rgf(at)dcn.davis.ca.us Guest
Posted: Sun Dec 02, 2007 5:53 am Post subject: LSAs |
Speaking of LSAs....Chinese or otherwise...Van's RV-12 got me to thinking. That doesn't happen often and when it does, I take advantage of it.
I gotta think that the RV-12 could fly faster than the LSA speed limit (120 kts) with maybe just a coarser pitched prop. If so, would it be legit to:
- build or buy an LSA--say Van's--switch the prop, and fly it out of the LSA class with your PP-ASEL and current medical
- then if you don't want to renew your medical for some reason, simply switch the prop back again to be below 120 kts
Can the same plane, with a minor alteration, switch between LSA and not?
Ralph Finch
Posted: Sun Dec 02, 2007 8:07 am Post subject: LSAs |
Bigger engine or a different prop, and the RV-12 probably would fly faster than the LSA limit. But, it wouldn't be an LSA at that point. If it is *ever* registered as nonconforming to the LSA rules, it can never be put back into LSA.
Lots of Ercoupes, Aeroncas, etc. were LSA compliant as originally delivered. Unfortunately, they were modified with a variety of STC's, some of which raised their gross weight above the LSA spec's. And now, those aircraft can't be recertified as LSA's, even if the owners uninstall the STC's or decrease the aircraft's gross weight limit to LSA compliant figures.
It isn't perfectly logical, but that's the FAA and "rules by committee" for you.
KB
mike109g6(at)insideconnec Guest
Posted: Sun Dec 02, 2007 8:10 am Post subject: LSAs |
Doesn't that open a can of worms!!! LOL! What a selling point for Van's if applicable - multi-mission aircraft. But I'm sure that there are structural considerations in the design of the RV-12 that prevents Van's from selling/advertising this approach, ie the plug-in wings, etc. Interesting concept though.
Mike H 9A/8A
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Sun Dec 02, 2007 8:37 am Post subject: LSAs |
It's one of those questions that's fun to pose to Van, himself, just to be entertained by his reaction. (g)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of mike humphrey
Sent: Sunday, December 02, 2007 10:10 AM
To: rv-list(at)matronics.com
Subject: Re: LSAs
Mike H 9A/8A
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
tracy(at)rotaryaviation.c Guest
Posted: Sun Dec 02, 2007 9:52 am Post subject: LSAs |
I often hear this approach to speeding up airplanes and wonder where it comes from. Assuming that the engine is equipped with a prop that does
not allow the engine over- rev significantly to begin with (I doubt Vans would do this), a coarser pitched prop will only slow the engine down making
less power and making the plane go slower, not faster.
If this approach worked, we would all be flying 300 mph RVs.
Tracy Crook
Rotary powered RV-4
On Dec 2, 2007 8:49 AM, Ralph Finch <rgf(at)dcn.davis.ca.us (rgf(at)dcn.davis.ca.us)> wrote:
[quote] Speaking of LSAs....Chinese or otherwise...Van's RV-12 got me to thinking. That doesn't happen often and when it does, I take advantage of it.
Ralph Finch
Posted: Sun Dec 02, 2007 10:36 am Post subject: LSAs |
I don't want to start a flame war, but this statement is not true for many cases...my Alon Aircoupe, for instance, which definitely gains 6-8 mph with a cruise prop (52") over a climb prop (48"). I have both and have seen this several times. If changing pitch didn't help top or cruise speeds, why have constant speed (variable pitch) props on the higher performance aircraft.
I'm guessing--and it is a guess at this point--that the RV-12, like Van's other aircraft, is very low drag and that he's putting on a relatively flat pitch prop to keep the speed down. If true this will translate into a better climb rate. And if true, a simple prop change could allow speeds above the LSA limit. Voila, a dual-mission aircraft for cheap.
[quote] From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tracy Crook
Sent: Sunday, December 02, 2007 9:51 AM
Subject: Re: RV-List: LSAs
Tracy Crook
Rotary powered RV-4
Posted: Sun Dec 02, 2007 3:01 pm Post subject: LSAs |
I Love a good technical discussion and I never perceive disagreement as flame and hope others feel the same.
