n8vim(at)arrl.net Guest
				 Posted: Wed Nov 28, 2007 6:24 am    Post subject: N289DT preliminary report NYC08LA023 |
				NTSB Identification: *NYC08LA023*
 14 CFR Part 91: General Aviation
 Accident occurred Friday, November 02, 2007 in Greenville, PA
 Aircraft: Vans Aircraft RV-10, registration: N289DT
 Injuries: 1 Fatal.
 This is preliminary information, subject to change, and may contain
 errors. Any errors in this report will be corrected when the final
 report has been completed.
 On November 2, 2007, at 0830 eastern daylight time, an amateur built
 Vans RV-10, N289DT, was substantially damaged when it impacted terrain
 near Greenville, Pennsylvania. The certificated private pilot was
 fatally injured. Day visual meteorological conditions prevailed for the
 local flight that departed Greenville Municipal Airport (4G1),
 Greenville, Pennsylvania. No flight plan was filed for the personal
 flight conducted under 14 CFR Part 91.
 According to a family member, the pilot had driven to the airport to
 practice "touch and go's" and to make sure everything was functioning
 properly, prior to a planned afternoon trip in the airplane with his
 family to Boston, Massachusetts.
 Witness interviews were conducted by the Federal Aviation Administration
 (FAA) and the Safety Board, and while no one saw the airplane depart
 4G1, the airplane was observed by a witness at approximately 0800
 traveling in a northwesterly direction at low altitude, moving "fast,"
 and sounding like it was "running strong like a Ford Mustang
 (turbocharged) Cobra that the witness once owned." At approximately
 0825, the airplane was again observed but, this time by multiple
 witnesses. Descriptions varied between witness statements as to the
 altitude, direction of flight, and velocity of the airplane; however,
 the preponderance of witness statements were that the airplane was
 flying north on the east side of Pennsylvania State Route 58, and seemed
 to make a circle to the left at approximately 500 feet above ground
 level (agl). It was next observed to travel in a westerly direction, fly
 across Route 58 and make another turn to the left with the engine
 "revving up and down," and losing altitude. When it reached
 approximately 50-feet agl and was heading east, the airplane rolled
 wings level and impacted a cornfield in a 35 to 60 degree nose down
 attitude. A fireball erupted, and the airplane slid approximately
 100-feet. It then impacted the shoulder of Route 58, nosed over, and
 came to rest inverted on the roadway.
 The amateur built airplane, was a four place, low wing monoplane. It was
 equipped with a non-certificated Eggenfellner E6T/220, which was a water
 cooled, fuel injected, turbo-charged, six cylinder engine. The
 airplane's special airworthiness certificate was issued on July 10, 2007.
 The pilot held a private pilot certificate, with a rating for airplane
 single engine land. His most recent FAA third class medical certificate
 was issued on March 14, 2006. According to his pilot logbook, he had
 accrued 221.4 total hours of flight experience.
 A weather observation taken about 23 minutes after the accident at Port
 Meadville Airport (GKJ), Meadville, Pennsylvania, located about 14
 nautical miles northeast of the accident site, recorded the winds as 090
 degrees at 4 knots, visibility 10 miles, sky clear, temperature 1 degree
 Celsius, dew point -2 degrees Celsius, and an altimeter setting of 30.36
 inches of mercury.
 The wreckage was retained by the Safety Board for further examination.
