rudder repair
jlno7(at)aim.com
PostPosted: Wed Nov 28, 2007 3:53 pm    Post subject: rudder repair Reply with quote
There is some damage to the tail fuselage to my Kitfox One. The tubing is bent in the under belly near the rudder and the rudder is bent and the tubing is worn. My AP noticed it and says that the rudder needs to be repaired or replaced and a new tube welded in to replace the bent one and the rudder will need a new tub and fabric. The AP doesn't feel qualified to do the welding. Where do I go from here? Is there anyone in the Green Bay Wisconsin area who you might know who would do this repair?
Jerry
More new features than ever. Check out the new AIM(R) Mail!
Guy Buchanan
PostPosted: Wed Nov 28, 2007 4:41 pm    Post subject: rudder repair Reply with quote
I don't know if EAA wants us to do this, but I pulled a list of Wisconsin Technical Counselors from their web site. I don't see any in Green Bay, but maybe you can locate one who can lead you to an appropriate repair person. I tried to find A&Ps, but all I got was supermarkets.
Guy
Dale H. Jorgensen-Algoma, WI
Home - (920) 487-3881
Work - (920) 360-4830
Bennett A. Ludtke-Beaver Dam, WI
Home - (920) 885-2480
Michael J. Gaffney-Briggsville, WI
Home - (608) 981-2238
Work - (608) 742-4636
Edward J. Simpson-Camp Lake, WI
Home - (847) 395-4549
Work - (262) 889-8187
David A. Juckem-Chilton, WI
Home - (920) 849-4398
Work - (920) 849-9151
Douglas C. Apland-Chippewa Falls, WI
Home - (715) 723-5919
Glenn W. Gauger-Delavan, WI
Home - (262) 740-2413
Work - (262) 534-6315
Ronald G. Scott-East Troy, WI
Home - (262) 642-7423
Alan E. Nicoson-East Troy, WI
Home - (262) 565-6427
Work - (262) 215-5055
Roberta A. Hegy-East Troy, WI
Home - (262) 470-6181
Work - (414) 944-5700
Paul B. Buss-Eland, WI
Home - (715) 253-2490
Joe Schumacher-Florence, WI
Home - (715) 528-4489
Work - (715) 528-4489
Mark T. Schroeder-Fond du Lac, WI
Home - (920) 923-2711
Work - (920) 921-7845
John F. LeClercq-Forestville, WI
Home - (920) 559-7195
Work - (920) 559-7195
Fred J. Keip-Franksville, WI
Home - (262) 835-7714
Work - (262) 636-5828
Pat Spanaus-Hartland, WI
Home - (262) 538-0859
Work - (262) 367-7550
Kent Bummert-Holmen, WI
Home - (608) 526-9464
Work - (608) 385-0994
Archie H. Henkelmann-Janesville, WI
Home - (608) 752-5474
Dave F. LeVoy-Marshfield, WI
Home - (715) 676-2282
Work - (715) 687-3133
Allan O. Checky Jr-Merrimac, WI
Home - (608) 643-5151
Work - (608) 393-0773
Scott D. Jones-Milwaukee, WI
Home - (414) 466-1860
Work - (414) 461-6013
Frederick F. Flood-Milwaukee, WI
Home - (414) 282-7502
Jeff Point-Milwaukee, WI
Home - (414) 329-0054
Work - (414) 915-9173
Michael Weeden-Monroe, WI
Home - (608) 329-6652
William Tromblay-Mukwonago, WI
Home - (414) 313-5542
Work - (414) 313-5542
Greg J. Klemp-Neshkoro, WI
Home - (920) 293-8089
Tracy Buttles-New London, WI
Home - (920) 982-2509
Work - (920) 982-2509
Tom Seversen-New London, WI
Home - (920) 982-2203
Peter Tallarita-New Richmond, WI
Home - (715) 246-9143
Work - (612) 414-9505
Charles M. Allen-Onalaska, WI
Home - (608) 779-4899
Daniel Dudley-Oregon, WI
Home - (608) 835-8931
Work - (608) 263-2359
Joseph B. Norris-Oshkosh, WI
Home - (920) 688-2977
Work - (920) 426-6806
Norman A. Petersen-Oshkosh, WI
Home - (920) 426-2217
Earl Lawrence-Oshkosh, WI
Home - (920) 233-3972
Work - (920) 426-6522
Lyle M. Forsgren-Oshkosh, WI
