Covering wingtips- fabric reinforcement plates
roncarolnikko(at)hotmail.
PostPosted: Mon Feb 20, 2006 9:58 pm    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
I am nearing the point of covering my wings and I have a few questions. My
manual says to trim the fabric a few inches out onto the wingtip for
non-removable tips. My Avid Flyer has the entire wingtip covered in fabric,
but this suggests the fabric will end just beyond where the tip screws on.
I want the covered tips to use the polytone to the end.
Also my manual shows the strut bracket reinforcement plates for the
fabric. I assume these go under the fabric, but find no mention of
installing them. Do they rivet to the spar over the strut attachments?
Boy do I feel brain drained.... Ron NB Ore
Lynn Matteson
PostPosted: Tue Feb 21, 2006 4:47 am    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
Are you fixing your wingtips to the wings with rivets, or screws so
that they can be removed at some time? I let my fabric stop at the last
rib and screwed (with anchor nuts riveted to an added-on aluminum
strip) the wingtips on. If you're going to cover the tips, never to be
removed, then of course let the fabric go all the way to several inches
past the wingtip.
The reinforcement plates are merely glued to the under side...inside of
wing...of the lower fabric with poly-tak. One of my manuals (one is
original 1993 Model IV manual, the other is the Classic IV manual of
2003 revision) says to pre-coat the plates with poly-brush (two coats)
and the other manual doesn't mention the pre-coating (or at least I
couldn't find it quickly), then attach with poly-tak. You have to coat
one side of the plate with wet poly-tak and quickly slide it in place
over the strut bracket, and position quickly and then hold in place,
pressing the fabric onto the plate...it's a messy job. MAKE SURE that
you get these plates in/on before you start the top fabric...nearly
impossible afterwards...no, forget nearly, it IS impossible.
Lynn
On Tuesday, February 21, 2006, at 12:53 AM, ron schick wrote:
<roncarolnikko(at)hotmail.com>
questions. My
fabric,
on.
Lynn
Kitfox IV-Jabiru 2200
N369LM
KITFOXPILOT(at)msn.com
PostPosted: Tue Feb 21, 2006 7:39 am    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
Hi Lynn,
Just seen your Fox on frappr, nice plane, looks like you're a race fan!!
MichaelGibbs(at)cox.net
PostPosted: Tue Feb 21, 2006 7:55 am    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
Ron,
I built my IV-1200 so that the wingtips could be removed. This made
it very easy to cover because the fabric just goes over the end of
the last rib and the tip screws on over that. Yes, the fiberglass
had to be painted separately, but at condition inspection time it
sure is nice to be able to remove a few screws and see the entire
inside of the wing.
Just a thought.
Mike G.
N728KF
mteixeira(at)wmlylesco.co
PostPosted: Tue Feb 21, 2006 10:36 am    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
Lynn
I have one wing with the added-on aluminum strip installed (previous
owner), but the wing is not covered. Can I cover this added-on strip
with fabric? Will the fabric have enough hold if it doesn't wrap around
the end rib cap strip?
Thank you,
Matt
IV-1200
Fresno, CA
Vic Baker
PostPosted: Tue Feb 21, 2006 11:05 am    Post subject: Re: Covering wingtips- fabric reinforcement plates Reply with quote
Matt,
I wrapped the fabric around the wing tip supports. Take care if you drill and mount the wing tip attachment hardware before covering with fabric, the mounting holes will not line up due to the slight increase in thickness. I have not yet drilled/mounted the wing tips, (will do so after paint) hopefully I am not in for an unpleasant surprise!
Vic Baker
Series 7
Carson City, Nevada
aldaniels(at)fmtc.com
PostPosted: Tue Feb 21, 2006 12:14 pm    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
I found the best way to put them on is to tape them to the lift strut
attach bracket then cover the bottom of the wing. Shrink the fabric to
about 275 or just tight. Brush polybrush around were you need to cut for
jury strut and lift attach bracket. When dry cut with a razor blade and
the protrusion will pop through in just the right place. Turn the wing
over and glue down the aluminum reinforcement plates to the fabric.
PostPosted: Tue Feb 21, 2006 2:42 pm    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
Lynn I was planning on covering the wingtips. It does have the riv-nuts
installed now so maybe I will go back to the idea of removable tips. The
prior owner had covered them and my mindset was stuck on that road. If I
must trim and redrill anyway I wont be concerned about his poor fit and
attachment. Alan and everyone great info on the reinforcements, I made them
on my lunch hour and will tape in place before they get forgotten. Thanks
to everyone for the push as now I will be removable and possibly extendable.
Ron NB Oregon MK IV Speedster
Subject: Re: Covering wingtips- fabric reinforcement plates
Date: Tue, 21 Feb 2006 07:49:00 -0500
past the wingtip.
Lynn
> questions. My
> fabric,
> on.
Lynn Matteson
PostPosted: Tue Feb 21, 2006 6:05 pm    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
What tipped you off to the "race fan" thing, Ray? Was it the orange
(Tony Stewart colors)....the bare amount of white (typical of
unsponsored race cars)....the black (perhaps Kevin Harvicks'
colors)...wait a minute, NO, don't tell me it was the graphic on the
vertical fin? That thing that *looks* like maybe a number three? Now
who could THAT be? Yup, Ray, it's true, I'm a race fan...gotta admit
it. But you'll notice that I made the "3" just enough different from a
particular copyrighted #3 that I hope I won't get any visits from
Richard Childress's lawyers telling me to change it. Maybe as a
precaution I'll keep the plane in the hangar when the Nascar boys come
to visit this summer at nearby (15 miles) Michigan International
Speedway. Or maybe if I'm flying it by then, make a pass close enough
to MIS to let 'em know how REAL Dale Earnhardt fans express their
undying loyalty.
Just for grins, take a real close look in the background of the plane
picture, and you might see two vehicles lurking in the dark, both
wearing a #3 front license plate...hell, it's the real reason I moved
back to Michigan from California....no front license plate requirements
here.
Lynn
On Tuesday, February 21, 2006, at 10:38 AM, RAY Gignac wrote:
Hi Lynn,
fan!!
Lynn
N369LM
Lynn Matteson
PostPosted: Tue Feb 21, 2006 6:35 pm    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
Yes, that's what I did...rivet the aluminum strip to the underside of
the last rib cap, then when it's time to cover, press the fabric down
into the right-angle formed between the cap and the aluminum strip,
across the strip, around the edge of the strip, and cement under the
strip. It'll hold 'til the cows come home....actually longer than THAT,
thank God! I'm not sure if the fabric would hold just being glued to
the strip itself, so why take chances. And don't forget that this area
will be covered with the pinked finishing tapes, which I also formed
down into the cap/strip interface.
Lynn
On Tuesday, February 21, 2006, at 01:33 PM, Matt Teixeira wrote:
<mteixeira(at)wmlylesco.com>
Lynn
around
Thank you,
Matt
IV-1200
Fresno, CA
Lynn
N369LM
PostPosted: Wed Feb 22, 2006 9:13 am    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
Lynn
Thank you for the reply. I can't tell you how happy I am that I don't
have to take another part off this wing. Now I'm moving forward.
Matt
IV-1200, Fresno, CA
Lynn Matteson
PostPosted: Wed Feb 22, 2006 12:17 pm    Post subject: Covering wingtips- fabric reinforcement plates Reply with quote
Good show,Matt.
Lynn
Lynn
Matt
IV-1200, Fresno, CA
Lynn
N369LM
