ScooterF15
Posted: Mon Nov 26, 2007 3:33 pm Post subject: Radio Static Help |
Hi,
I appreciate all the suggestions regarding my radio static problems. I finally got my hands on another SL-30 unit and slid it into the tray... problem solved. Turns out my brand new SL-30 radio was the culprit. I just got word from Garmin that there was a bad solder joint inside my radio.
-Jim
40134
In a message dated 10/29/2007 3:37:35 P.M. Eastern Daylight Time, JSMcGrew(at)aol.com writes:
| Quote: | 4 years ago today I placed my order for RV-10 tail kit #40134 as a birthday present to
myself. Now, 2500 building and 100 flying hours later, I can say it was a pretty nice gift
and well worth it... unfortunately I haven't got all the bugs worked out yet:
I've spent the last few weeks trying to track down a problem with radio static on my
Garmin SL-30 Nav/Comm. The SL-30 is attached to a Garmin GMA-340 Audio panel.
The static itself sounds random (i.e. not obviously uniform like I would expect from an ignition
system), however, it is somehow associated with engine throttle setting. The
static starts around 2000 RPM and gets progressively worse as throttle increases.
On takeoff, it is so bad you can not comprehend any received transmissions. During cruise it appears
to be somehow associated with manifold pressure (i.e. throttle setting, not RPM). It makes
listening to ATC difficult to impossible. I also think it may be affecting my radio
transmissions as well, because when I have a hard time comprehending ATC, they
also have a hard time understanding me. This static appears to be only affecting
the Comm audio, there is no static on NAV audio reception. I have a belly mounted
bent whip VHF antenna and a wingtip VOR antenna. My handheld ICOM VHF radio
does not have any static when used inside the cockpit.
I have searched various lists for ideas and tried to solve this problem, but
I have had no success in changing it at all (for better or worse). Any
suggestions for what to try or where to look will be welcome. Below is a list
of some things I have tried with no luck.
General
-Shut off all avionics (except SL-30) and both ignition systems (not both at the same time)
--So it doesn't appear to be interference from other electronics
Antenna/Coaxial cable
-Added ferrite signal filters at various locations along comm coax.
-Connected SL-30 to a different comm antenna using a piece of RG-400 (tried
various routings to antennas)
-Connected SL-30 Comm to VOR antenna (great reception, still static)
--So it doesn't appear to be antenna related
Power/ground
-Ensured engine grounding cables have good contacts on both ends
-Apparently new Slick Magnetos have internal suppression and do not need a filter
-Separated SL-30 power/ground leads from bundle to reduce potential interference from other wires
-Ran SL-30 +12V and ground leads directly to battery
-Disconnected serial connection between my SL-30 and EFIS indicator
-Connected SL-30 to separate 12V battery sitting on floor of aircraft, disconnected power/ground
to GMA-340. Attached ICOM handheld antenna directly to unit (SL-30 completely isolated
from aircraft)-reception still has static
-Ran ground wire from battery to SL-30 tray
-Checked to ensure headseat jacks were isolated from aircraft ground.
-Checked the shield connections for tachometer and fuel flow sensor wires
I can't think of anything else to try. Again, I'd be happy to hear any suggestions.
Thanks.
-Jim
N312JE
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
Check out AOL Money & Finance's list of the hottest products and top money wasters of 2007.
n8vim(at)arrl.net Guest
Posted: Mon Nov 26, 2007 4:35 pm Post subject: Radio Static Help |
Great news!
Is your SL-30 RoHS compliant? I ask because the lead-free solder tends to be much more brittle than the regular lead-based solder (and tin whiskers are a problem). where I work, in the medical field, we have an exemption (as does the military) - but with everyone EOLing (End Of Life) their components we're being taken along for the ride and have had these problems as well.
Its really funny.... lead-free solder was a big problem in the early 1900's. The solder would grow 'tin whiskers' and short out connections. In the 1940's, it was discovered that you could avoid problems by adding some lead to the tin. Now, in the lead-free craze, brittle connections and tin whiskers are back! The most public result of this problem (documented in "Engineering Disasters 20" (I think its #20, possibly 18 or 19) was the loss of the G4 satellite in 1998
-Jim 40384
JSMcGrew(at)aol.com (JSMcGrew(at)aol.com) wrote: [quote] Hi,
-Jim
40134
In a message dated 10/29/2007 3:37:35 P.M. Eastern Daylight Time, JSMcGrew(at)aol.com (JSMcGrew(at)aol.com) writes:
General
Power/ground
Thanks.
-Jim
N312JE