My contention was based on the statement "Assuming that the engine is equipped with a prop that does not allow the engine to over- rev significantly to begin with".
If the speed of an airplane is limited by intentionally installing a lower pitch prop, it will almost invariably overspeed the engine in level flight at full throttle. Did your Aircoupe do this? This is sometimes done (to improve climb performance) but it requires the pilot to back off the throttle in level flight to keep the engine below redline. I don't know the details of the LSA regs but if they allow you meet the top speed requirement by simply backing off the throttle, that would be a loophole big enough fly a 747 through. I doubt even a government agency could be that daft.
I should probably have added one other condition, that being "all else being equal". All else in this case would include prop efficiency. If you unbolt a lousy or unsuitable prop and install a very good one (I have owned both kind :>) the increase in performance could be due to that increase in efficiency and not related to to the pitch. BTW, 48" prop? Wow, I'm not surprised that the 52" outperformed it in almost every way. Maybe I'm thinking of a different Aircoupe. (one with C85 engine?) A 48" prop is way too short for the one I'm familiar with.
To stretch my credibility even further, all else being equal, a lower pitch prop will often fly faster than the so-called cruise prop (if you don't mind over-reving the engine). Engines will make more HP at higher rpm and it takes HP to go faster. The tach reading on the Formula planes at Reno would give most pilots a coronary. If they installed a higher pitch prop to bring revs down, I guarantee you they would go slower.
More sacred cow slaughter: Constant Speed props don't make planes go faster. They just eliminate the compromise between climb and cruise props. They also allow you to run the engine in it's best efficiency spot for most flight conditions. If takeoff & climb performance were not a factor, a fixed pitch prop (designed for max speed) would go faster than a CS prop.
Tracy Crook (ducking bovine projectiles)
On Dec 2, 2007 1:35 PM, Ralph Finch <rgf(at)dcn.davis.ca.us (rgf(at)dcn.davis.ca.us)> wrote:
[quote] I don't want to start a flame war, but this statement is not true for many cases...my Alon Aircoupe, for instance, which definitely gains 6-8 mph with a cruise prop (52") over a climb prop (48"). I have both and have seen this several times. If changing pitch didn't help top or cruise speeds, why have constant speed (variable pitch) props on the higher performance aircraft.
acepilot(at)bloomer.net Guest
Posted: Sun Dec 02, 2007 3:11 pm Post subject: LSAs |
I believe he was referring to 48" of pitch, not prop diameter
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Tracy Crook wrote:
familiar with.
mrobert569(at)hotmail.com Guest
Posted: Mon Dec 03, 2007 9:40 am Post subject: LSAs |
Ralph,
It depends on which category you certificate it in. If it is in the experimental amateur-built category then it is no problem. But if you were able to get it certificated in the Light-sport category then you would have a problem. In this case I don't think you will have to worry as I don't think it will qualify for the Light-Sport category, just the amateur-built category.
Mike Robertson
Das Fed
| Quote: | From: rgf(at)dcn.davis.ca.us
Subject: RV-List: LSAs
Date: Sun, 2 Dec 2007 05:49:57 -0800
Ralph Finch
t=_blank>http://www.matronics.com/Navigator?RV-List
p://forums.matronics.com
| You keep typing, we keep giving. Download Messenger and join the i’m Initiative now. Join in! [quote][b]
Posted: Mon Dec 03, 2007 10:19 am Post subject: LSAs |
D'oh, You're probably right Scott. I still stand by the rest of my blasphemies though : )
Tracy
On Dec 2, 2007 6:10 PM, Scott <acepilot(at)bloomer.net (acepilot(at)bloomer.net)> wrote:
[quote]--> RV-List message posted by: Scott <acepilot(at)bloomer.net (acepilot(at)bloomer.net) >
Scott
Tracy Crook wrote:
familiar with.
Posted: Mon Dec 03, 2007 2:20 pm Post subject: LSAs |
Not to worry! I have days like that too!
Scott
Tracy Crook wrote:
| Quote: | D'oh, You're probably right Scott. I still stand by the rest of
Tracy
<mailto:acepilot(at)bloomer.net>> wrote:
<mailto:acepilot(at)bloomer.net> >
Scott
it in
(one
> familiar with.
