up. I was thinking of teeing off my fuel line and having a shut off valve in that line so when I'm not using the extra tank I could easily remove it and shut off the valve. Any suggestions? Also, is anyone using quick-disconnect fittings on this type of set up in place of a shut off valve? By the way, I can mount the extra tank so it is at the same level as my existing 2 tanks, so when connected the fuel levels would be the same.
Thanks for any advice.
Jimmy Young
2 lessons away from my Sport Pilot license.
Jimmy_Young.vcf
 Filename:  Jimmy_Young.vcf
 Filesize:  296 Bytes
 Downloaded:  523 Time(s)
Jimmy Young
Missouri City, TX
Kolb FS II/HKS 700
Richard Pike
PostPosted: Tue Dec 04, 2007 7:33 pm    Post subject: need advice on extra fuel tank hook up Reply with quote
We added a few extra gallons to the local FSII, here is the web page of
how we did it - feel this is a lot safer than a tank sitting in the back
seat -
http://www.bcchapel.org/pages/0003/FSIITankMods.html
Richard Pike
MKIII N420P (420ldPoops)
Jimmy Young
Jimmy Young
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
lcottrell
PostPosted: Tue Dec 04, 2007 8:33 pm    Post subject: need advice on extra fuel tank hook up Reply with quote
Wade Lawicki
PostPosted: Wed Dec 05, 2007 5:11 pm    Post subject: Re: need advice on extra fuel tank hook up Reply with quote
Jimmy,
I used a boat quick connect for my aux tank that i set in the rear seat allowing me an extra 6 gallons of fuel for 16 total. main tank and aux are on the same shutoff, works great
Fly Safe,
Wade
View user's profile Send private message Yahoo Messenger
Jim ODay
PostPosted: Wed Dec 05, 2007 5:46 pm    Post subject: Re: need advice on extra fuel tank hook up Reply with quote
Richard:
Did you ever have any problems with PVC and gasoline? I have seen where PVC has dissolved in gasoline and fuel oil piping installations.
Yours is a nifty set-up. Every plane I have owned could use more tanks.
Fly safe,
Jim
Jim O'Day
Fargo, ND
Former Firestar II Builder/Pilot
Richard Pike
PostPosted: Wed Dec 05, 2007 7:38 pm    Post subject: need advice on extra fuel tank hook up Reply with quote
We made up a test length of pipe and capped it off, filled it with gas
and let it set for several days. Then dumped the gas out and and
immediately checked it for softness or deterioration of the glue joint.
Nothing noted, but that doesn't mean it won't go bad in ten years...
Richard Pike
Jim ODay wrote:
Richard:
Fly safe,
Jim
Jim O'Day
Fargo, ND
Firestar II
http://forums.matronics.com/viewtopic.php?p=150674#150674
Richard Pike
Kingsport, TN 3TN0
ceengland(at)bellsouth.ne
PostPosted: Thu Dec 06, 2007 6:18 pm    Post subject: need advice on extra fuel tank hook up Reply with quote
If plastic really worries you, look into aluminum irrigation tubing.
Several different diameters available, up to at least 6" (I just built a
hangar door using it). You'll probably have to make your own end caps,
but with Proseal sealant & closed end pop rivets, construction would be
fairly simple.
Charlie
Richard Pike
Jim ODay wrote:
> Richard:
> Fly safe,
> Jim
> do not archive
> Jim O'Day
> Fargo, ND
> Firestar II
azfirestar
PostPosted: Sat Dec 08, 2007 8:39 pm    Post subject: Re: need advice on extra fuel tank hook up Reply with quote
If you want more range then you might want to get the 6 gal tanks from Kolb. I bought two of them and they fit fine in my Firestar II. The new tanks actually hold 6.5 gal when filled as high as the old ones needed to be to get 5 gal. I also switched to a bottom-drain configuration (instead of the pickup tube coming out the top of the tank). Now it doesn't matter that the aft tank is a little higher than the fwd tank in flight - both drain down to a low point in a 3/8" fuel line. I can suck them dry without worrying about fuel splashing away from the pickup because the 3/8 fuel like acts like a low sump. I never plan to go anywhere without the required 30-min reserve, but it is a great safety feature in case you run into an unanticipated headwind and there is no place to make a good landing. Also, I can now get a true 30 minutes from the lower part of the tank instead of having to leave 2 gallons in there to ensure the pickups do not suck air. All together I gained about 5 gallons usable fuel without having to add an extra tank.
Dan G.
503 Firestar II
Tucson AZ