Home - (920) 589-6501
George Rotter-Oshkosh, WI
Home - (920) 231-6446
Ron Wagner-Oshkosh, WI
Home - (920) 303-6193
Work - (920) 426-6122
Gary H. Buettner-Oshkosh, WI
Home - (920) 236-8704
Work - (920) 426-4854
Mark Gerlach-Oshkosh, WI
Home - (920) 231-6916
Work - (920) 233-3350
Steve Johnson-Pardeeville, WI
Home - (608) 429-3348
Paul McAllister-Pewaukee, WI
Home - (262) 695-7624
Scott K. Cater-Racine, WI
Home - (262) 639-3559
Work - (262) 652-4444
Larry Melau-Rhinelander, WI
Home - (715) 282-6462
Douglas P. Karis-Rice Lake, WI
Home - (715) 234-7540
Work - (715) 234-7540
Richard Marr-River Falls, WI
Home - (715) 425-0262
Work - (612) 751-6165
Joseph C. Weisbrod-Rosholt, WI
Home - (715) 677-3573
Ralph Skorupa-Salem, WI
Home - (262) 889-4438
Work - (815) 459-4405
Alan R. White-Superior, WI
Home - (715) 399-8564
Work - (715) 399-8564
Richard H. Pedersen-Tony, WI
Home - (715) 532-6276
William M. Rewey-Verona, WI
Home - (608) 833-5839
Raleigh H. Illgen-Watertown, WI
Home - (920) 699-2483
Bonnie Eales Jensen-Waukesha, WI
Home - (262) 574-0429
Work - (262) 894-4840
Herbert Statz-Waunakee, WI
Home - (608) 849-4675
David J. Conrad-Wausau, WI
Home - (715) 845-7545
Work - (715) 842-4371
Richard Carter-Wauwatosa, WI
Home - (414) 476-0705
Carl E. Schultz-Wind Lake, WI
Home - (262) 895-6194
Albert L. Barger-Windsor, WI
Home - (608) 846-1941
Work - (608) 836-1711
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
kirkhull(at)kc.rr.com
PostPosted: Wed Nov 28, 2007 4:56 pm    Post subject: rudder repair Reply with quote
I bet you could find an EAA chapter around green bay that could help you do it your self. That is one of the best parts of an experimental. No A & P required.
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Guy Buchanan
Sent: Wednesday, November 28, 2007 6:41 PM
Subject: Re: rudder repair
[quote] [b]
Fox5flyer
I would think that being that close to the EAA "Mecca" there should be lots of good aircraft tubing welders around. I suspect you'll get some good hits right here though.
What happened to it?
Deke
NE MI, S5, 370TT
darinh
PostPosted: Wed Nov 28, 2007 6:55 pm    Post subject: Re: rudder repair Reply with quote
Remember you are working with chromoly tubing...its takes a slightly different welding technique than regular steel. Having said this, any good welder will know what filler material to use. Should be a pretty easy fix.
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
n85ae
PostPosted: Thu Nov 29, 2007 8:48 am    Post subject: Re: rudder repair Reply with quote
It's pretty much a guarantee that any decent local welding shop, that
can do acetylene or tig can do a more than acceptable job for you. You
can buy tubing from AC Spruce, and use RG-45 or RG-60 welding rod.
I wouldn't get to worried about welding it, 4130 is VERY easy to weld
well.
Jeff
flier
PostPosted: Thu Nov 29, 2007 11:59 am    Post subject: Re: rudder repair Reply with quote
Thinwall 4130 is not nearly as forgiving as mild steel to weld. Needs to be done in an absolute breeze free environment. For TIG ER70S-2 filler is recommended. Post weld annealing is always debated but I always run a torch over TIGed chromoly. Nice thing about the rudder is aside from the spar it's not all that complex or highly loaded so just about anyone decent with a torch (TIG or OA) should be able to even build a new rudder for a Kitfox....
Ted
n85ae
PostPosted: Thu Nov 29, 2007 12:31 pm    Post subject: Re: rudder repair Reply with quote
Ted -
The only thing I've ever welded was thinwall 4130 Smile So I guess I really
can't compare.
Jeff
dave
PostPosted: Fri Nov 30, 2007 2:14 am    Post subject: Re: rudder repair Reply with quote
The proper term is "normalizing" not annealing.
Heat to a dull red and slowly pull torch away. A no draft t shop is critical as even faster air cooling can cause brittleness.
A good fit is very important for excellent welds. TIG or oxy/acetylene is good although I do prefer the latter.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
n85ae
PostPosted: Fri Nov 30, 2007 11:30 am    Post subject: Re: rudder repair Reply with quote
Well, if you consider that Skystar just blasted most of them together via,
MIG, as does American Champion I think the fear of cracks is for the
most part grossly exagerrated. Nothing I ever welded has cracks, and
that includes all the weld's I practiced on when I later beat on them
with a hammer.
I know that they can crack, and there is a lot of literature about how
to avoid cracks. But I think in real life, for the most part if you acetylene
weld 4130 odds are pretty good, you'll never see any cracks.
I think more importantly is just pay attention to getting a nice quality
weld. This is probably 99.9% of the strength anyway.
Jeff
dave
PostPosted: Fri Nov 30, 2007 1:46 pm    Post subject: Re: rudder repair Reply with quote
Jeff, Cooling too fast will cause crystallization.
I would say that the fit of the joint it very important as well if not critical to ensure a strong joint.
Welding -well anyone can weld right? No , not really.
Acetylene welding you might not see cracks but you might find a hardened area around the weld or the weld itself and that could lead to issues down the road.
Welding .025 to .050 4130 can be very challenging for many, I would not suggest anyone use a MIG on it unless they are very good with MIG, thin wall tubing and different welding techniques like stitch welding.
most part grossly exaggerated. Nothing I ever welded has cracks, and
with a hammer.
Jeff
lcfitt(at)sbcglobal.net
PostPosted: Fri Nov 30, 2007 2:55 pm    Post subject: rudder repair Reply with quote
Based on my observations after viewing my destroyed airframe at the boneyard
and a close look at some pictures taken at the crash site by a friend, I
would conclude that the tig welded joints on my Model IV airframe were not
normalized after welding. There were very few welds that broke if any.
Every broken joint was within 2" from the weld. Exactly where the
crystalization would be expected. What this means in everyday flying, I
won't hazard a guess except to say that historically, there has never been
an airframe inflight failure. Hard landings? Another matter entirely.
I am attaching some photos of the airplane. They have been reduced in
resolution for band width reasons and the resolution is not great.
Lowell
darinh
PostPosted: Fri Nov 30, 2007 3:04 pm    Post subject: Re: rudder repair Reply with quote
Dave & Jeff,
This is an interesting topic for me because last weekend, Lowell & Kay Fitt stopped by my shop to check out my project while they were in Utah visiting family. I got talking to them about the accident and he mentioned that all the tubing from the forward carry-thru tube broke on impact...none of the actual welds broke but about 1 to 1.5 inches ahead of the welds is where the tubing broke. I guess the heat "normalizing" around the weld does make a difference but it looks like the rest of the airframe is not "normalized" It appears that in the case of the Kitfox, the welds are stronger than the parent material...I think this is the case in any good weld.
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
PostPosted: Fri Nov 30, 2007 4:30 pm    Post subject: rudder repair Reply with quote
I see I forgot to add the photos. find attached.
Lowell
 Filesize:  49.82 KB
 Viewed:  649 Time(s)
 Filesize:  49.73 KB
 Viewed:  708 Time(s)
 Filesize:  49.76 KB
 Viewed:  666 Time(s)
 Filesize:  50.31 KB
 Viewed:  674 Time(s)
PostPosted: Fri Nov 30, 2007 7:04 pm    Post subject: rudder repair Reply with quote
Looks like the rudder is the only part that doesn't need to be repaired
